Question about Xerox Phaser 7750DN Laser Printer
Media curls on lead and trailing edges
The media has a back curl on the lead andf trailing edges of prints. Tried fresh ( drier media ) same result. ??
    Problem Solver:
  • 8 Answers
Any of the following:-
Ensure the correct paper weight settings are in use. Excesive heat will cause paper curl.
Feed paper short edge first.
This is normal with high ink coverage on light paper. Use a heavier weight paper.
Your fuser may need replacing.
Posted on Jul 05, 2008
I860 will not print a 4 x 6 photo on a windows 7 pc. It gives a message that I have installed the wrong paper. It only wants to print full sheet size photos. I installed the canon add on module drivers and...
Set Envelopes Correctly Before setting envelopes, press down on all four corners and edges of the envelopes to remove curls and bends, as well as any air contained.
Note: The flap of the envelope should be straightened if bent. If the envelope is curled, hold the opposite corners and gently bend them in the opposite direction. If the leading edge of the envelope is puffed or curled up, use a pen, etc. to press the envelope flat and sharpen the crease. (Press the envelope completely flat, working from the middle to the edge.)
i80_envelopes_2.gif How to set envelopes:
  1. Set envelopes to the right side of the sheet feeder. Set envelopes with their longer side vertically and the flap either at the bottom or on the left.
  2. Pinch and slide the paper guide until it firmly resets against the left side of the stacked envelopes.
    Note: The maximum number of envelopes that can be loaded is five.
    <1> Sheet Feeder's right side
    <2> Paper Guide
  3. Set the paper thickness lever to the left.
    <3> Paper Thickness Lever
    Note: Remove the printed papers from the paper output slot cover before five sheets have been ejected.
Also How do I enlarge or reduce my printing size?
Nov 07, 2010 | Canon i860 InkJet Photo Printer
I have a CP2025 Laserjet and the paper curls upon exit. When I first started using the printer, there was an option for no curl and it has disappeared. The people at our help desk do not know anything...
Hello i m giving some tips to u it may be helpfull to u
1. Press the "Setup" button to access the Setup Menu.
2. Press the down arrow button until "Service" is displayed.
1. Press the "OK" button.
2. Press an arrow button until "Less Paper Curl" is displayed. Press the "OK" button.
3. Press an arrow button to display "ON" and press the "OK" button.
NOTE: When 'less paper curl' = ON, sets the fuser to Light media mode, or uses less heat to reduce the amount of paper curl. The 'default paper type' gets set to 'light 60-74g'. As a result of this setting, the control panel may prompt the user 'load Tray 1 with Lite Letter' when printing.
If 'less paper curl' = OFF, then 'default paper type' gets set to 'plain' again.
if ur problem not resolved after this exercise then give me ur mail id i will send some more tips...good luck
Jul 30, 2010 | HP Office Equipment & Supplies
I have printed all odd # pages from a document, but my HP Laserjet 4 won't feed these pages back through to print on the blank side with even # pages. I've tried to keep the front (feeding edge) of papers...
You need to try a thicker paper, Heavier stock to double print the page. Slightly more expensive. Recycled paper typically will not work for this type of function. I had this same problem and found this was the only solution.
Oct 31, 2009 | HP LaserJet 4 plus Printer
Paper won't feed
Inside of the machine is dirty.
If the inside of the machine is dirty, the printed paper may be smudged.
Follow the steps described below to clean the inside of the machine.
1. Ensure that the machine is turned on and there is no paper loaded in the Auto Sheet Feeder.
2. Place A4/Letter-sized plain paper in landscape orientation, horizontally fold it in half.
3. Unfold the paper, and load the paper in the Auto Sheet Feeder with the inverted-V edge down.
4. Select <Bottom plate cleaning> from <Maintenance>.
5. Select <Yes> on the Bottom plate cleaning confirmation screen and then press [OK].
Paper will be ejected.
If protrusions inside the machine are stained, wipe ink off the protrusions using a swab or such like.
* Important
Before cleaning, be sure to turn OFF the machine.
Paper feed roller is dirty.
Follow the steps described below to clean the paper feed rollers.
1. Ensure that the machine is turned ON and there is no paper loaded in the machine.
2. Select <Roller cleaning> from <Maintenance>.
3. Select <Yes> on the Roller cleaning confirmation screen and then press [OK].
The paper feed roller will rotate as it cleans.
4. Repeat this operation twice.
5. Load three or more sheets of A4/Letter-sized plain paper lengthways in the Auto Sheet Feeder.
6. Select <Roller cleaning> from <Maintenance>.
7. Select <Yes> on the Roller cleaning confirmation screen and then press [OK].
The paper that is loaded in the machine will feed through the machine and be ejected.
8. Repeat Steps 5 to 7 three times.
Inappropriate paper type is used.
Check to see if the paper you are printing on is too thick. See Paper Types You Cannot Use.
Note that smudging may occur at the top and bottom edges of the paper when using Borderless Printing. Ensure that the paper you are using is compatible with Borderless Printing.
Thick paper is used.
When printing on thick paper, set the Paper Thickness Lever to the right.
This widens the gap between the FINE Cartridge and the paper. Try this maneuver if the printed surface is scratched.
Media is curled.
If all four corners or the printing surface of the paper is curled, the paper may become dirty or may not feed properly. Use the paper after correcting paper curl as follows.
1. Place the printing surface face up (A), and cover it with a sheet of non-printing regular paper to avoid damaging the surface.
2. Roll up the paper in the direction opposite to the paper curl as per the figure below.
3. Check the printing paper to confirm if the paper curl is eliminated to within approximately 2 to 5mm / 0.08 to 0.2 in (B).
It is recommended to print on curl-corrected paper one sheet at a time.
The media type is not selected correctly in the printer driver.
On the [Main] tab of the printer driver, ensure that the [Media Type] selected matches the paper loaded.
In the [Print] dialog box of the printer driver, select [Quality & Media] from the pop-up menu, and then ensure that the [Media Type] selected matches the paper loaded.
Paper is loaded incorrectly.
Load in the portrait orientation regardless of the print direction of the Auto Sheet Feeder.
Ensure that paper is loaded correctly. Slide the paper guides against the paper stack.
Oct 18, 2009 | Canon Pixma MP500 All-In-One InkJet...
Pasenger side air bag cover edges curled.
You would be well advised to leave anything/everything associated with any airbag issue to the dealer. Safety issues. . .
Nov 13, 2017 | 1994 Chrysler New Yorker
Paper curl
Paper Curl. Does the paper have a curl on the trail edge? (The last part of the paper to exit the printer)
If it is the entire paper replacement of the fuser will likely resolve this.
If the paper curl is on the trail edge then replacement of the upper delivery roller should be done.
Nov 03, 2008 | HP LaserJet 4 plus Printer
Anti-curl motor error
Yes.
On the Document/Quality tab, select "Print On Backside" in the Media Type box.
Apr 14, 2008 | Alps MD 5000 Thermal Printer
Curled corner causing a paper jam
Try replacing all paper. Sometimes paper that is overly humid or has gotten wet will curl. Replace with new paper and report results.
Dec 17, 2007 | Dell 1600n All-In-One Laser Printer
Brother HL_5280SW Clack and pages curling
When paper is damp and runs threw the fuser in machine paper dries out and curls, try fresh paper, see this link about paper. Try a fresh sealed ream of quality paper
I dont have this model in Australia but it looks the same as the HL 5270 and there is bullitin released on these to eliminate paper curl, they upgraded the fuser and exit guide to fix this problem, yours is 2 months old so is covered by warranty, contact brother in your country to have it fixed.
Dec 01, 2007 | Office Equipment & Supplies
Printing card
Postcards, 3-by-5 inch (index) cards, and other custom-sized media can be printed from tray 1. The minimum media size is 76 by 127 mm (3 by 5 inches) and the maximum media size is 216 by 356 mm (8.5 by 14 inches). Note You might experience some jams when using any media with a length less than 178 mm (7 inches). This might be caused by paper that has been affected by environmental conditions. For optimum performance, make sure you are storing and handling the paper correctly . Using media from another manufacturer might also help. Printing on odd sizes or weights of media (for example, small, long, or narrow paper) can decrease print speed. The decreased speed helps to prolong the life of internal printer parts. It also improves print quality with these types of media. Guidelines for printing on custom-sized media and cardstock Always insert the short-edge first into tray 1. If you want to print in landscape mode, make this selection through your software. Inserting paper long-edge first might cause a jam. Use the rear output bin to reduce curl. Do not print on media smaller than 76 mm (3 inches) wide or 127 mm (5 inches) long. In your software application, set margins at least 6.4 mm (0.25 inch) away from the edges of the media.
Aug 21, 2007 | HP LaserJet 2300dn Printer
Xerox Phaser 7750DN Laser Printer Logo
176 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
