On my potterton puma 80,the fan runs continually can you advice me please
2 Suggested Answers
rockmeister
  • 2047 Answers
SOURCE: Potterton Puma 80 Boiler When
Hello there, the firing from the burner is as a result of gathered pressure. If it is reduced then there would be no pressure from the system and this could cause the low pressure warning light to come on standby. When you also make the noise reduce by loosing the glass cover there is a probability of the pressure not stabilizing. If you visit forums about your product you will find out that the unit not firing with a loud pop indicates a problem in your unit as a lot of other people are complaining. The noise is just something you would have to live with.
Hope this support has been helpful?
Thank you for visiting FixYa.
Posted on Aug 16, 2011
How can I download an installation guide for potterton ep6002 programmer
Unfortunately unless you are trained as an installer of Potterton equipment you will not be able to get any advice from Potterton, they don't even supply direct to trade, everything is supplied through nominated suppliers, ie; Plumbers merchants.
This programmer should be quite easy to install I would have thought, in general all remote programmers have a mini wiring diagram on the back of the unit, though this will only show connections for the programmer outputs, ie heating on/off and water on/off.
If you require a wiring diagram for a complete heating system, you need to know the type of heating plan you have/are installing.
Hope this helps, if you need any more info get back to me.
I have just googled this and you can actually purchase from Amazon (not that I would do myself, I would use the merchants) there is a wiring diagram on the site. Just google Potterton EP6002, it comes up straight away Good Luck
May 23, 2014 | Garden
Install guide for ep6002 programmer
It would probably be best to contact Potterton or Baxi Potterton
at the email address: enquiries@potterton.co.uk
www.potterton.co.uk
Potterton Myson, send all enquiries to Baxi Potterton
I only found one PDF file online and it was a general book that showed how to wire most of the wire systems and controllers.
http://atibook.com/dl/en/Others/Tutrial/9780750664363_domestic_central_heating_wiring_systems_and_controls.pdf
I just moved ina flat with potterton combi 80 boiler with digital timer. can someone help and let me know how to use digital timer?
please download the owner manual and read it. go www.retrevo.com or www.manualslib.com or go to the website from the manufcture from digital timer.
God bless you
Oct 28, 2013 | Water Heaters
I have a Potterton Combi Puma 80e When I use the shower the pressure seems to drop and shower goes cold! except when the central heating is on shower works fine
Does the red status led in the centre of the control board come on when hot water is drawn? You need to remove ONLY the front decorative cover to see the control board, two fixing screws at the base of it. If not the boiler won't fire when the CH is off.
The trigger for this is a pressure switch, replacement of which is beyond DIY scope.
FYV
Feb 11, 2013 | Water Heaters
Puma 80 potterton hot water on and off
Boiler compartment ventilation will not stop you getting hot water . Its sounds like you have problems with a sensor or the water section on the boiler .
Apr 20, 2017 | Water Heaters
I have a Puma air compressor model # DD-2004v. I have replaced the piston in the compressor because I was told the one had gone bad. In order to get the new piston up in the compressor I removed the fan...
Hi cleancutc844...
Sounds to me like the fan is running in the wrong directions and not cooling the motor as intended.
Reverse your wires to to reverse the rotation of the fan motor and make sure it is pushing air over the motor to keep it cool while running.
Please take time to rate me
Sep 17, 2011 | Puma Air Tools & Compressors
Ford Puma Heating Problem
look under the dash for a big black box the fan will be in that box but first check the wires for good connections and power
Feb 15, 2010 | 2001 Ford Focus
Potterton Profile 60e doesn't start first time
could be fan speed or air pressure switch-is case seal sealing properly also check grommets under boiler for blowing.
YOU CAN ONLY WORK ON BOILER IF YOU ARE GAS SAFE REGISTERED.
Apr 04, 2009 | Water Heaters
Heating & Cooling Logo
35 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
