Question about Garden
I have a Challenge GBV180 Garden Blower Vacuum. I can only get it to blow ..does this model vacuum and if so how do the bits attach ?
  • 13 Answers
Remove the blower tube by turning anticlockwise. remove cover from air inlet same way. attach large diameter suction tube to air inlet (has to fit correctly as this is where the safety switch is) attach collection bag to air exhaust opening (where you removed the blower tube from)
Posted on Feb 28, 2011
To vacuum. (1). take off black cover with string on 'anti-clockwise' & lever up, screwdriver is good. (2). Put big tube in the same place, turn 'clockwise', make sure it's in good or it won't start.
(3). Put small tube with bag attached and twist 'clockwise' put shoulder ******** and 'GO'.
Small twigs can be picked up as well as leaves, the machine breaks them up.
To blow. (1) Take Big tube (vac) off and replace cover with string on.
(2). Take off tube and shoulder bag. (3). Place small tube (with crevice like tool on one end)
in the same place shoulder bag fitting goes.
Start machine you're ready to blow.
Posted on Nov 06, 2012
Who sells a Defond CYCM-1213-A rotary switch for a Toro Garden Blower/ Vacuum
Ebay has listing for Defond switches. Don't know if they carry that specific model number.
May 29, 2015 | Toro Garden
I'm trying to blow up a pool with my kirby. i forgotten how to use it. can you instruct me
The vacuum is designed to be an upright vacuum or a hand held canister vacuum, or a blower.
It comes with many attachments.
Please use the blower attachment.
Jul 04, 2011 | Kirby Ultimate G Bagged Upright Vacuum
Where do I attach the bag for the vacuum?
When the machine is converted to vacuum mode, the collection bag will go on the machine where the blower tube (long part) is connected for blowing mode.
Mar 19, 2011 | Black & Decker Leaf Hog 12-AMP Electric...
How do we activate the blowing system on the blower/vacuum? It is set for vacuum and we don't know how to switch to blower?
I presume this is a gas blower. When you start the unit it will be sucking from one end/area of the blower. See where the air is discharging from the other end. That is where you will attach your blower nozzle.
If you can get the model number off the machine, there is a good chance you can go to sears online site and find a manual to help you out.
Good Luck.
Oct 29, 2009 | Craftsman 4 Cycle Blower/Vac
Turning the vacuum on.. paramount pb350
That blower vacuum is very easy to operate if you have all the pieces. You need the tubes to blow, you need the larger tub to vacuum and if you want also a bag to attach to the bigger tube. The bigger tube has to be attached at the opposite part of the machine and once you turn it on it will vacuum.
Apr 08, 2009 | Garden
Where do I connect the hose and it's attachments
You need the suction/blower connector on the hose:
This must be for G4 or G3 model as later models had this part a bit different.
For rest of the attachment go HERE.
I can sell you used FULL G4 attachment set for 99.00
Good Luck,
Rocky
Apr 05, 2009 | Kirby G4 Bagged Upright Vacuum
Vacuum works, but blower doesn't
Make sure that the vacum houseing on blower is closed all the way and/or snaps shuts to engage for blowing once you have removed all vacum attachments.
Mar 16, 2009 | Toro Super Blower Vac
Craftsman leaf blower/vacuum
There is a round grille on the bottom of the unit. Insert a flat blade screwdriver into the latch to release it and reveal the vacuum opening. You should have a two-piece intake pipe that will attach to the opening.
The collection bag attaches to the smaller outlet where the blower pipe used to be (unscrew the wing nut to release the blower pipe). The bag clips onto the hooks at the base of the opening.
Nov 11, 2008 | Craftsman 4 Cycle Blower/Vac
The leaf hog BV4000
Put the switch in the center off position. That allows you to press the big black button in the front and take the vacuum attachment off. Replace the vacuum with the blower attachment and you should them be able to blow rather than vacuum.
Oct 25, 2008 | Black & Decker Leaf Hog 12-AMP Electric...
Vacuum or Blower?
* Blowers perform the single, simple function of blowing material. * Blower/vacuum combinations combine the blower function with a vacuum feature. Leaves or debris can be directed into an attached bag, which makes this type of unit great for vacuuming leaves from shrubs. An additional mulching feature is available on some leaf blower/vacuums. Mulched lawn debris can be used in compost piles or bagged for disposal. Most convert easily from blowing to vacuuming mode.
Aug 27, 2008 | Toro Lawn Mower With Toro Power Tools
Garden Logo
713 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
