Question about Canon PowerShot SD1000 Digital Camera
Lens is not working properly, some time it will gam,
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Oct 15, 2010
97 nissan maximum overheating changed thermostat and belts
have your rad flushed might have something gammed in rad check to see if you have coolent flowing proper
Oct 05, 2013 | Cars & Trucks
Sticky keys on gamming
go to keyboard settings and remove the sticky key settings
Sep 15, 2013 | Sony VAIO Computers & Internet
My xbox reads dvd but i canot play gams
Hi, When I had that happen I found banging on the top of the console, when the console is horizontal, would get it to read games since it tends to be a problem with the laser although that will stop working over time. In that case it's best to get a new xbox.
Jun 18, 2011 | Microsoft Xbox 360 Console
What is the prescribed maintenance for lens cleaning and how do i perform this? should i buy a lens cleaner? the player works fine, just wondering about future use.
Hi Tiernos,
  • Timely cleaning your lens assures you long life of your DVD/Bluray Drive Lens .
  • When you keep cleaning your lens at specific intervals , for e.g. One week , Twice a month etc..It should assure you that your lens is in proper clean state which is a prerequisite for a lens to work properly without any distortions in reading.
  • As far as future use is concerned you would be very happy to have a clean working DVD / Blu ray player because of proper maintenance as lens cleaner will avoid the accumulation of dirt on the lens which eventually leads to the non working of the player.
  • There are many people who avoid lens cleaning and have to suffer the consequences , in many instances the lens needs to be replaced which sometimes in not affordable and therefore they have to get a new player.
  • It's always better to be safe than sorry.
Please find the below link for an example of a blu ray lens cleaner.
http://amzn.to/kYp7yh
Hope this helps ...:)
May 25, 2011 | Denon DVD-1800BD Blu-Ray Player
It does not read cd's or dvd's when inserted in the tray?
Hi..
this may caused by
  • Dirty Lens
  • Faulty Internal Mechanisms
  • Corrupted Data transfer
  • Dirty Lens- Your Drive's Lens may have become dirty and you need to clean the lens.It is usual that the lens become dirty time to time. You can clean the lens by the cleaning Disc which can be purchased separately from a nearby computer shop.
  • Faulty Internal Mechanisms - all internal movements are powered by a small electrical motors and belts. If any of these are not working as it would, then Drive may not work as expected. You may need a expert hands to clear this problem.
  • Corrupted Data Transfer - If all the internal parts are working properly but data cable is not connected properly, then too drive may not read any discs. you can reconnect the cables.
Mar 23, 2011 | Pioneer DVR-107D DVD±RW Burner
When turning on my xbox 360, it will not load any games automatically. it says open tray, i open and close tray several times for it to finally load the game so I can play. Also at times when gam does...
This is a problem occurring in all the xbox 360 consoles....... this is mainly because of the poor quality of the disc,.....as a result it leads to the damage of ur xbox lens..............use good original discs........the heating effect is due to the long usage of pirated discs ...
check your lens if its working good then better download this Repair Guide for further information .........
all the best.......
Dec 07, 2010 | Microsoft Xbox 360 Hard Drive (120GB)
Zoom error
It sounds as though your lens is sticking while trying to extend. Check the lens to see if it binds. Also look at the retracted lens and see if the center portion is properly centered or is cocked to one side and out of alignment.
Once your camera is working properly, as you say it does at times, hold the camera with the lens pointed downward and run the zoom in and out several times to see if there is dirt caught between the lens cylinders. Sometimes that will work any debris out.
May 20, 2010 | Fuji FinePix S2000hd Digital Camera
Humming sound and gmes disc got scratch
this cause of strip wire connected to the lens,
1.u can change the wire( or)
2.hold or bend the wire in opposite direction so that it doesn't peek up, more curve it will touch the dvd when it play and scratches
happy gamming
May 20, 2010 | Sony PlayStation 2 (PS2) Console
AZUS M2N68-AM is good for graphic and gaming?
Yes this board can be a solid gamming platform depending on how you plan to set it up. This is a uATX form factor, with onboard video graphics. You may be able to play older less video intensive games such as Diablo II or maybe even World of Warcraft with this board as is. However I would not recommend it this way for gamming.
With a mid range PCI Express video card you could play most of todays popular video games at medium settings. ($75.00 to 150.00) With a higher end PCI Express video card this board could be a very good gamming platform. ($150.00 to $300.00)
Jan 06, 2009 | ASUS P5S800-VM Motherboard
Canon 30D
Is the lens a Canon EF or EF-S lens? Have you used it before on this particular camera body? Did you do anything else (change memory cards, etc.) at the same time you changed the lens?
Try taking off the lens and cleaning the electrical (metal) contacts on both the lens and the body with a small dust-free cloth or pencil eraser. If that doesn't help, switch in the lens you were using before. If it works with the original lens, there may be an electrical problem with the other one. If it no longer works with the original lens, you may need to have it serviced.
Feb 08, 2008 | Canon EOS 30D Digital Camera with 18-55mm...
Canon PowerShot SD1000 Digital Camera Logo
15 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
