Berry magicoal storage heater did not function. How should I set all controls?
2 Suggested Answers
  • 21 Answers
SOURCE: no hot water from electric shower Berry magicoal Action 850
you need to replace the element probably. you have a short which is a wire touching sometimes then it gets away
Posted on May 10, 2010
1991 f150 5.0 th red and black vacuum hoses going to the vacuum reservoir broke. Can I still drive it
yes. Plug both hoses. Typically vacuum storage is used for power brakes, A/C and heater vent control, and on some cars hideaway headlamps. Disconnecting any of these will not leave the car undriveable, but the systems involved may stop working (heater vents) or have reduced function (cars that lose power brake vacuum still stop, but no power assist so you have to push harder to stop).
Jan 03, 2018 | Ford F-150 Cars & Trucks
I moved into a flat with newlec NLSH24AN HEATER N NO INSTRUCTION. ..HELP
Hi Sharon,
This should be relatively easy.
You have storage heaters that only take in the hear during cheap rate electricity (at times you cannot change - typically between 00:00 and 07:00 but times vary - ask your electricity supplier).
The controls of an electric storage heater normally consist of two
dials to be found under a flap on the heater.
The input dial, sometimes known as the charge or overnight dial.
This control sets the amount of heat to be stored during the night.
It is best to be set on a seasonal basis: medium for
autumn/spring, high for winter.
If you find that you run out of heat before the end of the day,
and the Input is not on maximum, turn it up to store extra for the
following day.
The Output Dial sometimes known as the room temperature or boost dial.
This dial controls the amount of warm air or convected heat given out during the day. It opens and closes.
Nov 24, 2014 | Heating & Cooling
Hi, I have a Dimplex DUO500i storage heater and
Sounds like you heating coils burnt threw. how much did you pay for it? Might want to buy another.
Oct 29, 2013 | Heating & Cooling
My blower only blows threw the defrost vents. all climates everything, no matter where i put the control knob. dealership says the solenoid got stuck closed after using my 4 wheel drive.
Assuming you have vacuum controls at the heater control head, you have a classic vacuum leak in the hose from the engine intake manifuold to the control head, or the vaccum storage canister somewhere in the engine compartment. It is required to fail to defrost by law.
Climate Control Assembly
The climate control assembly has 3 system controls:
  • The function selector switch combines a vacuum selector valve with 2 electrical switches to supply battery positive voltage (B+) to the blower motor control circuit and the A/C clutch circuit (if equipped).
Vacuum Control Motors
The 2 vacuum control motors:
  • are actuated by vacuum from the function selector switch.
  • position the plenum doors to direct system airflow to the vehicle's interior as determined by the function selector switch setting.
The vacuum reservoir is behind the driver fender well, black plastic ball.
If you have diesel, then you will have a vacuum motor under the hood.
please rate if this helps.
Oct 05, 2011 | 2006 Ford F-250 Super Duty
Cannot get temp to raise
I would go for the sensor first. It is in the easy to afforde range and easy to install along with more sucpeteable to falure.If that dosen't help then you can still try the board.
May 28, 2010 | Jandy Aqualink Rs4 One Touch Control...
No hot water from electric shower Berry magicoal Action 850
May 10, 2010 | Home
HOW DO YOU CHANGE THE CHARACTER PITCH
You have not specified which printer you are using.
1. In a serial printer having a displaceable printing head and being selectively operative in a setting mode for setting a variable character pitch and in a normal mode for effecting a printing operation according to the set character pitch: a plurality of manually operable switches each having assigned thereto a normal function which is performed when the switch is operated when the printer is in the normal mode and having assigned thereto a setting function which is performed when the switch is operated when the printer is in the setting mode, at least one of the switches having a setting function which effects selective displacement of the printing head to one of a plurality of predetermined positions each corresponding to a different character pitch; means for producing character pitch data effective to specify a desired character pitch according to the selected position to which the printing head is selectively displaced; and storage means operative when the printer is in the setting mode for setting therein the desired character pitch data for use during a printing operation of the printer in the normal mode.
2. A serial printer according to claim 1; including controlling means for controlling the serial printer to effect changeover between the normal mode and setting mode.
3. A serial printer according to claim 2; wherein one of the switches has a setting function which enables the controlling means to set the setting mode.
4. A serial printer according to claim 3; wherein two of the switches have setting functions which effect selective displacement of the printing head in opposite directions.
5. A serial printer according to claim 3; wherein one of the switches has a setting function which enables the storage means to set therein the desired character pitch data.
Jan 28, 2010 | Electronics - Others
I have a 2000 ford E350 van with front and rear air. the front blower motor runs at low speed, The front blower still runs on low even when the knob is set on medium or high. I do not know where the...
it's either the blower motor switch or blower motor resister. Resistor ?Heater Blower Motor Switch Removal Remove the battery (10655) ; refer to Section 414-01 . Remove the battery tray. Remove the screws. Remove the battery tray. Disconnect the heater blower motor switch resistor connector. Remove the heater blower motor switch resistor (18591). Remove the two screws. Remove the heater blower motor switch resistor. ----------------------------------- Switches Removal Disconnect the battery ground cable. Remove the center trim panel; refer to Section 501-12 . Remove the control assembly. Remove the screws. Remove the control assembly. Remove the A/C-heater function selector switch knob. Disconnect the vacuum harness connector. Disconnect the A/C-heater function selector switch connector. Remove the A/C-heater function selector switch. Remove the screw. Remove the A/C-heater function selector switch. Remove the temperature control switch knob. Disconnect the temperature control switch connector. Remove the temperature control switch. Remove the screw. Remove the temperature control switch. Remove the heater blower motor switch knob. Disconnect the heater blower motor switch connector. Remove the heater blower motor switch (18578). Remove the screw. Remove the heater blower motor switch. ----------------------------
Mar 31, 2009 | 2007 Ford E-350 Super Duty Length XLT
Slimline storage heaters with no switch to turn on/off - how do you turn them on? have taken off the front panel but can see no switch/override - the electric cable comes straight from the wall into the...
The principle of electric storage heaters is that they take in electricity at night through a central time switch (normally owned by the electricity supply company and usually not controllable by the user).
There should then be a main switch/ fuse box to control the heater circiuts, check for such a box and that it is switched on (This would normally be sited near the electricity meter).
There should be an isolator switch next to each heater but from what you say this is not the case.
There should be some controls on each storage heater marked INPUT with a dial from 1 to 6 or similar then another marked OUTPUT or BOOST.
When you have ascertained the fuse box is on and the heater controls are set to maximum you then have to wait overnight for the heaters to warm up.
Oct 09, 2008 | Heating & Cooling
Early / Late boost in dimplex storage heater
The output setting if turned off isn't adjusting the temperature in the room automatically if its off,and by turning the output up is like turning up the heat.By turning the output switch on you can let the heater automatically control the heat.Still you need to monitor the adjustments to your liking and then you know how hot it will be when you come back into that room.
May 26, 2008 | Dimplex DS5603 Heater
Heating & Cooling Logo
44 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
