Question about Insignia 19 in. Widescreen Flat-Panel LCD HDTV
Menu Appears "on it's own"
We've had this tv for about a week.IWe have it wall mounted in a bedroom on the second floor of our house. This morning, with no one touching the remote, the menu for the input pops up on screen. It then started scrolling through the options and finally started selecting them (DVD, AV, etc). I switched the input back to TV and it did it again. This went on for about 15 minutes and then resolved itself. Is the TV on some sort of frequency that someone outside could be triggering? Another solution? Or should we be calling Ghost Hunters? hahaha. Seriously, though- what gives?
  • SpookyTV Jun 04, 2008
    And now, the volume is turning itself up to full volume. When I try turning it down, it immediately goes back up full volume whether I use the remote or the buttons on the televsion.
  • SpookyTV Jun 30, 2008
    Very Helpful, thank you!!!!
    We ended up taking the set back and getting a different model since this was our second set of issues with the same brand.
    We did try the remote soultion and the curtains were pulled (although I did notice that we have a neighbor who has a direct sight line from their family room up to our bedroom so that was possible if the window was open.)
    Again, thank you for your response. I am pretty sure something in the set was defective.
    Genius:
  • Insignia Master
  • 1,689 Answers
I have seen five types of causes for this type of fault. The fifth one is extremely unusual.
  • The uPC, and or the IR reciever and remote data amp circuits in the set went defective and started addressing functions from noise generation.
  • The control panel circuit board in the set has gone defective, and randomly addresses functions. (Sometimes people spill liquid inside while cleaning the set and damage this circuit board).
  • In the room, there are some compact fluorescent, or fluorescent lighting, and the frequencies from the lights are causing the IR addressing to malfunction.
  • The remote control itself is defective and sending commands. (Remove the batteries to test).
  • You have an unscrupulous neighbor that enjoys to annoy you, they can see your TV set in the window, and he or she is messing with it using a compatible remote! Very very rare to have this one! (Keep your curtains pulled to see if this fixes this type of fault).
Jerry G.
Posted on Jun 28, 2008
HOW TO FIX JVC LT47X788 PIC FADES OUT
Try this
Ensure that a cartridge is not inserted
Hold down the Hint (?) button while turning the unit on. Continue to hold the Hint button down until the LEAPSTER menu appears.When the LEAPSTER menu screen appears, press the A button.Touch each of the crosshairs that appear with the stylus, Restart unit
Aug 13, 2014 | JVC Silver Tilt/Tilting Wall Mount Bracket...
Can you give me some advice on, how to mount a 46in tv above my non working fireplace mantle?
You would have to use a mounting bracket specifically designed for the type of installation you describe and it certainly would have to be fastened into the studs behind the sheetrock. A TV of that size will be heavy to lift and install in the bracket
Mar 04, 2013 | Universal Bedroom Mounting Bracket For...
Samsung TV DLP
Disconnect everything from the TV so no more wires are attached to it like cable or DVD or gaming console. Unplug the TV from the wall for over 2 minutes. Then plug only the TV back into the wall with nothing plugged into it, if the TV does not stay on then you have a defective TV. You might try moving the TV to a different part of the house to a plug on a different circuit/breaker like a bedroom to verify this.
Jan 22, 2012 | Audio Players & Recorders
Took it off the wall of the camper we just bought. Would like to use it in my guest bedroom, but the stand is gone. Can you help locate one for me?
If you search on Ebay for your TV's exact model number, sometimes you can find a replacement stand for it there.
Here is a link to one example currently available for an Emerson TV:
http://cgi.ebay.com/Emerson-LC320EM8A-32-Inch-LCD-Flat-Panel-TV-BASE-STAND-/110728286130?pt=LH_DefaultDomain_0&hash=item19c7eb8fb2
Otherwise you can just buy a generic wall mount floor stand for around $100 which bolts to the TV like a wall mount, but actually sits on the floor instead of being bolted to the wall.
Here are some links to a few different models currently available on Ebay which include pictures so you can see what I mean:
http://cgi.ebay.com/PLASMA-LCD-FLAT-PANEL-MOUNT-TV-STAND-WALL-SHELF-STAND-/390330001764?pt=LH_DefaultDomain_0&hash=item5ae17b2964
http://cgi.ebay.com/Plasma-LCD-Flat-Panel-Console-Shelf-Wall-Mount-TV-Stand-/270797719452?pt=LH_DefaultDomain_0&hash=item3f0ccd479c
I hope that was helpful to you, good luck and take care.
If you choose to rate this solution by clicking on the YES THIS WAS HELPFUL icon, I thank you very much for your time and consideration.
Joe.
Aug 11, 2011 | Televison & Video
Is there a specific wall mount for this TV to swival in all directions
Acquiring wall mounts for television are according to preferences. For example, wall mounts that provide the TV dynamic directions to suit operators requirements would have separe requirements. The multidirectional wall mount provides the TV capability to swirl around several angles. Howeever, acquiring wall mounts as requirement to encamp the TV also placement on safe areas from which the device is observable is an alternative considerations. TV wall mounts provide multi purpose functionalities. For example, TV wall mounts that provide both encampment housing placement hinging to an area, and finallly capable of multidirectional functionalities available for acquisition at retails. Also possible are acquisition of customisable wall mounts to suit the type of placement area required on TV sets either suitable at various locations. For example, TV wall mounts are customsiable to house sets that require functionalities with complimentary devices like decoders, modems, DVD players, VCR recorders, or cable wiring. The process of acquiirng wall mounts is achieving interhrety of the TV set, housing available devices requiredm and achievifn viewer egonormics. Consult room device area estimate expert before acquirng wall mount to ascertain the appropiate conditions capable of providing egonomic experiences. Goodluck
Jan 08, 2011 | Televison & Video
Balancing problem Frigidaire stackable front load washer/dryer
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 21, 2009 | Kenmore 98702 Stacked Washer/Dryer
Pilot wont stay lit
A short pilot flame not playing on the thermocouple or a faulty thermocouple , loose connection at the gas where thermocouple is ,
blocked pilot flame to small , air in gas line did he purge the gas line first? other wise you will be there a long time .
Dec 16, 2008 | Dyna-Glo D-E37 Wall Mounted Panel Heater
Window or wall mount
The differance between a window and wall mounted A/C is the mounting system.
Window units are usually smaller BTU systems they set in the window, so you do not have to cut a hole in the wall to install it.
For a bedroom say 10 x 10 you can use @ 5000 btu it plugs into a standard 120 volt electric outlet. If the room is bigger then go bigger say @ 6000 btu or so. Take your room dementions with you when shopping for a unit. sometimes they have sizing on the side of the unit box.
Wall units are usually larger units. Like whole house 18,000 btu
they slide in and out of the case and use a 240 volt seperate circuit.
Best place to shop for A/C's are Home Depot, Lowes, Sams Club, B.J.'s, and Cosco they buy in large volumeusually give a Good deal I've seen 5000 btu units as low as $89.00
Just don't drop the unit out the window when installing it
From the second floor it will void your warranty. LOL
Good Luck Phil
May 19, 2008 | Frigidaire FAC124 wall/Window Air...
Insignia 19 in. Widescreen Flat-Panel LCD HDTV Logo
161 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
