Question about Panduit Easy-Mark Labeling Software (PROGEMCD)
I want free panduit easy mark labeling software can i get it
Can i export easy-mark label information into excel
On the File tab there is an Export/Import choice. Give it a try
May 14, 2014 | Panduit Easy-Mark Labeling Software...
How do I stop my printer from skipping a blank row of labels in between each row I print?
I was using LibreOffice Writer to print terminal block labels on my TDP43MY and was having all kinds of problems. (I tried EasyMark too, but had just as many problems.) The printer was constantly switching landscape and portrait modes on me. It would print 2 sets of good labels (portrait) and then the next label would be landscape. It did this no matter if I printed one page at a time or if I printed the whole document. I spent over half a day trying to get it to work, and finally succeeded - read on.
No surprise that the Panduit TDP43MY printer is really a Zebra printer. I discovered this by accident when I first got the printer. I connected it without first installing the driver and windows asked for a driver for a Zebra printer. Knowing it was a Panduit, I rejected windows offer and installed the Panduit driver. I spent a whole day trying to get it to print correctly and decided I would try windows recommendation of a Zebra driver. I did some digging and discovered it is a Zebra TLP 3842 printer. I removed the Panduit driver and installed the Zebra TLP 3842 driver. The version I have says "Windows driver for ZDesigner TLP 3842 Version 5.1.07.6290 Copyright 2016". I then used LibreOffice Writer to print my labels again. Wonder of wonders it printed with ZERO problems! Yeah for Zebra!
May 06, 2014 | Panduit TDP43MY Thermal Label Printer
When importing data from Excel 2010 spreadsheet Easy Mark says you must install Excel
If you selected an Excel spreadsheet from the Data Import dialog, you will need to select which worksheet within the spreadsheet contains the label data you wish to import. If you don't have Excel installed you'll need at least Excel Viewer as Easy Mark relies on the users system to view the worksheet.
Oct 17, 2013 | Panduit Easy-Mark Labeling Software...
Panduit printer tdp43my wont print
There are lots of possible problems here: printer broken, bad cable to computer, bad roll of ribbon, labels don't match ribbon. I was having problems getting my TDP43MY to print correctly. I ended up removing the Panduit driver for the TDP43MY and installing the Zebra driver for the TLP 3842 instead. Turns out Zebra makes this printer. The Zebra driver worked much better for me. If you think everything else is fine (printer OK, cable OK, etc.) you might try installing the Zebra driver and see if that helps.
Oct 01, 2013 | Panduit TDP43MY Thermal Label Printer
Where can I get LS7-75NL-1 label tape?
I am also looking for a tape cassette (LS7-38-1) for the LS7 label printer, and cannot find one anywhere. I called Panduit and they said the LS7 has been obsolete for several years, and they have no tape cassettes for it.
Feb 18, 2013 | Panduit LS7 THERMA TRANS Thermal Label...
How do i terminate a panuit data jack 568A configuration
I haven't used Panduit specifically, but on almost every jack (leviton, on Q, ortronics) it actually shows the color codes on the side or bottom of the jack. They are usually marked for both A and B, so make sure you go by the color code marked A. Strip your cat 5, use an impact tool to punch the colored wires into the corresponding slots on the jack.
Feb 25, 2011 | Panduit CJD5E88TIW MiniCom Cat5e Shuttered...
I just installed Easy-Mark on a vista computer. There were no problems during the install, but the program stops working when I try to open it.Is there a patch I can use to get this working on my machine?...
You can try to modify the following properties of the executable file, EasyMark.exe.
1. Use Compatibility Mode as "Windows XP SP2" to execute this program.
2. Under "Advance Properties", select the option to run this program as System Administrator.
Jul 08, 2009 | Panduit Easy-Mark Labeling Software...
Screen shows "Tools too big"
This problem can be caused by the label roll not seated completely in the connector. Reseating the label roll with the power on does not solve the problem, the printer must be off when reseating the label roll.
Jan 26, 2009 | Panduit VIPER LS6 Thermal Label Printer
Viper LS6
cable serial de pc a viper panduit LS6 o como lo puedo hacer la conexion
Mar 06, 2008 | Panduit VIPER LS6 Thermal Label Printer
Computers & Internet Logo
348 people viewed this question
Top Panduit Computers & Internet Experts
David Payne
David Payne
Are you a Panduit Computer and Internet Expert? Answer questions, earn points and help others
