Question about Fisher and Paykel GWL11 Top Load Washer
My fisher & paykel smart drive 051 will wash then drain, but when it gets to the spin cycle it wont spin at all it fills then drains only.
  • Fisher and P... Master
  • 17,130 Answers
Possible that the program controller is faulty and is not executing the output when the wash cycle and the drain is done. So the program must advance further to the next stage to drive the motor to spin after the water is pumped off and the water level sensor is reset.
Have the conttroller checked to confirm the fault, look for loose joints in the connections.
If not the controller can be a suspect.
Posted on Oct 15, 2010
Smart drive 085
It won't spin until all the water is drained out. The drain pump may be blocked or faulty. Fix the drain pump fault first then deal with the filling issue. They will not be related.
Jun 21, 2017 | Fisher and Paykel (IWL12)
Smart drive 085
the buzzing noise is the pump trying to work, but it cannot due to a blockage. unplug the washer and you can lean the washer backwards and remove the pump to unblock. the fill error is probably unrelated, and is an inlet valve issue.
Sep 25, 2013 | Fisher and Paykel (IWL12)
Hi I have a fisher and pykel fresh smart drive 9 and its filled up with water but wont drain,ive tried advancing the cycle but all I get is a humming noise.please help
The humming noise is due to the drain pump being jammed due to clogging of dirt. All you need is to remove the drain pump and do a full clean up. You can also try to tap on the drain pump while it is humming as it will release the dirt and wash off.
Sep 07, 2013 | Fisher and Paykel GWL11 Top Load Washer
I have a F&P smart drive 051 machine - it has stopped spinning. How can I check for common easy to fix problems?
Hi just read your posting.Now does your machine drain the water?If it does not drain then the machine will not spin.Please reply with additional information and I can help you further.If the machine drains but does not spin then I will guide you throe a different series of things to test.Looking forward to your reply.
Jul 01, 2010 | Fisher and Paykel Washing Machines
The fuse in the control box of my F&P Smart Drive 703 keeps blowing.Any ideas why?
Hi just read your posting.Now at what stage of the cycle does the fuse blow?Is it when it is filling,or draining or washing or spinning?Please reply with additional information and I can track down this fault for you.
Jun 30, 2010 | Fisher and Paykel IWL12 Top Load Washer
Hey, my f&p smart drive 9 excellence washing machine does not start wash cycle after entering water level etc.... upon pressing the start button nothing is happening any thoughts?
Is the bowl turning slowly when you press start.if it does then you may have a faulty inlet valve,make sure taps are turned on.try advancing the machine to spin cycle,see if it will do any other things such as spin & drain.if it does then probably just not letting in water & inlet valve needs replacing..try filling machine by hand & see if it washes.
May 24, 2010 | Fisher and Paykel (IWL12)
Fisher & Paykel Smart Drive 7.5 washing machine.
Unplug the machine have someone tilt the machine back and look under the machine for a little fan on a motor give it a turn to see if it spins it might just be sticky or it may need replacing.
Jan 07, 2010 | Fisher Paykel Eco IWL16
Fisher and paykel 7.5 smartdrive washing machine, no power
If there is power and all your lights are lighting up but you get no responce from the machiene eg no spin, water filling, wash cycle or drain then it will be the sensor for the lid it will have coroded but this is an easy fix , I hope this helps
Feb 20, 2009 | Fisher Paykel Eco IWL16
Fisher and Paykel Smart Drive 608 wont spin
remove the pump from underneath front right move whith clip forward the twist pump out.but you will need to remove all the water first you may a ball of lint stuck in the pump.hope this helps.
Mar 29, 2008 | Washing Machines
Fisher and Paykel GWL11 Top Load Washer Logo
388 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
