Question about Toshiba TEC B-572 Printer
Printer display various error codes when switched on ie ?d????.'//;
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Toshiba TEC Expert
  • 142 Answers
You have a problem with data transmission.
May be due to cable problem or centronics interface.
Check using serial cable default 9600,n,8,1
Posted on Jan 14, 2014
What does error code 168 mean?
what make and model printer is it?
Feb 14, 2016 | Office Equipment & Supplies
Canon MX922 printer displaying code C000
Try switching printer off then unplugging the power for 15 or so minutes. If that doesn't work and same error pops up when you turn printer back on, contact Canon.
good luck
Feb 28, 2015 | Canon PIXMA MX922 Wireless InkJet MFC /...
IE error code
Water inlet error - washing machine failed to fill
The fault code is displayed, if the washing machine does not detect any incoming water.
·Check wiring to water inlet valve
·Check water valve
·Check drain pump
·Check pressure switch
Check PCB
Oct 05, 2014 | Daewoo DWDWD3011WW Front Load Washer
Cannon pc1061 error 100
there is no error code `100'. The error codes that show on the display start with an `E', then three numbers, ie: E001.
Apr 02, 2014 | Canon Office Equipment & Supplies
My TEC B-572 Printer is sporadically displaying various error codes.
Two things:
If firmware prior to 3.1 the you should not use topix graphics
You can use ascii or compressed. If you use topics and the printer doesn't understand it then the line is displayed with error condition.
Else you have a bad monitoring of the spool. B575 has monodirectional centronics port.
Jan 11, 2012 | Toshiba TEC B-572 Printer
Washing maching error code IE
WATER PRESSURE SWITCH ERROR - Display shows 1 E.
* Generated Frequency Signal of WATER LEVEL (WIL) SIW (KHz)
Normal Level = Abnormal W/L Frequency
Low Level = 30.00 Khz
High Level = 15.00 Khz
If the same signal is detected for more than 5 seconds, it is a PRESSURE SWITCH Error. When this error occurs the drain pump will operate for 3 min. and the display will show 1 E indicating a pressure switch error.
Dec 19, 2010 | Samsung Washing Machines
Error code ( IE ) on my samsung washing machine model wa13g7q1
1E - WATER PRESSURE SWITCH ERROR
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 27, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Ribbon Stall
Printer errors are various messages displayed on the LED display of printers. ... We also carry a lot Lexmark Toner & Ribbons for your one stop shopping experience. ... ERROR 54 - Duplex Feed Error (IID/IIID) or Main Motor Stall 2686 A/D ..... Sharp Printer Supplies, TallyGenicom Printer Supplies, Texas Instruments ...
www.printersupplies.com/errors.html
Dec 03, 2009 | Office Equipment & Supplies
LG-Trom Getting error CL .now not able to operate.after switch on it gives CL in display
IE is a water inlet error...meaning that the correct water level was not achieved within 8 minutes or it did not reach preset water level within 25 minutes...
CL is child lock feature which can be toggled on and off by by holding the Pre wash button in for 3 seconds.. Hope that helps...
Aug 04, 2008 | LG WM-2277HW Front Load Washer
Toshiba TEC B-572 Printer Logo
145 people viewed this question
Top Toshiba TEC Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
richie46
Are you a Toshiba TEC Office Equipment and Supply Expert? Answer questions, earn points and help others
