Question about Sony StylePro SDM-S73/B 17" LCD Monitor
I have problems with colors on my SONY SDM S73 LCD. Many of lighter colors are not displayed at all. I tried to update a driver, chanfe resolution, nothing changed... I use WinXP SP3 with RAGE 128 PRO Ultra GL AGP (32MB)
  • 732 Answers
Tlnwiayqydee, In terms of lcd monitor age, unit is VERY OLD. Cold cathode fluorescent lamps will need to be changed for new ones. Very hard to do for consumer/user!!! Best if you trade-in for new unit. Did you even look at the "date of manufacture" on back of unit? Look here for lamp information: www.rexim.com and www.jkllamps.com and www.lcdparts.net and www.lcdrepair.us You will need to also visit YOUTUBE for video clips of units being repaired. 12fixlouie
Posted on Oct 15, 2010
No display on monitor
There are a number of possible reasons after checking what you have so far. Have you checked that the video card has not been disturbed inside the computer?.
Try starting your computer in safe mode, see link below. Just in case you have a driver problem.
http://windows.microsoft.com/en-gb/windows/start-computer-safe-mode#start-computer-safe-mode=windows-7
Dec 21, 2013 | Sony 15 Inch Tft Lcd Color Computer...
Power supply sony monitor SDM-S204
TRY WITH A OTHER MONITOR ARE THAT OKEY YOUR MONITOR ARE PROBERLY BROOKEN.
ARE THE OTHER MONITOR ALSO BLACK YOUR VIDEOCARD ARE PROBERLY BROOKEN.
ALL CABELS SHOULD ALLWAYS BE SEATED TIGHT.
Jun 07, 2013 | Sony Sdm-s204 20.1" Tft Lcd Color Desktop...
Hey, i have this sony tft lcd color computer display (SDM-HS 75). It was working fine earlier. I shifted to a new place and reconnected the monitor with the system. But now while booting and error message...
It is telling you that the PC videocard resolution is too high, when you boot up insfae mode, the resolution is lower. Does it do the same when attched to another PC? You should set the resolution to the native resolution of the monitor.
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Mar 22, 2011 | Sony SDM-HS75/B 17" LCD Monitor
No picture Display when turned on lots of Colour lines, could this be the inverter board problem. the model is Sony TFT LCD Color Computer Display SDM-X72 Serial Number 4530624 Manufactured April...
This is not an inverter problem. The inverter only powers the fluorescent lamps in the back of the LCD panel.
It is probably a fault in the LCD data decoder circuit or a failing connector between the decoder circuit board and the glass LCD panel. If you took it in to a shop, they would probably charge you a full hour's labor minimum - compare that with the price of a new LCD monitor.
Dec 14, 2010 | Sony SDM-HS73P 17" LCD Monitor
My SOny SDM-S204 has no green in the computer display however, the monitor menu window is the correct color
Hello amellows, hi, check the video cable for loose connection, tighten the vga plug screw, try to wiggle the vga plug and see if there are changes on the display. As for the monitor menu, this is usually not affected, the colors are built in its onboard memory.
Mar 31, 2010 | Sony SDM-S204 (Black) 20.1" LCD Monitor
Colors are off on various web pages--red links are blue--pictures and game screens are okay though --Windows XP Pro--TFT LCD Color Computer Display
install the drivers of display new if persist then insert AGP card in AGP slot of grade 8X because that is not problem inbuilt display card does not support games and movie
Mar 05, 2010 | Sony SDM-HX73 17" Flat Panel LCD Monitor
My Sony SDM-HS73 color is way too green. Happened after electrical power loss due to storm. Possible power surge damage??????????????
the only thing you can do is look at the monitor settings on the monitor itself and in display properties. Try to adjust it there. Also double check the connections on both the pc and the monitor (loose burnt ect...) otherwise toss it
Dec 13, 2009 | Sony SDM-HS73P 17" LCD Monitor
Sony sdm s73 screen black - green light flashing - no amber light
1. If under warranty, take it to the service center immdtly.
2. The display cable might be loose plug it up.
3. Your system might not be giving signal to the display unit. Is the system running, Listen for a beep when u turn on the system. If there is a beep the System Ok for display or the problem might lies in the Tower itself.
Jan 14, 2008 | Sony SDM-S73/B Monitor
Out of focus/fuzzy
Your screen refresh rate may be too high for the monitor or one of the parts might be incompatible with windows try lowering your screen refresh rate. Or checking windows for a compatible driver for the chip or monitor.
Feb 09, 2007 | Sony DELUXEPRO SDM-X82 18.1" LCD Monitor
LCD Monitor should display 1280 by 1024, but only 640 by 480 and 16 colors avlbl. in control panel/display/settings. i've tried everything imaginable-virus removal,reinstalling drivers, (there is no...
You should try to update the driver for the display adapter, not the monitor. right click my computer>hardware tab>device manager if anything, that should be it. You like staying with win 98?
Jun 09, 2006 | Sony SDM-HS75/B 17" LCD Monitor
Sony StylePro SDM-S73/B 17" LCD Monitor Logo
239 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
