Wharfedale pro BX1360SD powered mixer intermittent fault - preamp section OK, no output from power amp (false overtemp detection? shutting down power amp??) please supply advice, circuit diagram,schematic if possible thanks, Dennis Ruff
Wharfedale pro bx1360sd
I have had problems with this stereo mixer amplifier which had the symptoms of no sound output from either channel .
I opened up the unit and discovered that the amplifier was correctly amplifying my input signal up to a relay which switches the output through to the speakers .
This relay did not activate at all.
When the power switch is turned ON you should hear a click approximately 2 seconds later , if no click then there is a problem with the circuitry associated with this relay .
I traced out all the connections associated with this relay and made a circuit diagram .
The relay is a 24v relay and I will explain the way that I can see that this section of the amplifier works.
It has been designed to ;
  1. Create a slow start delay ( 2 seconds ) when the power is turned ON.
This it needed because otherwise there is a current surge and sparks from the relay turning on immediately.
  1. Thermal cutout mounted on heatsink . If the ventilation fan fails the heatsink and transistors may get too hot and the cutout will operate and cut power to the relay by going open circuit.
  2. Speaker protection from blown output transistors. There are 2 transistors q802 and q803 both 2sc1815. They are connected together emitter to emitter and collector to collector to form a differential Op amplifier I.C. If there is a blown output transistor then DC voltage will be detected by q802 and q803 and the relay will be switched OFF to protect the speakers .
Q804 turns On Q805 which turns On Q806 to activate the relay .
Voltages on transistors
Q802 and Q803 2sc1815
Base 0V Collector 12.9V Emitter 0V
Q804 2sa1015
Base 12.9V Collector 0V Emitter 15.1V
Q805 2sc1815 (driver for Q806)
Base 0V Collector 7.2V Emitter 0V
Q806 2sc1815
Base 0V at Turn ON then after 2 secs increases to 0.7V
Collector 2.8V ( transistor is activated as a switch Turned Fully ON ( saturated) to turn on the Load which is the relay .
Emitter 0V
I have replaced the following transistors to fix my amplifier q805 2sc1815 and q806 2sc1815 .If you are going to use a different type of transistor it may not work and also the lead connections of a 2sc1815 for the collector and emitter are different to those such as on a 2n2222( transposed).
Posted on Aug 29, 2014
  • andrew zitterschlager
    andrew zitterschlager Dec 09, 2014
    I have made a hand drawn circuit of the section that I described below .
    If anyone would like a copy of it then please contact me at email azitters63@gmail.com
    I have made a hand drawn schematic of the section I described below .
    If anyone would like a copy then contact me at email azitters63@gmail.com
SOURCE: Amp powers off after switching on
the last click you hear before the amp turns on is the power relays for the amp circuit,these have 2 very small copper contacts inside them which after much time get corroded and cause high resistance when they try to power up the amplifier circuit.awkward to get to and desolder but can be opened up and serviced,done mine and a few friends with yamaha amps which use similar system,had no problem since,also worth checking for dry joints around amp chip i.c legs onto main board.
Posted on May 02, 2008
  • 336 Answers
SOURCE: Denon AVR -1604 Powers off after 3 seconds
Check in the amp section for a short on the output transistors. It may need a resistor or two also. I doubt that it would be in the power supply.
Posted on Jan 31, 2009
  • 27 Answers
SOURCE: Noisy left hand power output stage. Noisy transistor? No circuit diagram.
If the speaker is not blown, there must be an output capacitor. If no output capacitor, and you have a blown transistor the speaker will blow from DC current. You can further check the transistors with a multimeter. A transistor looks like 2 diodes and you should be abobe to test with a mulimenter like a diode test.
Posted on May 12, 2009
  • 586 Answers
SOURCE: sony str-da50es. Does not power when power button is pushed.
This problem is very common in this model the solution is to replace the fuse with improved one 10A 125V of type CES710A having part No.1-576-695-11. Remember that this fuse would be larger in size of earlier one so that you have to drill it first in the holder and adjust the fuse to a proper space of 1.4 drill bit.
Do the changes and your product work fine.
Thanks.
Posted on Nov 24, 2009
  • 4234 Answers
SOURCE: Yamaha RX-V470 Receiver Shuts Off
This unit is in the protection mode. See the link below. If you have further questions, please post them here.
Thanks,
Dan
Link: http://www.fixya.com/support/r5390728-protector_means
Posted on Aug 19, 2010
I have a Kustom KPM8420 PA mixer and the monitor channel comes through both the monitor and main speakers and vice versa. The two channels are not separate.How do I fix that?
On the back panel there is a section labelled Patch Bay
There are 2 small switches which assign each Power Amp to either Monitor or Main Output.
It would seem you have them both set the same at present. Set one to Monitor and one to Main, and use the corresponding Power Amp outputs direct to speakers.
Note you can send signal to external amps or powered speakers from the preamp outputs. This is really handy.
Download and print the manual from https://www.manualslib.com/manual/90516/Kustom-Kpm-8420t.html
and keep it with the mixer.
( Of course don't send speaker outputs to other amps or powered speakers )
Sep 11, 2017 | Kustom Music
Tip
My Pioneer displays Overload
Overload is displayed when the amp draw is excessive, and can be caused by different faults.
when Overload is detected, the protection circuit will shut down the unit to prevent further damage.
The first thing to try is hard reset. Shut down the unit for about one hour to drain power completely.
This can fix minor problems that can cause overload, for example electrostatic charge accumulation on internal capacitors.
If that does not fix the problem, then you must find the fault.
Overload can be caused by shorted speakers, wrong impedance speakers, or by a contact on speakers wiring.
Check speakers connection and test different speakers with 6, or better 8 Ohms impedance.
Another test can be done by unplugging all speakers, and reconnecting and testing them one at a time, at a very low volume.
If the speakers are OK, then preamp, shorted input/output connectors, main power supply or faulty output transistors can draw too much amps causing overloading.
In that case it is recommendable contacting Pioneer at the number listed on the owners manual.
on Jun 22, 2009 | Pioneer VSX-D608 Receiver
Accidently had peaker connect to A side while in bridge mode wud mixer be damaged
Hi, When an two channel (stereo) amplifier is connected in bridge mode the polarity of one channel is reversed, for this example say channel B. An identical (mono) signal is applied to both channel inputs.
The output is now connected between the two channel +ve outputs. As channel A's output goes +ve , channel B's output goes -ve, thus doubling the output voltage.
On this Behringer powered mixer, the bridge switch simply connects the power amp section inputs, the required way.
The bridged output is wired to the B output between pins 1+ and 2+ of the 4 pole Speakon connector. (Because usually pins 1+ and 1- are used, stereo operation is unaffected.)
So.... If you connect a speaker from the A output alone then I would expect it to work, BUT if there is already a speaker connected from the bridge output, then what happens will depend on the amplifier design.
At best the A channel will see too smaller impedance, and hopefully shutdown.
This is a Behringer, it has digital (class D) power amps, and it does Not claim any amplifier protection !!!
If the powered mixer works in normal stereo, then it is probably OK.
If it then does Not work in bridge mode it is likely to be the connector wiring.
All the best.
Apr 07, 2014 | Behringer Pmp4000 Europower 1600-watt...
Marshall MB4410, with low volume gives no real volume,
Guitar amps have preamp sections (think unpowered audio mixer) and power amp sections (Crown rack-mount amp). An excellent way to isolate audio problems if amp is still producing audio is to check the preamp out (line out). Preamp output distorted = preamp failure. Connect MP3 player to "Power Amp In"...sound distorted = power amp failure. In your case the latter is the case as your "line out" is clean. Also test each speaker for clear sound as speaker cone damage from being overpowered is fairly common. At 300w. I'll assume the failure was not from cranking the volume to loud but a shorted speaker or speaker wiring could zap the power amp in an instant.
Jan 06, 2014 | Marshall MB4410 Bass Combo Amplifier
I have a studiomaster vision 8 powered mixer the
Probably you have a missing voltage at power supply which should be +15V/-15V connected to a number of opamps in the mixer section of the circuit, NOT in the power amp section, let me know to help troubleshoot your issue.
Nov 01, 2013 | Audio Players & Recorders
NAD M3 power light turns red immediately and PROTECT message displays. Amp keeps functioning but volume control doesn't work up or down.
Hello
Check the connection to speaker with this amp, for any short or any other fault. disconnect the outputs, ie, speakers from the amp, and switch it On, and see the protect display comes or not. If it comes, the fault is internal and the set need service.
Your M3 dual Mono integrated amp, is of high output power and its outputs are protected against any overload or short circuit. If the system detect any among this condition specified above, it will show protect mode display.
Never load this amp, as protection display is there, as it may damage the speaker or its internal power amplifier section circuits, may cause more money to get it repaired. OK.
Jan 23, 2012 | NAD M3 Master Series Integrated...
I have a GK Backline 600 bass amp with an intermittent pre amp problem. Sometimes it works fine then starts distorting. One odd thing i've noticed when I shut it down, about 7 seconds later the clip light...
This is not a problem with dirty components. There is a semiconductor inside that is sensitive to heat and is failing. This unit should be taken to a service shop before complete failure. It has the potential for frying the output section depending upon the part that fails.
Please seek professional assistance with this repair.
Dan
Apr 06, 2011 | Audio Players & Recorders
Intermittant LR output problems Main outputs (XLR
Intermittent problems cn be a real pain to find... BUT I want you to verify your use of the mixer and its connections as one can cause the output drivers to latch up due to ground bounce.
Make sure your outputs go to the power amps AND into balanced inout at the amps... either XLR or TRS connectors.
Make sure that the amps are POWERED from the same receptacle as the mixer... even if you have to run power back to the mixer. If you power the mixer from a different receptacle at the other end of the room, ground bounce of the safety ground MAY exceed the common mode drive of the mixer and cause the output drivers to latch up or even be destroyed!!!
Aug 11, 2010 | Peavey 32fx USB 32 Channel Mixer
If i turn the power on , it switch off by it self and the power light flicker red
The set powers off because there is a cut off by the error amp which controls the main relay to switch off for safety from burning out any circuits. It could be failure of the output drive/ the short in the speakers or failure of the error amp section. It is tricky to find out the actual fault because you will have to keep testing by elimination, disconnect power output section, preamp section, and check if this releases the power switching.. Helpful? Good day
Jul 08, 2010 | Denon 3991095008 Rc1068 Remote...
Mute function on the amp
A couple of questions to try and narrow this down:
1) What is the impedence rating for the speakers?
2) When the unit shuts down, will it recover on its own after a little while or do you need to power cycle it to get it to work again?
3) When the unit shuts down, is it hot?
Possible causes of this behavior:
1) Impedence rating too low causing the amp to work too hard and shutdown.
2) Excessive heat (caused by #1?) will shutdown the unit to prevent damage.
3) Possible intermittant short in the speaker wires somewhere? Loose connection?
A little more investigation will be required to find this. A repair shop would run this unit under load and monitor the outputs for heat and any spikes in the signal that could kick in the protection circuits.
Keep us posted on what you find.
Dan
Jun 07, 2010 | Marantz Audio Players & Recorders
406 people viewed this question
 Grubhead
Grubhead
