Question about Garden
Viking ride on mower slow in forward motion and a little faster in reverse
  • 33 Answers
SOURCE: husqvarna yth1842xp 2005 ride on mower won't move in gear
your linkage came apart from the way it sounds. most all these riding lawn mowers are simple machines. you need to fallow the(flopppy lever) and see where it go's it is supposed to attach to a rod or cable and must have came unhooked
Posted on May 02, 2009
youcandoit2
  • 11 Answers
SOURCE: I HAVE HUSQVARNA 1548 RIDING MOWER HYDROSTATIC
You may have a drive belt that is worn or broken. Check the drive belt for slack condition see if it is not slipped off idler pully wheels or the belt tensioner. I had one that was streched out and was very slack on the pully wheels - I had it replaced with new one and was fine to go. There is a device on the back of your tractor to release the transaxle for manual pushing your tractor about with out starting the engine. Make sure the device is positioned correctly for running mode (engine) - There is a symbol on the back to help you know what to do. The tractor manual has good trouble shooting info and if you don't have one, try googling for it with the model number of your tractor - you will be able to download one free to your computer for viewing it.
Posted on Jul 17, 2009
  • 396 Answers
SOURCE: wont move forward or reverse-- transmission??
Does it have gears or a hydrostatic (automatic) transmission?
If it's a gear model, sounds like a loose drive belt.
If it's hydrostatic, it could be a belt problem or a problem inside the transmission. If it's a tranmission problem, this is not good. Many of the transmissions on riding lawn mowers are not serviceable - they are just replaced.
Posted on Oct 10, 2009
dolharoobang
SOURCE: troy bilt pony riding mower will go in reverse but
have a troy-bilt riding mower. place a gear in neutral and park it.
it dies instead idling. want to know why?
Posted on Nov 14, 2009
  • 33 Answers
SOURCE: MTD riding mower does not move forward or reverse.
this is a belt driven transmission. from the engine driven pulley going aft towards the xmission differential there is another smaller variable speed pulley, there is a long belt between these two, from the variable speed pulley there is a larger xmission pulley that sits kitty-corner to it with a belt between these two. This larger "xmission pulley" is what drives the differential and depending upon which gear you have selected, makes it go forward or reverse. Check that both belts between pulleys are on, check that pulley's hardware is completely secured (nuts tightened down) The heads of these pulley's are splined to align to the shaft(s) and if they aren't tight, they will just spin and not engage the transmission. If your battery is under the seat, remove it and you should be able to see and access the aft pulleys. If both belts are on and engaging the pulley's and the shaft is turning on the transmission pulley than you have transmission differential failure. Bet it's the belt off or pulley head loose. Good luck, hope this helps
Posted on Apr 14, 2010
Has very little power in reverse.
sounds normal to me none of that type run fast backward
Apr 22, 2015 | Husqvarna 25HP Hydrostatic 54"Cut Garden...
My mower starts easily, has NO motion forwards or reverse. s a drive belt slipping or what?
unset the brake push pedal all the way down and release it
Apr 10, 2015 | Garden
No forward/reverse motion
This sounds like you have a bad bearing in one of the blade hubs or idler pulleys. Check by turning each pulley by hand and see if it turns easily. Go around all the pulleys and blade hubs(where the blades mount) and check for ruff spots while turning, and that they all turn freely. Do this without the blade engaged, this will allow them to turn somewhat freely.
Apr 22, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
John deere sabre 2354 hv moves slow forward, even slower in reverse
this hydrostat drive tractor is designed to max at 5.5 mph forward, 2.5 in reverse, check linkage at pedal if you dont think your achieving those speeds
Mar 23, 2013 | John Deere 420,1020,2010,2020,2510,2520...
Reverse has got real slow, forward is slowing down to.
yea i know i did the trick i bought 2554 huq i have a lever shift i cut the platic on the reverse tp make it longer and it go much faster. now for floor pedal need make a bracket higher on pedal should make go down further and faster too.
Jul 30, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Craftsmen 5000 Model # 917276071- manual transmission: mower will not take off normal, it will pull off at a very slow speed going forward, and a little faster in reverse. The idler pullies are fixed,...
I do not know of any tractor that has a fixed idelr pully!! The purpose of the idler pully is to take up the slack in the drive belt. What scamadic are you talking about? Is it the one on the deck? If it is that one you have the belt installed wrong. The idler pully has a large spring on it and is flat, not "v" shaped szm230
Apr 15, 2011 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Riding mower surges in forward and not reverse. It
Ok first of all is not an automatic.Its a pedal operated transmission. The motion is accomplished by tightening a belt with a moveable idler and it is only shifted with a lever to forward and reverse. The belt probabley has a burnt spot in it and it hits that spot and it feels like a surge. Replace the motion belt
Mike
Oct 19, 2009 | Garden
Will not go into gear
a hydro uses a foot pedal on the right side , you push forward to go forward or rock the pedal rearward to go in reverse - a regular transmission has a shifter usually between your legs for reverse 1st 2nd or 3rd gear - you also said the blades wont engage . are they electric ( with a switch ) or do you manually move a lever .
Oct 23, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
