Question about Compaq Presario Notebook
From yesterday i have been getting this streak flash type of line on the bottom of my screen ....being display in every 2 secs ...green or white in color l though its not hampering the operation of the notebook but its still distracting and irritating How can I stop it? What is the problem?Please help me.. my notebook is Compaq Presario CQ40 12 months old windows 7 professional 32 bit OS Intel(R) Core (TM)2duo CPU T6500 @2.10 GHz Thank You ..
    President:
  • 1,146 Answers
Hello:
Your most likely cause to the color flash on your screen is a bad LCD panel. One way to troubleshoot this is to hook an externa monitor up to your laptop, and observe the display on the external monitor. If it is ok, then your LCD is the cause. If you still experience the flash, you could have a motherboard video problem, but unlikely.
There is no easy fix to get rid of the flashing line. If your laptop is still under warranty, or even close, I would contact HP /Compaq customer support and explain your laptop's problem.
Hope this helps !
Posted on Oct 15, 2010
I have a 70 inch Bravia XBR 70X850B which up until yesterday green/red/pink vertical line that runs across the middle of the screen.
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Nov 17, 2016 | Sony XBR Televison & Video
A horizontal band of green and red lines across the screen
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Type in the brand name to your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 17, 2015 | Panasonic TC-P46C2 - 46 Inch 720P Plasma...
Insignia ns lcd32
Check the connecting cable to display paned and its T'Con board [LVDS cable] for any loose contact with its either end sockets. Reseat it once and check. If you wish to get more details, http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by type in the model name to your set in its search box, or view it in Timeslide option.
Jul 12, 2013 | Televison & Video
Screen is all white
the display screen is faulty have an expert change it for you
Nov 07, 2009 | Computers & Internet
The display on my inspiron 6000 in jumpy at the bottom 1/3 of the screen. no evidence of any damage to case or screen. Just started with a black line and now jumps around and has white lines in the bottom....
Generally the problem is caused due bad LCD inverter cable. Kindly run the LCD diagnostics
How to Run diagnostics
1. Shut down the computer
2. Disconnect the AC adapter and Battery
3. Press the power button for 10 sec.
4. reconnect both AC adapter and battery
5. Press FN key+ power button
6. Follow the screen prompts.
If the LCD problem is shown in diagnostics your screen would have to be replaced.
Thanks for using Fixya
proton
Jul 27, 2009 | Computers & Internet
Ds lite flashes on but fuses are ok
One or both your screens have blown.
Try removing the motherboard from the screens and attach the battery the green light should turn on and stay on.
Now attach the lower screen and turn on. If the screen is ok the screen and green light will flash and then turn off. (if the screen doesn't flash the bottom screen is you're problem and will have to be replaced)
If this happens the problem is then you're top screen which you will have to replace.
Jul 26, 2009 | Nintendo DS Lite Console
Press power button green light comes on.But no picture no sound,
I have had my WS-65511 fail like this, first at 4 years, second 2 weeks later, then 3rd time yesterday (4/14/2009). In past, the tech replaced a thermal sensor p/n 299P313010A (but Mitsubishi says that part is not for WS-65511 and that it does not have a thermal sensor - go figure). It is a white rectangle with about 30 pins in 2 rows and is soldered onto a board in the TV. List price is about $25. Might be your problem.
Apr 04, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Ghosting, Flickering, Green Sparkeling Lines, Color Washout.
There is a component failure on the board inside the display. Since you did not post the model number that is all that I can tell you.
Mar 17, 2017 | LG Studioworks 700B (White) 17 in.CRT...
Blue haze around image, yellow streak
the tv color circuit is off frequency change the color ic take a look on the crystal that gives the 4.8.mhz burst could be that it needs to be replace dont rule out the video IF change the two ICs you mention.good luck.from the look of your tv screen that is my conclusion.good luck.email me at nicodhem@yahoo.com
Apr 04, 2007 | Samsung HC-P4241W 42" Rear Projection...
Compaq Presario Notebook Logo
114 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
