Hi I have a systor Printmaster Plus printer, It seems to have gone weird on me It prints on the disk but is 5mm short to the left on disk I have adjusted the alignment but to no good Im trearing my hair out ( what little I have left ) can you please help me if you have heard of this before Many thanks Paul
SOURCE: Ink cartridge alignment problem
well, what i did, and it seemed to work, in the short run anyway. i took and threw my hp in the back of a waste management truck,  then i called amazon.com and i ordered a new epson printer,
Posted on Aug 18, 2008
SOURCE: A960 printer
I HAVE A DELL A960 PRINTER AND I REPLACED NEW BLACK CARTRIDGE BUT I KEEP GETTING THE MESSAGE " CARTRIDGE ERROR 50 ".
I DISCONNECTED AND RECONNECTED THE POWER BUT NO LUCK.
DO I NEED TO REPLACE THE COLOR CARTRIDGE TOO, SINCE IT IS EMPTY.
PLEASE ADVISE.
THANKS.
Posted on Sep 19, 2008
SOURCE: Printer keeps showing : Press
PRESS SET UP & OPTIONS AT THE SAME TIME. WILL CLEAR MESSAGE.
Posted on Oct 22, 2008
SOURCE: My printer display keep showing " Warning, Ribbon in", cannot print multiple label at a time
i have the same problem , but my printer is ZEBRA S4M ZPL
my solution is:
in your barcode software: change printer settings: 1 and 2
1 . in media setting : change media type --> Thermal transfer
2. in documents options , configuration --> use printer settings
by Lin Yu Hsien
Posted on Dec 10, 2008
bartech9
  • 155 Answers
SOURCE: HOW TO PRINT LABELS IN DATAMAX PRODIGY PLUS PRINTER USING VB.NET
Tu necesitas utilizar comandos DPL. Pero si vas a utilizar graficos o windows true type fonts, tu necesitas un cartucho de memoria ram o flash. You need to use DPL commands. But if you use graphics or windows true type fonts, you need a RAM or flash cartridge.
Posted on Jun 10, 2009
Systor printmaster plus
First thought is the ink supply is low or cartridge is bad
Apr 26, 2014 | HP Computers & Internet
Prints a line top and left
You may have to do a clean and wick on the cartridges. Please Follow the Below Steps:
Take 2 Paper Towels one should be Damped with Luke Warm Water and the other one should be Dry.
Take the Cartridges out of the Printer and on the bottom of the cartridges where you have the ink coming out of place the Damped Paper Towel on It and Remove it, Do the Same Procedure thrice.
Once thats done, Place the Dry Paper Towel in the same mentioned way. Try to Print.
Good Luck!!!!!!!
Feb 15, 2012 | Epson Stylus Photo R300 InkJet Printer
I have Printmaster gold. It will not use the
You need to enter the printer properties in your control panel and turn on the duplex feature. In properties you select paper size, orientation, print quality, and also duplex printing.
Apr 20, 2010 | Office Equipment & Supplies
Double-sided wizard & instructions keep printing
we have printmaster 12. I vaguely recall it had problems with WinXHome multi user. It seems like the application was developed years ago. We had the same problem double sided with our color laser, never seemed to have this problem with our old inkje, but I'm guessing it doesn't like to re-do the settings. So I just printed the outside-only, flipped the paper over, and printed the inside-only. Just a few more clicks then the old method. Hope this helps.
Feb 09, 2010 | The Learning Company PrintMaster Platinum...
What is compatible with Printmaster 10?
  • 133 MHz or faster Pentium processor
  • Microsoft Windows 95, 98, NT 4.0, or 2000
  • 32 MB RAM
  • 164 MB hard disk space
  • 4x CD-ROM drive
  • 16-bit color with 800 x 600 display
  • Windows-compatible sound card and speakers
  • Works with most popular printers (monochrome and color) supported by Microsoft Windows
  • Internet access for online features
  • The above are the requirement for printmaster 10....Hope this will help you...
    Nov 13, 2009 | Broderbund Print Master Silver 16.0 for PC
    I have the new Printmaster 18 and it will not work with my printer. I tryed to print a simple document and it took 3 minutes to accomplish the printing. I also have Printmaster 15 still in the computer...
    How do you do. For decision of your problem advise you to change adjusting the printer. There is adjusting the seal In characteristic of the printer. You it is necessary to install seal the text.Thank you for question.
    Sep 11, 2009 | Computers & Internet
    Printing Envelopes
    There is a workaround for this problem by tricking the printer.
    The paper sensor, on my printer model hp4500 seems to only sense the paper at the beggining of the print job.
    What I did to trick the printer to print on odd size paper is slide the paper adjuster to 8.5 and put a regular white sheet in. Then put your odd size paper under it. When you print your document set the number of copies to 2 and print. The printer is going to sense that the paper is correct, and start the job.
    Here is the tricky part... once the first 8.5x11 sheet is almost all the way through quickly slide the paper adjuster over to match the size of your odd width paper. The printer should pick up the odd paper and print the second copy. Fool you printa! You should be able to do batches of odd paper size under the first 8.5X11. I hope this helps.
    Deny
    Jan 10, 2009 | HP OfficeJet 6210 All-In-One InkJet...
    Bad print quality
    what you need to do is run your disk and it will print off a paper that you put in your scanner and it sets the alignment. Will you please send me a copy of your disk as that is what i need. matt.griffin80@o2.co.uk
    Apr 07, 2008 | Epson Stylus DX4200 All-In-One InkJet...
    Printmaster and Windows Vista
    been running printmaster platinum 8.0 for many years on several different computers . have had it installed and running on my HPPavilion slimline for two years now . problem is that i cant get it too print anything new that i create it will print out older stuff that i have created but nothing new . have checked drivers on print they are all up to snuff , and have uninstalled and reinstalled both the printer and the printmaster program but still cant get it too print anything new that i create . it does print everything else in the PM program. and otherwheres on my computer
    Feb 09, 2008 | Broderbund PrintMaster Platinum 16
    93 people viewed this question
    k24674
