Question about Konica Minolta Office Equipment & Supplies
Konica minolta 210 error code cof33 - Konica Minolta Office Equipment & Supplies
Soulvisitor
  • 1113 Answers
SOURCE: konica minolta EP2010 error code c05
Fuser is hot section near paper exit, left side, replace fuser assem. to fix,
The fuser "melts toner into paper after printing", fuser runs hot at 180 deg, but yours isnt heating up, hence error, lamp blown, thermister faulty or thermal fuse, these are all parts of a fuser, odd occasions it is board that powers it, but thats rare.
Posted on Nov 08, 2007
  • 8 Answers
SOURCE: Problem in configuring IP address in Konica Minolta bizhub 210 Copier, Printer, Fax
Is there network card is installed in it, if yes then you can configure it with your network go to machine Manu in machine control panel and the in network settings here you can give the IP address and subnet mask after then reboot the machine.
If network card is no installed behind the machine then you can use its built-in USB or and parallel printer without NIC card.
Posted on Feb 02, 2008
I have a Konica Minolta CSPRO EP1054 (in the Middle East)
I accidentally plugged the EP1054 copier into a 110V outlet instead of the 220V. Immediately the malfunction code (error code) of "C05" appeared along with the "Call Tec Rep" indicator light (wrench).
I followed the instructions posted by "Soul Visitor" ... i.e., I found the "Trouble Reset Switch" (not shown in the user manual) by opening the upper back panel and pressing the small black button in the lower right hand corner of the middle circuit board (green).
It worked perfectly!7df26b9.tif
Posted on Jan 16, 2009
herminio_hal
  • 210 Answers
SOURCE: Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
Posted on Jul 09, 2009
SOURCE: IError Code C13FO on konica minolta Di1610
C13F0 - Laser error
The laser output exceeds the upper limit value.
The laser output remains lower than the lower limit value.
Posted on Aug 23, 2009
Sir I have Minolta buz 210 error code
Code: C0210
  • Description: Abnormal image transfer voltage
    - The image transfer voltage remains more than 100 V continuously for a given period of time while the PC Drum remains stationary.
  • https://printcopy.info/?l=en&mod=erc&brand=Konica-Minolta&model=bizhub%20210
    Jun 29, 2017 | Minolta Office Equipment & Supplies
    Konica minolta c550 displaying a code C-B116, how can I solve this please?
    Konica Minolta Ineo 223 Fax card Error C-B003 \ C-B116 ...
    www.copytechnet.com > ... > Copier Technical Discussion > Konica Minolta
    Feb 6, 2014 - 10 posts - ‎6 authors
    The other errors that appear are C-B116 & C-B003, i've tried the below : 1. .... Also ensure you have the fax set to the correct country code. Error Code konicaminolta bizhub500 error code C-B003
    7 Sep 2010
    How Do I Access Techrep / Service Mode? - Page 4
    18 Jul 2008
    More results from www.copytechnet.com
    Error code C-B116, what does it mean? - Fixya
    www.fixya.com/support/t1535504-error_code_c_b116_mean Jan 13, 2009 - Touch the following code on the trouble code display screen. Stop ? 0 ? 7 ... 4 Answers. SOURCE: Konica Minolta Bizhub C352 error C-B116.
    Bizhub c250 code c-b116 - Fixya
    www.fixya.com/support/t11325427-bizhub_c250_code_c_b116 Jan 17, 2012 - bizhub c250 code c-b116 code c-b116 on the bizhub c250. ... on the display you'll see the Trouble reset button on the display, touch it and turn ...
    Konica Minolta Bizhub C352 error C-B116 - Printer
    www.allprintersmn.com/konica-minolta-bizhub.../q724088-konica_minolta_bizhub_c... fix Printers & Copiers - Konica Minolta Bizhub C352 error C-B116 about Printers & Copiers. ... Konica Minolta BizHub C550 Error Message ... ERROR CODE C11B2 ON DISPLAY - Konica Minolta bizhub C250 All-In-One Laser Printer. konica minolta c550 displaying code B116 Google Search
    Mar 15, 2017 | Konica Minolta Office Equipment & Supplies
    Bizhub 210 error code c501
    could not locate the BH210 on the Konica Minolta web site, code is close to a fuser code The hot part of the machine
    Jul 12, 2014 | Konica Minolta bizhub Office Equipment &...
    C0F32 Minolta bizhub 210 and 211
    C0f32 that means ATDC error, when toner amount in developer is uneven then this code will display, so you have to replace the developer and do the atdc auto adjust the code will remove.
    please always mention the copy counter and life of consumables every time when ask the qustion.
    Sep 15, 2012 | Konica Minolta DiALTA Di183F Copier
    My copier is konica minolta bizhub 210 have problem error code M1. please help me solution.
    My Friend You must do general service in your photocopier and then you must program your machine.
    Sep 29, 2010 | Konica Minolta bizhub 180 All-In-One...
    Error code c0000 in bizhub 210
    Error code c0000 means imaging unit drive motor is not working or imaging unit get hard so its better to call a service representative.
    Jul 07, 2010 | Konica Minolta bizhub 180 All-In-One...
    REMEDY TO SOLVING ERRORS COF32 AND CO650 IN KONICA MINOLTA BIZHUB 211.
    to remove code "COF32" from your machine, simply change the developer with the new one. code will remove.
    wish you best of luck............
    Jun 12, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
    Konica minalota 210 error code detials can everyone can give me the error code
    If you are asking about a C0 210 code on a Minolta Di183 then this code means there has been a abnormal image transfer voltage error. The service manual says "the image transfer voltage remains more than 100V for a continuous given period of time while the PC drum remains stationary".
    Have you opened/closed the front door or turned the machine off then back on to reset the code and see if it returns?
    27 years working on Minolta copiers and I have never seen this code on this model of machine before so hopefully it will reset. If not you will need to call for service on the machine.
    Good Luck and Thank You for using Fixya.
    Apr 22, 2010 | Konica Minolta DiALTA Di183F Copier
    C03FF Minolta bizhub 210
    C03FF, is the improper or unmatched model setting code. go to "service mode" In service mode please select "ADJUST"
    in "ADJUST" please select "Model Setting" in "Model Setting" select the cpm, (Copy speed) of your machine, for example if you have bizhub 210, then select "21" from the list. if you have bizhub 163 then select "16" from the list and press "yes" button. code will remove.
    Jan 29, 2009 | Konica Minolta DiALTA Di183F Copier
    400 people viewed this question
    Top Konica Minolta Office Equipment & Supplies Experts
    Norman  J Weimar Jr
    Norman J Weimar Jr
    Ben
    Ben
    David Burkhart
    David Burkhart
    Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
