Question about Gaggenau EB294/295 Electric Double Oven
OVEN DOOR WILL NOT UNLOCK. HOW DO I GET IT TO OPEN.
Where is the start key Gaggenau Oven EB825/10
Posted on May 27, 2011
Door lock is on but door is not shut, how do I get it unlocked so door can go shut
Unplug the oven for 5 minutes and see if the lock resets.
Nov 22, 2016 | Ovens
Why is oven door locked and won't open?
Troubleshooting a GE Oven That Can Not Get Out of Locked ...
motherhood.modernmom.com > Around the House > Home Appliances
Self-cleaning GE ovens have a locking oven door as a safety feature. ... How to Troubleshoot a GE Artica Profile Refrigerator That Won't Get Cold ... Allow the oven to cool down if there is food inside the oven, and unlock the door once the ...
Oven won't open!!! [Archive] - Chronicle Forums
www.chronofhorse.com > ... > Off Topic
The Chronicle of the Horse
Dec 25, 2010 - 100+ posts - ‎100+ authors
Different ovens unlock at different times, some are by temp and some are ..... -cooktops/19645-ge-oven-door-wont-unlock-after-self-clean.html)
Dec 30, 2015 | GE Ovens
Oven door won't open after cleaning
The oven shut down before self cleaning completed without a model # this is what I can tell you the TOD thermal overload fuse opened cannot be reset if you have no display then the thermal cavity fuse opened buy a set of feeler gauges from the auto store take one go to top of door in the middle between between door and body push to left door should open.
Sep 24, 2014 | Whirlpool Ovens
My oven is saying unlock door after self cleaning but the door is open
It's likely that the door switch has failed, or stuck in the depressed position from grease or your oven cleaner spray solution. To correct this problem, remove the door switch and inspect with a multimeter for continuity connection.
Dec 22, 2013 | Ovens
How to unlock the hinge on an Ariston Oven Door with door off
To Unlock the hinge on an Ariston Oven Door
Lay the oven door flat on the worktop with the inner door upwards and the locked hinge facing you.
With a pair of pliers and a good grip on the hinge, force the locked hinge towards you (by pulling it open towards you) and keep it in position by flipping the U piece over.
Fitting the Oven Door
Fit the door to the oven with the metal receivers in the slots on the oven.
Once the receivers are in the slot, fully open the door (in a downward position).
Flip the U shaped pieces over to lock the hinges.
May 17, 2010 | Ovens
I cannot unlock my door after self cleaning, it has been several days i pushed the 9 and unlock key but it will not open.
Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
or
Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
If these procedures fail to correct the condition, the lock must usually be accessed and moved manually to open the door.
Some model ovens require the oven door to be manually unlatched before the controls are returned to the OFF position or else the door may not be able to be unlocked. Check the owner's manual for proper operating procedures.
Feb 23, 2010 | GE Profile JT952 Electric Double Oven
Lock would not open after cleaning process has been canceled, oven is still hot
Don't open or try to open the oven door, until it has cooled down completely. The oven heats to a very hot temperature, usually 800 to 900 degrees. The door locks itself once it gets to a certain temperature, and will not allow the door to be opened until it cools below a certain temperature. On some units, this can take hours to cool down enough to unlock. If you try to force it before the cooldown is complete, it usually results in a repair call. If it still will not unlock when it is cool, turn your power to the oven off for 20 minutes, then turn on and reset your oven controls. Sometimes you have to put the oven back into the self-cleaning cycle, and then cancel it immediately to cycle the oven door lock. If it still won't unlock, call a repair company out to service this. Good Luck, Appliance Specialists
Jan 19, 2010 | Ovens
I cant get my self cleaning oven to unlock... what do I do, I cant find my manual
or
Oct 10, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
I CAN'T UNLOCK MY OVEN DOOR!
First get rid of the noise by turnining off te breaker.
You will have to pry the lock open.
This is common I use a small screwdriver and coathanger wire,then pull out oven enouhg to replace lock.
Mar 12, 2009 | Ovens
Gaggenau EB294/295 Electric Double Oven Logo
518 people viewed this question
Top Gaggenau Ovens Experts
Dennis Boxerman
Jaime Hernandez
Oloyede Monsuru
Are you a Gaggenau Oven Expert? Answer questions, earn points and help others
