AC make loud noise on power off.
When I power of my AC it sounds like the fan blades are hitting something. It also makes the noise when in the fan only mode but not as loud.
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
Is this a wndow unit or central air system? if this is a window unit , your problem is it only needs cleanning (dirt dbber nest-- trash around the back blades-- or the unt is twisted and rubbing the fan shroud. Last but not least, the slinger ring around the back blades (a ring around the end of the blades thats picks up water in the bottom of the unit and sling it on the coils to help cool the hot gases....Thank-you Thank you Thank you very much!
Posted on Jun 03, 2008
Why is my 1987 300e Mercedes making a loud clanging noise at start up?
I would think the honeycomb ceramic "Brick" inside the Catalytic Converter has broken up, makes a terrible rattling when this happens.
Nov 26, 2011 | 1987 Mercedes-Benz 300-Class
My air conditioner unit outside is making a very loud banging noise. It sounds almost like a small jack hammer. i noticed it this mornin and immediately turned off my system. Any ideas?
Hi!!
Have you taken a look at it???? It sounds to me like the condenser fan blades are bent or something fell in thru the grill that the blades are hitting on. If this is the case, TURN OFF POWER TO UNIT AT BREAKER BOX , remove the screws around the grill or cover
to get to the blades and fix the problem..
Don't forget to rate this post!! Good Luck!!
Jul 11, 2010 | Heating & Cooling
The fan of dell gx280 producing a loud sound, how I fix it ?
Sometimes something is stuck in the grill and the blades keep touching it, other times the bearings have worn down and the fan or entire power supply needs replacing.  I used to hit my PCs noisy fan with the palm of my hand and the loud noise stopped!
Mar 11, 2010 | Dell OptiPlex GX280 PC Desktop
Fan makes loud noise when i start car
Firstly we need to know what model etc. Noisy fan if viscus could be the viscus itself - fan blade hitting something on the shroud / housing. First check & make sure the small bolts haven't shaken lose. Good luck
Jun 01, 2009 | 2001 Cadillac DeVille
Very loud noise whirling sound
Can you tell me where the sound is coming from? Like inside freezer or under refrigerator. Most sounds like you describe come from a fan motor and the fan blades are hitting something. Let me know, Thanks, Sea Breeze
Apr 23, 2009 | Whirlpool ED5FTGX Side by Side...
Noise while in clean mode
sounds like the fan is hitting something or the blade is loose.
does it make the sound on a covection bake or speed bake?
Apr 14, 2009 | Maytag MER6772 Gemini Electric Kitchen...
RV Rooftop AC Unit
Sounds to me like your fan is hitting something
Remove the cover and turn the fan by hand ( with the power off ! ) See what it is hitting
Oct 24, 2008 | Dometic Rooftop RV Air Conditioner
Loud Buzzing Sound
Sounds like the cooling fan blades are hitting something (possible worn bearings).
Apr 21, 2008 | RCA P52926 52" Rear Projection Television
LG Fridge making intermittent sound - like something hitting fan
GAIN ACCESS TO THE FAN IN THE FREEZER(EASIER SAID THAN DONE) AND INSPECT THE FAN BLADE AND FAN SHROUD. HAVE REFRIGERATOR TURNED OFF AND MANUALLY ADVANCE FAN BLADE. WATCH FOR SLIGHT CONTACT BETWEEN THE FAN BLADE AND OTHER OBJECTS NEAR IT-ELECTRICAL WIRING, FAN SHROUD, ICE CYCLE,ETC. ADJUST FAN BLADE OR OBJECT TO INCREASE CLEARANCE.
Mar 27, 2008 | Refrigerators
Heating & Cooling Logo
439 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
