We have just moved into an old house with a Baxi open fire and have no idea how to use it. Do all Baxis have boilers? How do we find the model name/number? Is there any risk in using it if the backplate is cracked?
  • Heating & Co... Master
  • 2,597 Answers
Baxi do boilers they are on the baxi potterton wed site, but they are gas would not use with the back platecracked this old fire place you may have trouble finding parts if any , try someone one that deals with woodburners of fire places , they could well be you bestline to go down or a chimney sweep
Posted on Oct 15, 2010
Boiler not running smoothly
needs tune up change filter and nozzle and check electrodes are clean with no build up and clean out chambers
Oct 10, 2016 | Heating & Cooling
My Baxi Combi 80e boiler turns the heating on randomly. With the wall thermostat turned down and even with the boil switched to hot water only the heating still fires up when unwanted.
If the thermostat wire run passes anywhere through, beside or inside any metal surfaces and the wires touch any of the metal its the same as if you turn the stat to on. I've seen this a few times. Easiet way to detect it, if its inside the house is at night in the dark. Look around when its doing this you may see the small spark when it goes on. Otherwise you will need to inspect the entire run from the stat to the untis, etc.
Jun 23, 2014 | Heating & Cooling
Need Manual
Try the baxi potterton wedsite you can down load manuals there or they have at tech line
Nov 24, 2012 | Heating & Cooling
I want to use my baxi bermuda gas fire just as a fire as having a combi boiler installed is it possible
yes a combi boiler has to be piped so they would cut off the pipes to your baxi and you can ues it as a gas fire only
Nov 06, 2012 | Heating & Cooling
Got a baxi bermuda 552, back boiler not working
Hi clean pilot light and change the thermocouple , you will have to remove the gasfire to get to the boiler if unsure best get a gas fitter to do this as this is not easy to explaine , simple job but you have to know what you are doing , it might be you need a service on the bbu and the gasfire then the thermocouple could be done at this time.
Feb 20, 2010 | Heating & Cooling
My boiler(baxi luna HT330) keeps going into E1 fault mode.
After you pressure system do you bleed the rads then top up again .
Jul 19, 2017 | Water Heaters
What boiler?
This is a test by FixYa Staff.
MODS - DO NOT REMOVE
Thank you!
Sep 22, 2009 | Combi Centre DX - Mango
Baxi Boiler not firing, pilot light ok
first check the pilot is alight, it sounds like it is cause you can hear the boiler click. that click is the gas vale solenoid trying to open, if there is 240-230volts at gas valve when you here the click and pilot is alight the gas valve is broken. if you test for voltage look on the gas valve and see if its 240 or 24v obviously if it 24 v check for 24 volts, let me know
Nov 11, 2008 | Combi Centre DX - Mango
Baxi Combi 80e
i need to know boiler specifics- make and model but sounds like either the air pressure switch seized or the main printed circuit board, if the boiler has an overheat thermostat please ensure that the little red button hasnt popped out because this will prvent the boiler firing up- refer to the manufacturers instructions for location of the o/heat stat
May 05, 2008 | Combi Centre DX - Mango
Heating & Cooling Logo
377 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
