I git this error message "invalid database specification" after logging into accpac. assistance please.
2 Suggested Answers
SOURCE: Cannot Access database (error=49153)
We are using Oracle, but you may want to try these:
  1. Go to ODBC in Control Panel, and test the Connections
  2. If it still doesn't work, Go to Services in Administrative Tools, and try to restart it (the seervices)...
It worked on us...
Posted on May 19, 2009
Error 53.21 hp color 5550
Doesn't specifically mention the 53.21 error this is the closest they come so you will know it deals with the ram anyway
Control panel message Event
log error
message
Description Recommended action
53.XY.ZZ CHECK RAM
DIMM SLOT X
To continue press
CANCEL JOB
None An error occurred on some
memory of the printer.
X DIMM Type
1 RAM
Y Device Location
1 DIMM Slot 1
2 DIMM Slot 2
3 DIMM Slot 3
4 DIMM Slot 4
ZZ Error Number
0 unsupported memory
1 unrecognized memory
2 unsupported memory size
3 failed RAM test
4 exceeded maximum RAM size
5 invalid DIMM speed
Press CANCEL JOB. If the problem
persists, replace the DIMM card in
the slot indicated.
Click Here for Memory
hope this helps and if so please mark FixYa!!
Jul 30, 2010 | Office Equipment & Supplies
HP 4350 ERROR MESSAGE: 49.2F90
"the printing operation has been aborted.
The issue can be caused by a firmware error, invalid print commands, corrupt data, invalid operations, poor quality parallel cables, poor connections or specific applications.
Action :
1> Press Cancel Job to clear the print job from the printer memory.
2> Turn the printer off and then on to clear the error message.
3> Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job, contact the software vendor for assistance.
If the above action does not solve the issue, contact HP or authorized service provider."
Mar 15, 2008 | Office Equipment & Supplies
49.4co2 service error will not clear
Error 49.xxxx - this type of error can be caused by invalid print comands, corrupt data or invalid operation...try this steps to resolve... :
1 Turn the MFP off, and then turn the
MFP on.
2 Upgrade the firmware.
3 Try printing a job from a different
4 If the message persists when using
different software programs and
attempting specific print jobs,
disconnect all of the cables that
connect the MFP to the network or a
computer.
5 Turn the MFP off.
6 Remove all DIMMs and flash-memory
cards. Do not remove the firmware
memory card that is in slot 1.
7 Remove all of the EIO devices.
8 Turn the MFP on.
9 If the error message disappears,
reinstall each DIMM, flash-memory
card, and EIO device individually,
making sure to turn the MFP power off
and then on again as you install each
device.
10 Replace the component that caused
the error message.
11 If the error persists, replace the
formatter
Jan 06, 2010 | HP LaserJet 4650 Color Printer Manual...
Can not open sage accpac
That error means this entry:
HKEY_LOCAL_MACHINE\SOFTWARE\ACCPAC International, Inc.\ACCPAC\Configuration\SharedData
is not pointing to the folder that contains the *.LIC files. Or, you don't have full permissions to that folder.
Oct 13, 2009 | ACCPAC Fax/Voice/Mobileserve for PC
LaserJet 4350n Error 49.C02
49.XXXX PRINTER ERROR To continue turn the printer off then on Description The printing operation has been aborted. The issue can be caused by a firmware error, invalid print commands, corrupt data, invalid operations, poor quality parallel cables, poor connections or specific applications. Action
  1. Press Cancel Job to clear the print job from the printer memory.
  2. Turn the printer off and then on to clear the error message.
  3. Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job, contact the software vendor for assistance.
  4. If the above action does not solve the issue, contact HP or authorized service provider.
Dec 05, 2008 | HP LaserJet 4350 Printer
It worked on us...
Nov 21, 2008 | Computers & Internet
SQL Invalid cursor number 135 error
The error is being generated because you are trying to order on a value not in your selected fields e.g EFFECTIVE_DATE
You only have TRANSACTION_TYPE in your select statement
Sep 24, 2008 | Gupta Team Developer for PC
COMPANY IS MISSING!!!
try checking to see if the company exists in the database setup.
you need to make sure the company database is linked to the system database before it becomes available to use. if it is there, delete the links and recreate them
Feb 22, 2008 | ACCPAC Simply Accounting 2004 PRO...
Computers & Internet Logo
79 people viewed this question
David Payne
David Payne
