Question about Hotpoint WMA64 Front Load Washer
WMA62 before going away I started a wash the water came into the drum but the drum would not turn so I switched it off went away for a week. and the machine worked for two washes then stopped again. Any Ideas why
    Problem Solver:
  • 8 Answers
The brushes have probably gone sometimes it will work sometimes it wont when it does it will make a burring sound from the motor as it is trying to make a contact try shaking it while in spin it may start up then stop then you will know.
Posted on Aug 20, 2008
Why is clean water collecting in the drum of my washing machine afer a cycle?
Replace the inlet solenoids. They are where the hoses attach to at top back of machine. Dead easy replacement. Couple of screws and a tubing clamp
Nov 01, 2014 | Bosch Washing Machines
Indesit iwme12 fills with clean water when not running
sounds like a faulty valve. it maybe weeping, leaking water in.
Jun 20, 2013 | Washing Machines
Hotpoint wma62 keeps blowing the fuse in plug started week ago would go couple times then blow another fuse now when i switch on blows it straight away
I assume that you have the correct amperage fuse fitted, and that the plug and socket are o/k.
I would start by unplugging the motor lead from the motor, if it still blows, remove the leads from the heater
.If it still blows, then it could any one of a number of things.
However, there is more than a good chance, it will be the heater or motor.
If it is the motor that has caused the problem then before you do anything about it, check the control module in the top of the washer,as there is a very strong possibility that it will have blown the board, I have come across this on many occasions.
This being the case, then it is not going to be economical to repair.
Hope this helps.
Dec 02, 2009 | Washing Machines
My Electrolux washer is only 6 months old and the drum has started squeaking. What could the problem be?
NOT Solution - I just bought one last week and it squeaked for me today. Sounded like a belt. As the washer added more water to the drum to soak the clothes, the squeak went away. So not sure if belt slightly out of alignment - hence it rubs or perhaps a roller knob needs adjustment is what I am thinking.
Sep 23, 2009 | Electrolux AWF 1435 Front Load Washer
Hotpiont wma62 not washing
check the motor brushes and connections to the motor the fault is logged as motor action fault.
Jul 12, 2009 | Hotpoint WMA64 Front Load Washer
Hotpoint WMA62 door will not lock
Sounds like the door lock switch has failed,normally they go bang when fail,they start the machines cycle so are important,when door is shut it should click,this engages a timer which keeps door locked switch is live at mains potential,cant be tested have to be replaced about 12 pounds cost,best for a tech unless you feel competent
Dec 13, 2008 | Hotpoint WMA64 Front Load Washer
Drum on my wma62 won't turn
Hi.
The main drum bearigs have failed, you have to disconnect everything you can to enable you have to
remove the whole drum and container through the top of the m/c.
It is quite an involved repair, and could prove to be expensive. more so if the drum shaft is worn.
Good luck.
if you need any further info, let me know
Nov 20, 2008 | Hotpoint WMA64 Front Load Washer
Hotpoint washing m/c WMA62 - door won't open
sounds like you have a blocked pump or discharge pipe
Oct 12, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hi experts, I have a Hotpoint WMA62. In the past it suffered from the bearing problem, and today it has stopped completing the wash cycle - barely starts it infact. I don't have a warranty and wonder if I...
is this that the drum doesnt go round much or at all when turned on but lets the water in if it is then its just your carbon brushes and will only cost no more then £15 to buy them let me know
May 08, 2008 | Washing Machines
WMA62
Have you checked to see that the waste is not blocked? THis is very common on these machines and causes the pressure switch not to operate, making the machine fail to spin or spin with water in the drum, causing unbalance symptoms.
This is extremely common on Hotpoint machines without a accessible filter. The filter is in the rubber waste pipe under the drum and needs to be removed to be cleaned out. When iti s blocked it also blocks the chamber that operates the pressure switch.
Dec 09, 2006 | Hotpoint WMA64 Front Load Washer
Hotpoint WMA64 Front Load Washer Logo
119 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
