Question about Dryers
Replacing the belt on my Whirlpool awz7303 tumble dryer
The belt has broken and I have taken the machine apart to retrieve the broken belt. I now need to put the new belt in but not sure how to do it correctly. Can you help or point me towards some instructions please
  • 2 more comments
  • abizack Jul 11, 2008
    Thank you. Worked a treat
  • scottallen21 Jul 29, 2008
    hi have a whirlpool awz7303 condenser tumble dryer and the belt has snapped a took the top and back panels and the drum out so i could get to the wheels underneath the drum but i cant work out how to fit the belt back on can any one help?
  • ijha Aug 12, 2008
    I want to know how to fit a new belt to a Whirlpool AWZ 650 dryer
  • iancrome01 Oct 23, 2008
    i need to fit a new belt also but cannot wrk out how to get the belt around the drive shaft from the motor i have removed all panels and the tumble drum but do i need to remove motor and drive shaft?? help pls.
You definitely need circlip pliers to get the fan off though.. It's a bit tricky without them. Othere than that it's a fairly easy job.
Posted on Nov 13, 2009
  • adavb1 May 12, 2011
    I can't get the fan off. Aaaarrrgggg
It is an easy enough repair with little need for tools.
Unplug the dryer first. Remove the top via the 3 screws at the back. then carry on and remove the back panel. It maybe easier to disconnect the mains plug on the inside of the machine (top left if looking from the back)
remove the other screws at the rear holding the drum in.
You can then remove the screws holding the fan cover in and just put a slight bit of force on pulling the plastic housing and push the retaining tabs down on the fan housing - that will come off.
To remove the fan I was able to to pull mine - but some say you need to remove the circlip - I am not sure if this is true - anyway you can take the fan out and gain access to the motor.
Fit the new belt over the drum (ridges down). and then you will need about six hands but you need to fit it onto the metal rod coming from the motor. this need to be fitted inbetween the tensioning rollers. Had to describe but easy to see when looking at it - basically you need to pull the wheels apart and fit the belt inbetween then.
Re-assamble it all and hey presto it works.
Posted on Apr 14, 2013
Hi i just fitted a belt to this tuble dryer, you have to take the bak off and the inside back off, lift out the drum and at the bottom there's a fan, take it all out and your left with the tensioner's and the mental rod, fit the belt on to the rod and sperate the tensioner's to pull the belt through the middle of the tensioner's, put the drum back on and fit the belt onto the drum, thenfit the rest, fan, etc.. tht should be it.
Posted on Jul 08, 2008
  • 2 more comments
  • whiteamara2
    whiteamara2 Jan 21, 2012
    top tip , many thanks , thought i was stumped until i read this post
  • Steve Arendse
    Steve Arendse Dec 03, 2012
    hi guys,theres no way of getting around fan housing,must belt slip over shaft of fan as i am stuck at this point,,i need a set of sirclip pliersciorrect.
  • Steve Arendse
    im at stage of taking fan off..my electrician neighbour has sirclip pliers...i bought a belt slightly longer,will tensioner do its part??
  • Arron
    Arron Nov 28, 2014
    idk if you will reply now, but how did you remove the fan? It's the only thing stopping me from finishing this.
Whirlpool dryer awz 121 only tumbles counter clockwise. This is a dryer that briefly reverses direction, so the only tumbling is when it reverses. The rest of the time, the dryer makes a noise but d
You may want to contact a professional that will have the diagrams for your machine online. there are some here or you can go to another site. like (Just answer.) Be more specific about your problem. It can be fixed . There's no worries.
Are you saying that it does not heat up either ?In addition with not tumbling clockwise ?
Disconnect the dryer first. You can remove the top and front of the dryer to check to see what is happening. If it does not heat . You may need to replace the temperature control relay. If that does not work , the heating elements themselves may need to be replaced.
For the tumbling problem, they also have relay switches that go out.
BUT, if it is tumbling to one side and keeps tumbling then that will probably be enough to dry your clothes. As long as it is not too heavily loaded.
Mar 19, 2014 | Whirlpool Dryers
Whirlpool tumble dryer AWZ7303
Could you please describe the problem you are having a little better?
Dec 03, 2012 | Dryers
My whirlpool portable 3 cycle druer stopped tumbling is there a belt because I,ve taken it apart and can,t find it
The belt may have gotten wrapped up in the outer shell of the drum. In any event, armed with the Model # and Serial #, you can purchase the replacement belt from any local appliance dealer's parts dept. Since it's already been taken apart, you're one step ahead of what you would have needed to do.
Hope this helped you.
Mar 02, 2011 | Heating & Cooling
Whirlpool tumble dryer model NO- AWZ 121/3-belt replacement
how do i replace my belt on my tumble dryer
Jan 09, 2010 | Whirlpool Dryers
Dryer does not want to tumble
Felicia
make sure to see if the blower runs free
in this case is your drum belt broken
if you have someone at home to dissassamble the dryer then
replace the belt and test the machine
this is a normal situation when the dryers are not tumble
May 26, 2009 | Whirlpool Dryers
Dryer not tumbling
A broken belt is very common. If you hear the motor running, that's probably it. The dryer must be taken all apart to replace the belt. Hopefully instructions will come with the new belt. Routing the belt over the motor shaft and around the tensioner is always a challenge.
Apr 22, 2009 | Candy CDV262 Dryer
Broken belt on hotpoint vtd65 tumble dryer
turn the macine aroun you wiil see3screws on the top holding the lid on remove these and take the top off there are 3or4screwes on the top in front of machine remove these lay the macine back at45degres and on the bottom of machine you will find 4more screws remove these and the front will come off place new belt over the drum and with a small crow bar linked through the belt and under the drive apply a lot of down presure to get it on to drive this is realy hard and you mey think the belt is to small it is not make sure u align drum in to front door or machine this is very simple then re assemble and away you go approx time45to hours work
Dec 06, 2007 | Dryers
Zanussi tumble dryer
take it apart and you will see that the belt is probably find the belt broke
Nov 05, 2007 | Kenmore 64902 Electric Dryer
Dryers Logo
3,541 people viewed this question
Top Dryers Experts
