Question about Daewoo DWC-056CL Air Conditioner
My unit cools until it reaches the right temperature. It won't kick back on as the temperature rises. I have to reset it at the button on the plug
  • 20 Answers
Check the fuse on the line you are plugged into. It may be too small to carry your A/C. A 15 amp breaker could be too small. Check your owners manual and it should tell you what the service amp fuse should be.
Posted on Oct 15, 2010
Once the heater reaches the set temperature at the thermostat it shuts off.the flame goes out but the pilot light stays on. the heater will not kick back on automaticaly when it gets cold however it will...
you will have to look into why the unit is tripping and needs resetting. Heaters usually have a fan delay, meaning that when the heat is satisfied, the fan continues to run for about an minute. If not, it could cause an overheating issue and trip a safety. Look for that to start with.
Aug 05, 2017 | Williams 3003622 Ceramic Wall Mounted...
Unit will not blow cold air after starting up for first time this season
That's because this unit is only designed to cool a room to approximately 75 degrees. http://www.fixya.com/support/p114531-delonghi_pinguino_pac_700t_air/manual-1811/page-2 It's not supposed to make the room cold, just comfortably cool. It automatically switches off of Cooling when it achieves this. If you want it cooler, you'll have to get a traditional air conditioner unit (like a window unit).
Sep 01, 2007 | DeLonghi Pinguino PAC-700T Air Conditioner
Ac won't blow any air
Good Morning David - Here are some simple troubleshooting tips to help resolve this issue:
If the outside temperature or inside temperature is below 60 degrees, the unit may not run.
Confirm that the unit has power to it.
Check the power cord connection to the wall outlet is secure.
Make sure that the house circuit breaker has not tripped.
Make sure the unit is turned off, Press the TEST button, you will notice a click as the BUTTON pops out. Then press the RESET button. Again, you will notice a click as the button engages, now turn unit on. If the LCDI plug does not reset the cord may be damaged.
The "Cool" circuit has an automatic 3-minute compressor time delayed start if the unit is turned off and on quickly. This prevents overheating of the compressor and possible circuit breaker tripping and the fan will continue to run during this time.
If the unit has been turned off and on rapidly or if the thermostat was changed to a lower number and then immediately turned back to a higher number the compressor may not start. You must turn the unit off and wait a minimum of 3 minutes for the unit to equalize before restarting.
I would recommend reaching out to an experienced appliance tech just to ensure no troubleshooting step has been missed. Parts are often costly and if the problem is precisely diagnosed, it can save you a lot of time and funds. I hope these troubleshooting tips help you in some small way.
Jul 09, 2013 | Frigidaire Heating & Cooling
Ge profile oven lock button won't go off
  • 1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door.
    2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle.
    3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad.
    or
  • 1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers.
    2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time.
  • 3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off.
  • 4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down.
  • 5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
  • Nov 22, 2011 | GE Profile JK915 Electric Single Oven
    We have a Delfield 407 freezer that will freeze when initially plugged in, fan running, gets nicely down to zero. After the unit gets down to temperature, the fan does not kick in again and the unit...
    You will need to replace the temperature assembly on the unit. If you can post the model number, I will be able to direct you to the parts you need. The model number will be something like "18648-BUC".
    Regards,Richard
    Nov 11, 2010 | Delfield Undercounter Freezer - 407
    When driving i have rising water temperature
    The coolant temperature should rise until the gauge indicated roughly half. if it continues to go until it reaches the red "H" shut the vehicle off and wait for the car to cool off. The most likely cause of this is the thermostat. It is a $4-$10 part and usually is easy to change. Thanks for asking!
    Jun 28, 2010 | 2000 Mitsubishi Galant
    My gas furnace keeps will run until it reaches
    Sounds like the Thermostat isn't resetting quickly enough.
    Feb 17, 2010 | Heating & Cooling
    My cooling fan does not come on when car is started.both the ac and cooling fan comes on when ac is started
    The cooling fan is required to operate when the engine temperature rises above the maximum operating temperature threshold.
    After the car is started, it will usually take some time for this temperature to be reached.
    Ensure fan runs when fan control temperature sensor switch demands.
    Oct 10, 2009 | 1997 Nissan Sentra
    Cooling fans not kicking in at high temperature.
    problam could be with your coling temperatuer sensor .make sure fuse for you raditor fan is good.and you have coolant in you raditor.
    May 20, 2009 | 2003 Audi TT
    I have a magic chef 1.7 cubic compact refrigerator, it's been great, but I had quite a bit of ice build up on the little freezer compartment. I unplugged it, and used a hair dryer to melt the ice until it...
    OK as long as you used a hair drier, and not a screw driver to defrost this machine, you should be fine, it shoudl take no more then 24-36 hours to regain the correct temp, this being said, not real comfortable with the over the internet diag of a unit that potentially "keeps people alive"
    Jan 25, 2009 | Magic Chef MCBR170 Compact Refrigerator
    Daewoo DWC-056CL Air Conditioner Logo
    60 people viewed this question
    Top Daewoo Heating & Cooling Experts
    Tim Whalen
    Craig Hill
    Dan Webster
    Dan Webster
    Are you a Daewoo Heating and Cooling Expert? Answer questions, earn points and help others
