Casio FX-7400G Plus Calculator Logo
Posted on Oct 15, 2010
How to differentiate y=sin9x+1/log2x - Casio FX-7400G Plus Calculator
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 02, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
42
Points
What is the other slider button used for? How do I set the differential +/-
Setting thermostat differential to 3 degrees? - HVAC-Talk
hvac-talk.com/vbb/showthread.php?...Setting-thermostat-differential-to...
Dec 27, 2006 - 12 posts - ‎5 authors We set both the differentials on the thermostat to 3 degrees. ... very low, but I doadmit to changing the differentials to 1 degree on the thermostat ... How does an adjustable temperature differential work?
Apr 5, 2011
Honeywell Thermostat TH8000 Series
Jun 27, 2009
Honeywell Thermostat Cycle Time
Feb 3, 2005
More results from hvac-talk.com
Need recommended Fluid specs and amounts to change oil for 1996 Toyota Tacoma 4 wheel drive front and rear axles
Hello there,
From this page https://www.worldsbestoil.ca/product-cross-reference.php?year=1996&make=TOYOTA&model=TACOMA&engine=2.7L&vin=1
Extract.......
.Engine, 2WD, with filter - 5.4 quarts [1]
Engine, 4WD, with filter - 5.3 quarts [1]
Cooling System, Initial Fill - 9 quarts
AMSOIL Antifreeze and Engine Coolant
Automatic Transmission, A340E Initial Fill - 1.7 quarts
Automatic Transmission, A340F Initial Fill - 2.2 quarts
Automatic Transmission, A43D Initial Fill - 2.6 quarts
Automatic Transmission, Total Fill
4 speed A340F - 10.4 quarts
4 speed A340E - 7.7 quarts
4 speed A43D - 6.9 quarts
Manual Transmission, - 5.3 pints
Differential, With ADRD Front - 2.6 pints
Differential, Without ADRD Front - 2.4 pints
Differential, 2WD Without LSD Rear - 6 pints
Differential, 4WD Extra Long Rear - 4.5 pints
Differential, With LSD Rear - 6.4 pints
Differential, Standard Rear - 6 pints
Transfer Case, - 2.2 pints\'
2answers
Need to find and replace the DPFE-15 sensor. Dealership diagnosed when service engine light came on and saaid this is what needed replacing. Problem is I do not know where to find it on the engine.
Exhaust Gas Recirculation (EGR) System The exhaust gas recirculation (EGR) system is designed to:
  • reintroduce exhaust gas into the combustion cycle.
  • lower combustion temperatures.
  • reduce the formation of oxides or nitrogen (NOX).
The amount of exhaust gas reintroduced and the timing of the cycle varies by calibration. Timing and volume are controlled by the following:
  • engine rpm
  • engine vacuum
  • exhaust system back pressure
  • engine coolant temperature
  • air charge temperature
  • throttle position
The EGR valve (EGR valve) (9D475) is vacuum-actuated. The vacuum hose routing diagram is shown on the Vehicle Emission Control Information (VECI) decal. The EGR system is a differential pressure feedback EGR Sensor system. Differential pressure feedback EGR Sensor is a subsonic closed loop EGR system. The differential pressure feedback EGR system:
  • monitors EGR flow rate by the pressure drop across the metering orifice located in the EGR tube.
  • uses a differential pressure feedback EGR sensor as the feedback device.
  • uses the EGR valve only as a pressure regulator, rather than a flow metering device.
  • controlled pressure is varied by the valve movement using vacuum output of the EGR vacuum regulator solenoid (9J459).
  • allows for a more accurate assessment of EGR flow requirements.
Differential Pressure Feedback EGR Flow Diagram
Differential Pressure Feedback EGR Sensor Removal
  1. Disconnect engine control sensor wiring (12A581) from Differential Pressure Feedback EGR Sensor.
  1. Disconnect Differential Pressure Feedback EGR Sensor hoses from EGR valve to exhaust manifold tube (9D477).
  1. Remove retaining nuts or bolts (depending upon application) and EGR Differential Pressure Feedback transducer.
Installation
  1. Follow removal procedure in reverse order.
  1. Tighten retaining nuts or bolts (depending upon application) to 5-7 Nm (45-61 lb-in).
    Differential Pressure Feedback EGR Sensor, 3.0L (2V) Engine
    Differential Pressure Feedback EGR Sensor, 3.0L (4V) Engine
    Item Part Number Description 1 6049 RH Cylinder Head 2 - Differential Pressure Feedback EGR Sensor 3 - Nut (2 Req'd) 4 - Stud Bolt 5 - Bolt (2 Req'd) 6 - Differential Pressure Feedback EGR Sensor Bracket A - Tighten to 5-7 Nm (45-61 Lb-In) B - Tighten to 8-12 Nm (71-106 Lb-In)
    Engine Emission Control Component Location-3.4L SHO Engine
    Item Part Number Description 1 95607-05200 Nut 2 - EGR Sensor Hose 3 - EGR Sensor Hose 4 95027-08016 Bolt 5 - Differential Pressure Feedback EGR Sensor 6 9J433 Differential Pressure Feedback EGR Sensor Mounting Bracket 7 9D474 EGR Solenoid Vacuum Valve (2 Req'd) 8 A4670 Vacuum Tube Assembly 9 9424 Intake Manifold 10 9J459 EGR Vacuum Regulator Solenoid A - Tighten to 5-7 Nm (45-61 Lb-In)
Hope this helps
21helpful
2answers
Differentiate (sin x)x w.r.t. x.
Question 1: (i) Find the complex conjugate of (3+5i)/(1+2i)
(ii) Differentiate (sin x)x w.r.t. x.
(iii) Find all the seventh roots of (3+4i).
Mar 04, 2011 • Cameras
How much oil do you put into the differential?
000 DODGE TRUCKS DURANGO 5.9L 8-cyl Engine Code [Z]
Limited Slip Differential, Rear 8.25-9.25 W/ TT......GL-5* All TEMPS......75W-140
Standard Differential, Rear 8.25-9.25 W/ TT......GL-5 All TEMPS......75W-140
Limited Slip Differential, Rear 8.25-9.25 W/O TT......GL-5* All TEMPS......75W-90
Standard Differential, Rear 8.25-9.25 W/O TT......GL-5 All TEMPS......75W-90
Note:Trak-Lok axles require Mopar limited slip additive limited slip additive 04318060 or equivalent
Differential, With 7.25 RingGear Rear..........1.4 liters Fill no higher then 3/4 inch below plug hole.
Differential, With 8.25 RingGear Rear..........2.1 liters Fill no higher then 1/4 inch below plug hole.
Differential, With 9.25 RingGear Rear..........2.3 liters Fill no higher then 5/8 inch below plug hole.
Thank you for using fixya and good luck
7helpful
2answers
Fluid capacities and fluid specs
2000 TOYOTA TACOMA 2.7L 4-cyl Engine Code 3RZ-FE
Engine Oil Grade 1......API* All TEMPS......5W-30 Optional ..10W-30
Engine, 2WD, with filter..........5.5 liters
Engine, 4WD, with filter..........5.4 liters
Manual Transmission,......GL-5/ GL-4 All TEMPS......75W-90
Automatic Transmission,A340E......AF3 / A43D......AF3
Differential, Front/ Rear W/ ADRD......GL-5 ALL TEMPS......75W-90
Differential, Front Less ADRD......GL-5 ALL TEMPS......80W-90
Transfer Case,......GL-4/GL-5 ALL TEMPS......75W-90 Gear oil.
Capacity:
Cooling System, Initial Fill..........8.5 liters
Automatic Transmission, A340E Initial Fill..........1.6 liters
Automatic Transmission, A340F Initial Fill..........2 liters
Automatic Transmission, A43D Initial Fill..........2.4 liters
4 speed A340E..........7.2 liters
4 speed A340F..........10.1 liters
4 speed A43D..........6.5 liters
Manual Transmission, ..........2.5 liters
Differential, With ADRD Front..........1.2 liters
Differential, Without ADRD Front..........1.1 liters
Differential, 2WD V6 Rear..........2.6 liters
Differential, 4WD Extra Long Rear..........2.5 liters
Differential, Short WB With LSD Rear..........2.7 liters
Differential, Short WB Without LS Rear..........2.6 liters
Transfer Case, Electronic..........1.2 liters
Transfer Case, STD..........1 liters
6helpful
2004 gmc sierra rear differential
remove cover.take off back wheels and calipers (or drums).turn differential to where you see small bolt/pin (5/16) horizontally (same direction as axles)on right side of differential.remove bolt/pin.A large pin (about 5"long 3/4"diameter) should slide out differential with ease ( you may have to tap one side of the large pin).turn differential to completely remove large pin.turn differential so you can see in the view window.push each axles in (they'll go in about 1 1/2"each) You may hear one of the axle C-clips fall.If not use a small telescoping magnet to remove the C-clips from the axles through the differential window.pull each axle out about 10"so they are out of the diff.Now remove the cap bolts(4-5/8"bolts) and remove the caps(mark the caps so they go in excactly the way they came out.be careful the diff might fall out.If not you may have to use a long bar or 2x4 to wedge and pry the differential out. Have a basket/crate w/rags in it to catch the diff.TIP:If you are removing the ring gear from the diff, the bolts are left handed bolts meaning you have to turn them clockwise to loosen and counter clockwise to tighten ; )
3helpful
2answers
Where do i put the differential gear oil
  1. Before changing or inspecting oil, be sure to stop engine and lift vehicle horizontally.
  2. With vehicle lifted up, check leakage. If leakage exists, correct it. NOTE: Whenever vehicle is hoisted for any other service work than oil change, also be sure to check for oil leakage.
  3. Remove oil filler plug (2).
  4. Remove drain plug (1), and drain old oil.
  5. Apply sealant to thread of drain plug (1), and tighten it to specified torque.Tightening torque Differential oil drain plug a: 23 Nm (2.3 kg-m, 17.0 ft. lbs.)
  6. Pour new specified oil until oil level reaches bottom of oil filler plug hole (3) as shown in figure. NOTE:
    • Hypoid gear oil must be used for differential.
    • It is highly recommended to use API GL-5 80W-90 gear oil.
Differential oil specification: API GL-5 (For SAE classification, refer to viscosity chart [A] in figure.)
Differential oil capacity (Reference): 0.9 - 1.1 liters (1.9/1.6 - 2.3/1.9 US/Imp. pt.)
  1. Apply sealant to thread of level / filler plug, and then tighten it to specified torque. A: Sealant 99000-31260SUZUKI Bond No.1217G Tightening torque Differential oil level / filler plug b: 23 Nm (2.3 kg-m, 17.0 ft. lbs.)
8helpful
2answers
What;s the oil capacity for a 2002 chevy trailblazer 4.2 6 cyl?
Here are the Fluid CAPACITIES & MORE:
Engine, with filter..........4.6 quarts[1]
Cooling System, Initial Fill..........12.0 quarts
4 speed 4L60, 60E..........11.0 quarts
Manual Transmission, NV1500..........5.7 pints
Manual Transmission, NV3500..........4.2 pints
Differential, with 8.6 ring gear Rear..........4.0 pints
Differential, with 7.25 ring gear Front..........2.5 pints[2]
Differential, with 8.25 ring gear Front..........4.2 pints[2]
Differential, with 9.25 ring gear Front..........5.9 pints[2]
Differential, Front..........2.5 pints
Differential, Rear..........4.0 pints
Transfer Case,BW4472..........2.5 pints
Transfer Case,NV136/236/246..........4.0 pints
Transfer Case,NP207..........4.6 pints
Transfer Case,NP231, NP233..........2.3 pints[3]
Transfer Case,NV231/233..........2.1 pints[3]
1. After refill check oil level.
2. Do not use synthetic lubricant in axles using RTV sealant.
Synthetic lubricant will chemically atack RTV sealant.
3. Identification: check tag on case.
Change differential fluid
Loosen the lower bolts on the cover to drain the differential,remove all bolts,remove cover and clean cover, replace gasket or silicon, replace cover and tighten bolts to spec or snug + 1/4 turnrefill with proper fluid.
Top Casio Office Equipment & Supplies Experts
k24674
Arnie Burke
Arnie Burke
Ngoro
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
