Question about Sony Playstation 3 (PS3) Console
My ps3 is not working properly - Sony Playstation 3 (PS3) Console
  • Brazen Sigilos
    Brazen Sigilos Oct 15, 2010
    Would you like to clarify that a little? What exactly is it not doing correctly?
  • 56 Answers
If ur ps3console wont working properly....then the things to check are>>> 1.check urpower cable 2.check whether u have inserted the disc properly and precisely.3.check the insertion of memory card... 4.check the video port.......
still the same problem,don worry check out thefollowing Repair Guide..... CLICKHERE
Posted on Oct 15, 2010
Why am i having problems with facebook on my PS3 when it used to work perfect weeks ago ?
Dave, the PS3 is not a great computer platform. I've never had it work "correctly" trying to connect to Face Book from the PS3.
Jul 20, 2014 | Sony Playstation 3 (PS3) Console
Why is facebook not working properly on my PS3 system when it used to weeks ago ?
I'll tell you why. As I have stated several times, the PS3 is weak as a computer, at best. It is not designed to be updated like regular PC's. FaceBook runs flash objects, and when new flash players are required to view these objects, the PS3 can't keep up! Simply because Sony will not let you update the Flash player on the PS3. Sometimes it works, most of the time, it don't. I recomend never using a PS3 for any website you might visit, including Face Book.
Trying to go to facebook from the ps3 browser wont help that much,try to do works like that on your pc.Ps3 sould had a facebook app but they only use that feature on the ps vita.Ps3 browser is slow as hell and facebook won't show normaly.
Cant hook up my ps3 to the tv ? tried all 3 input outlets and nothing tried hooking it up with a dvd player and still nothing ?
The ps3 has 2 output modes, hdmi and composite or component. For example if you started with composite and switched to hdmi the screen would show up black. The way to select the dif output is to press and hold the power button until you hear a second beep, this should put it on the proper output. Hope this helps and is the only thing I can think of if your tv is properly working.
Aug 23, 2011 | Audio Players & Recorders
No sound going to tv from console
If the audio function is not working properly on your PS3, there are several steps you can take to properly fix these problems quickly at home without sending it out to Sony and paying over $100 for repairs. Here are some simple troubleshooting steps to help you identify what may be causing your PS3 audio problems and fix them.
1) If you have no sound at all, you should check and make sure that the mute button has not been pressed on the television remote. This may sound like an obvious thing to check, but you would be surprised how often this is the cause of no sound issues with the PS3.
2) Next, make sure all your audio cables are properly connected between the TV and the PS3. A simple loose cable can cause sound issues as well.
3) Check the audio settings for your Playstation 3 and make sure they are properly set and also set correctly for the type of television you are using (HDTV versus standard).
4) Check and make sure the disc you are using is not copy protected or otherwise unsuitable for use in your PS3. Try another disc if you are unsure.
5) Make sure that you are using the correct cables to connect your TV to your Playstation 3. If you have recently changed the cables you are using, this can often be the source of the problem.
If none of these five steps work, you may still be able to fix your PS3 at home with the help of a good PS3 home repair guide
Aug 20, 2010 | Sony Playstation 3 (PS3) Console
When i turn on ps3 all i get is a blank tv screen? hooked up thru hdmi. triied another hdmi cable i know works still a blank tv screen
when you turn your ps3 on ..try holding the power button down for about 10 seconds..that shud cure your delema..if the ps3 is working properly
Nov 06, 2009 | Sony Playstation 3 (PS3) Console
Ps3 wont work on lg tv with hdmi cable
With the PS3 and the TV properly connected and both units off turn on the TV and set the input to the proper HDMI setting then press and hold the power on button on the PS3 until it beeps twice. This should resolve your issue. Please let me know how it works for you.
Feb 26, 2009 | LG 32LX5DC 32 in. LCD TV
My PS3 wont turn on properly
Your PS3 is still under warranty. Call Sony and tell them about it.
Jan 26, 2009 | Sony Playstation 3 (PS3) Console
PS3 WONT WORK SOS I NEED HELP
Well the first thing is you should check that the AV cables are properly plugged into the TV and console and that the TV is set for the proper input. If that doesn't work try to hold the power button down for a few moments, that will reset the PS3's sound/video output to the default settings.
That failing you can always try a new set of cables.
If these things fail it's possible your video card is bad, your tv's input may be not receiving a signal properly(e.g. not working) or some other flaw in the PS3 hardware.
Jan 02, 2009 | Sony Playstation 3 (PS3) Console
Ps3 wont read my disc or load my games my ps3 will load films and music but not games
You need a new KEM-400AAA which is the Blu-Ray drive itself. You can find it on ebay for around $55-$70 and find YouTube Videos on how to replace it yourself. This just recently happened to my PS3 along with my Nephews....
Dec 18, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
32 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
