Question about Lexmark X3480 All-In-One Printer
Lexmark 3480 cover open
Where can i find the protruding piece of plastic on the cover of my printer. i'm not sure where to stick the piece of paper to try to solve the cover open message. thanks.
    Novelist:
  • 85 Answers
Hi I have 30+ printers and each differs but sorry I do not have your printer. But generally you will find a corresponding female recess somewhere around where the lid closes on the main frame of the printer.
Hope it helps
Tinteiros (Ebay)
Posted on Jun 03, 2008
I have a Lexmark x2600 printer and when I stated printing many pieces went through and then jammed and won't move in either direction, the paper is really jammed in and I don't see any way to get...
Unplug the printer from the power source to turn it off. Open the printer cover to access the cartridge area. If you see the paper jam, slowly and carefully pull the paper out of the printer. Avoid tearing the paper or avoid leaving torn pieces in the printer. This will cause future paper jams in the printer.
When all is clear, re-plug the printer into the power source. Load some paper and try to print again.
Tips: Use only paper that is in good condition. Fan the paper before loading into the feeder to prevent sticking together. Use the specified media type and sizes for your model. Don't overload the feeder.
Jul 24, 2011 | Lexmark X2600 InkJet Printer
We had a paper jam and although we got the paper out it won't feed properly anymore.
Try to remove the sheets of paper from the feeder. Open the printer cover and remove the cartridges. Make sure there are no torn piece/s of paper left in the cartridge area or in the paper path. Close the cover. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, re-insert the cartridges and close the cover. Load some paper. Try to print again.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Jul 06, 2011 | Lexmark Interpret S405 Wireless All-in-One...
Lexmark 3500-4500 paper jams will not roll through
Try to open the printer cover to access the cartridge area. You should have enough space there to get a better hold of the paper jam. Carefully remove the paper. Make sure not to tear or leave any torn pieces of paper to avoid future paper jams.
Apr 25, 2011 | Lexmark X5470 All-In-One InkJet Printer
The printer (Lexmark X5340) display "cover open"
Short of slamming the cover closed there is a small tab that tells if it is open or closed. It should be located on the lower right hand corner. Once you find it just put a small piece of paper there or plastic and you should have no more problems.
Mar 30, 2011 | Lexmark Office Equipment & Supplies
Printer keeps saying it's jammed when there is no paper in it. Printer is a lexmark x7675. Which screws do i need to unscrew?
Look at the rollers and near the print cartridges that stay open when the paper isn't moving along..that compress or lift as the paper is fed. Did you overload the paper tray? sometimes that forces the tab open way deep. A flashlight and plastic fork is all you should need. If it was used alot the hear could have bent a piece of plastic but that gets into the corner cases
Here's the user's manual but not sure if it will help but screws should NOT be the issue , most all of these problems are related to plastic or residue sticking the switch open so it thinks the paper is inside...check print cartridges...could be a scrap of a piece
http://www.lexmark.com/publications/pdfs/2007/7600/v7597795_en.pdf
Mar 14, 2011 | Office Equipment & Supplies
Will not print. Error message saying Lexmark x2250 printer saying cover not closed when it is
open the cover
there is a switch that the cover has a lever to press its embedded inside the machine with a small opening above it where the cover lever inserts to press it down. chances are its broken. take a stick or piece of tightly folded paper and press it in you will see it says the printer cover is closed. See if you find the broken part and stick it back on the cover, replace the cover or simply wedge the switch in place .. any of those will fix your problem.
Jan 09, 2011 | Office Equipment & Supplies
Ink is smudging on paper
Try replacing the fuser bulb located inside the fuser roller. This is accessible from the back of the printer. Remove the plastic piece on the back, unplug the two wire connections to the fuser, remove the toner wiper on top, and then remove the fuser. On one side of the fuser, you'll have a protruded plastic piece with two screws in it. Remove that piece and you'll see one more very tiny screw on top and another regular sized screw on bottom. Remove those both and the plastic piece. Inside you'll find the fuser bulb.
Mar 17, 2009 | Lexmark T644 Laser Printer
Paper stops
Check that the rear paper sensor feeler arm is not broken. It is the little black plastic tab that sticks up in the middle of the paper path when your looking at the back of the printer with the cover open. If you can't see it, it's probably broken.
Aug 06, 2008 | Lexmark E234 Laser Printer
My printer keeps saying Cover Open and won't let me do anything else
Hi All printers have a protruding piece of plastic on the cover / lid, when out of place it tells the printer the cover is open
When you close lid it is inserted into main frame which tells the printer that the lid is closed.
Look for this it may be damaged. If so roll a small piece of paper and insert ito the recepticle hole.
It will trick printer that the lid is now closed.
You will need to remove it each time you need to change inks etc...
Good Luck!
Tinteiros (Ebay)
Jun 02, 2008 | Lexmark Office Equipment & Supplies
Lexmark X3480 All-In-One Printer Logo
53 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
