Question about Sigma 70-300mm f/4-5.6 DG APO Macro Lens
IN AUTO FOCUS FOCUS RING STICKS MAKES NOISE LIKE
IN AUTO FOCUS FOCUS RING STICKS MAKES NOISE LIKE GEARS SLIPING. LENS FAILS TO FOCUS. MANUAL FOCUS OK.
  • 21 Answers
How new is the lens? In or out of warranty? If out or warranty most likely solution is to find a Sigma authorized repair shop because your description sounds like the auto-focus motor gear has failed. If in warranty, check out Sigmaphoto.com for repair sites and also download the SIGMA_SERVICE_REQUEST.PDF. I've only had to deal with Sigma once on warranty matter and they were very helpful, provided UPS authorization for shipping on their nickel.
Posted on Oct 16, 2010
I own a Nikon D5000 and am experiencing issues with the 55x200 lens. When trying to take a picture (on auto mode) of an item that is too close, I am hearing a squeaky noise (like the noise made my a VCR...
The 55-200mm lens does not focus closer than 1.1 meters (3.6 feet). If the subject is too close, then the autofocus tries and fails to focus or keeps trying (and squeaking). Either way, you won't be able to take a picture. In manual focus, you can take a picture but it will be out of focus and blurry.
Every lens has a minimum focus distance, closer than which it will not focus. Some lenses focus closer than others. It's a matter of design; making lenses focus closer makes them larger, heavier, and more expensive.
If you want to take close-ups, you have several options. You can buy close-up adapters that fit onto the front of a lens. You can buy a special close-up lens ("macro" or "micro" lens). You can buy extension tubes to fit between the camera and a lens.
Jul 18, 2011 | Cameras
\my D50 is not following through when I press the shutter release on auto focus-am able to take a pic on manual. When pressed, the camera makes a whirring noise but does not finish
Your lens might have an issue caused by some sort of shock or impact. Before anything just try to gently turn the focus ring on the lens while on auto focus to see if it pops back into place. Sometimes this actually takes care of the issue. Just DON'T FORCE IT. If this doesn't solve your issue then contact a Nikon authorized service center because your lens is going to need repairs. Hope this helps!
Hiram
Photo Tech Repair Service
110 East 13th Street
New York, NY 10003
212-673-8400
Jul 07, 2011 | Nikon D50 Digital Camera with 18-55mm and...
Can you use the twist-barrell zoom lens on a Sony DSLR camera (or any DSLR) when the camera is set to auto-focus? I've been told that this damages the gears in the lens if you do. Thanks for your help.
You can zoom completely independent of the focus.
Some lenses immediately override the autofocus when it senses you turning the manual focus ring. Other lenses don't, and you can damage the lens by forcing it. It depends on the lens, so you'll have to consult the documentation for the specific lens.
Jul 06, 2011 | Sony Alpha DSLR-A200K Digital Camera
After taken photos the image out of focus
On the front of the camera body, below the lens release button you should find a two position switch labeled "AF" & "M" This is the "Auto Focus - Manual" selector switch. Make sure the selector is set to "AF" for auto focusing.
Your lens may have a similar focus selector switch on its barrel. There are two types of switches used - depending on the lens. The first is labeled "M/A" and "M" The "M/A" position indicates it is in "Auto Focus" mode with a "Manual" focus over ride capability. You can simply twist the focus ring to change the focus to a point other than that chosen by the camera's auto focus system. The "M" position is Manual Focus mode. No focusing operations will be performed by the D80 auto focus system - focusing must be done by the photographer.
The second type has "A" & "M" positions. These represent Auto and Manual focus. The difference between this type switch and the "A/M & "M" switch is that when in "A", the camera will no allow the focus to be changed manually. There will be opposition to twisting the focus ring in the position. Forcing it will likely result in damage. The selector switch must be changed to "M" to change the focus.
If either switch is set to manual, the auto focus system will be disabled, so it is very important to have them both set to "A" or "A/M".
I hope this helps. Please rate my reply - thanks!
Jan 04, 2011 | Nikon D80 Digital Camera with 18-135mm...
Makes weird noise while auto-focusing
The 18-135 lens focus system is driven by a motor in the lens itself. So there are moving parts inside it, not really gears and pinions and such, but similar. If it works fine and doesn't make the focus jumpy or stick anywhere, it's probably safe to wait a bit and see if it either goes away or gets worse. If it gets worse or the focus jumps, you just need to take the lens in and have it serviced. The mechanism could be out of alignment or need other adjustment.
Jan 09, 2010 | Nikon D80 Digital Camera with 18-135mm...
My wide zoom lens for my D200 will not auto focus..
Mine occasionally does this as well, but only when trying to focus on the left side of my viewfinder. I found there is a piece of dust on the sensor in just the right quadrant that prevents it from focusing. Try setting your focus settings so that you can press the left or right buttons to select the focusing quadrant (left, middle, or right). If that fails, you can always manually focus.
May 28, 2009 | Nikon Normal AF Nikkor 50mm f/1.8D...
Manual Focus won't work
Which camera are you using? If the body has AF/MF switch, put that also to MF.If this fails to help, take out the lens and try to change it to MF.
Feb 05, 2009 | Nikon Zoom-Nikkor 55-200mm f/4-5.6G IF-ED...
Canon 3000N Auto focus fault
No extra batteries.
Usually this is a lens fault as the focusing gear is all in the lens. Clicking sounds as if a rear pinion has cracked. It's not uncomon in the 'prosumer' level lenses where plastic gears are used a lot.
It's just possible the fault is which the auto-manual switch. This usually has a mechanical clutch coupled to it which physically disconnects the gearbox from the focusing ring, as well as operating a switch to tell the camera to turn off the AF system.
Dec 21, 2008 | Nikon F65 35mm SLR Camera
Manual Focussing failure with Canon EF 100-400mm SLR zoom lens
I doubt if there is anything you can do yourself. The manual focus may have debris under the ring or is in need of parts. I would leave this one to a tech.
Jan 22, 2008 | Cameras
Camera will not auto focus
Take the lens off and rotate the focus ring, it should turn very easily with little gear noise.Try a different AF Pentax lens that you know is good.
I'm sure the lens is binding, take the lens to a camera repair shop for an estimate cost to repair.
Dec 10, 2007 | Pentax PZ-70 QD 35mm SLR Camera
Sigma 70-300mm f/4-5.6 DG APO Macro Lens Logo
772 people viewed this question
Top Sigma Cameras Experts
Steve
Doberman
Are you a Sigma Camera Expert? Answer questions, earn points and help others
