Question about Philips Philishave HQ8150 Electric Shaver
One of the spindles that drive shaver head has snapped, can this be easily repaired?
  • Philips Master
  • 1,600 Answers
For model HQ8150, the item you reqire to replace the broken gear is found at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/norelco-8100-series-motordrivegear-assembly-p-608.html
You will find generaal disassembly instructional video also at shaveroutlet.com. See link below (it's the second video)
http://shaveroutlet.com/video_tutorials
Follow the instuctions in the video, then remove the wires from the motor by pulling on the wires as you puch in on the metal release tab next to them. Remove the two screws near the broken 'spindle' to remove the plastic gear plate. The motor assembly will then come out
Posted on Oct 15, 2010
I have a Braun 7570 and it is marvelous! I replace foil and cutter every year. This time after replacing it the shaver did not cut my hair. Battery still gets full charge. What is the problem?
Most likely, the 'drive unit' is bad. The drive unit is a component that consists of the swivel frame that the head snaps onto and the motor. Excessive noise while the shaver is running is also a major sign that this part is bad.
Unfortunately, Braun no longer provides these type of replacement parts for any of their shavers. You may end up needing to replace the unit.
Since you apparently like that model and you have spare shaver heads for it, you might want to consider a compatible model as a replacement. shaveroutlet.com has a new model that uses the same foils and cutters as your 7570. You can see it at the link below
http://shaveroutlet.com/shavers/foil-shavers/braun-series-1-195s-mens-cordless-shaver.html
Feb 19, 2014 | Braun Syncro 7570 Electric Shaver
Tip
Fix Model 3105 also Model 3612
The small plastic piece falls out when cleaning the head. It goes back in the left side of the removable piece. Hold it with the screen closest to your body and upside down. The small piece fits in the upper left with the square edge to the left in the small recess. It just sort of snaps in.
Mine is actually the 3612 cordless but they look identical from the photo. I have been trying to fix it for 6 months. When a new head had the same problem with the piece falling out, I decided it might be repairable. After I pushed the piece back in, it stayed. You can tell where it goes by looking at the taken apart shaver (With the head removed for cleaning). The shaver has a plastic pin sticking up on the left side. This pin is what lowers the trimmer when the shaver is assembled.
Hope it works for you.
on Nov 07, 2008 | Braun Interface 3105 Electric Shaver
I need directions on changing the head on the Arcitec razor head
Changing the head on Arcitec models is very easy. It doesn't come apart like older models. For the Arcitec model you simply pull off the entire head assembly and snap on a complete new assembly. See diagram at the link below
http://shaveroutlet.com/media/catalog/product/cache/1/image/5e06319eda06f020e43594a9c230972d/f/i/file_34_1.jpg
You can purchase replacement heads for this model at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/norelco-philips-rq10-arcitec-replacement-heads-p-353.html
Aug 17, 2011 | Norelco Arcitec Electric Shaver -...
Hello- I have a Remington MS-900 shaver that the head will not snap into position on one side. Since then I purchased another with the same model number, but the new head will not snap into the old one. ...
It could just need cleaned well as a buildup of whisker particles can prevent it from locking into place. But, the foil frame may be broken or damaged. If this parts needs replaced, you will find it available at shaveroutlet.com. See link below
http://shaveroutlet.com/catalogsearch/result/?q=ms-900+foil
Dec 07, 2010 | Remington MS-900 Electric Shaver
1.5 year old 7140XL worked fine, then next time would not turn on at all. Charge light shows charged.Any suggestions?
There are two likely possibilities. These problems would either be that the head is damaged or jammed or there is a loose connection inside.
You can easily test if it is the heads by flipping up the head assembly and then turn it on. If it runs with the heads flipped up but not when they are snapped down, you can assume that the heads are the problem and they will need to be replaced. You will find replacements for this model at shaveroutlet.com. See link below
http://shaveroutlet.com/norelco-philips-hq8-spectra-sensotec-replacement-heads-p-251.html
If the shaver will not run with the head flipped up either, you may have a loose connection inside...usually from the moto to the circuit board or from the battery to the circuit board. You may be able to locate and repair this but if your shaver is 1.5 year old, it is still under warranty. If this is the case, contact Norelco using the info in your user manual for the warranty
Jun 30, 2010 | Philips 7140XL Electric Shaver
Braun Pulsonic 9595 Razor will not hold a charge ... where can I get this repaired in New Hampshire (03110 area code)
You can replace the battery yourself. The battery can be purchased from Amazon: http://www.amazon.com/Braun-Li-ion-Battery-Pulsonic-Shavers/dp/B002S8UWMI and to replace it you will need to remove the rubberized back from the case. The black rubberized back is snapped into place on the silver case so to remove it the first thing to do is to remove the retaining screw. This screw is a Torx T8 and you can see it inside the socket for the power cord. Once this screw is removed, carefully insert a small blade in between the edge of the back and the case at the end away from the shaver head and gently pry up on the case back. Once you get a large enough gap, you can grab the edge of the back with your fingers and pull it off the case working toward the shaver head. The edge of the back by the shaver head has a small lip that slips into the case so it needs to be slipped out of the case edge last. Now you will see four Torx T8 screws holding down the plastic back to the silver case. Remove these screws and pull the back off the case straight up. You will now see the battery you need to replace in its holder. Remove the old battery from its holder and push in the new one in the same orientation. Replace and screw down the case back, snap on the black rubberized back and replace its retaining screw. Charge up the battery and you are good to go.
Nov 11, 2009 | Braun Shavers Male Pulsonic System 9595CC...
How to disassemble Braun 4505 shaver. Cutter stopped working.
You want to go to this site and get a repair manual. http://web.archive.org/web/20041025223715/63.230.9.155/braun/Srv_Man/SHAVER/
Follow the instruction and remove the swivel head. Then remove the 2 screws at the bottom. I still have problem sliding the two side head support off.
Apr 08, 2009 | Braun 4501 Electric Shaver
My shaver head broke! PLEASE HELP ME!
I just fixed my husband's razor. I took everything out and washed it all. Then I took the three things that touch the skin and put them in the three holes so that they fit comfortably. Then I put the sharp parts inside those thin parts. The I took the gray thing with three holes and snapped the little brown thing to it and turned the arrows on the brown thing so it snapped it securely to the things with holes. Then I put the head onto the handle by sliding the hook into it's hole, than brought the head onto the handle and snapped it shut. It fell apart the first time I tried it but I put it all back together and after that it worked like a charm.
May 08, 2008 | Norelco 8170XLCC Electric Shaver
Conair GMT182 How do I change heads?
Pull at the bottom of the shaver head- it has a small pin that snaps into the drive mechanism- it is hard to get free, but will come off.
Nov 29, 2007 | Conair GMT182CS
Philips cool skin shaver fault
The shaver head symbol means the motor isn't starting, which all the support info assumes is because the heads are too gunked up with hair and congealed moisturizer etc, so clean it. In my case it was because the motor had seized - I completely dismantled the razor and turned the cog attached to the motor spindle by hand while turning the razor on, which was enough to free it up and kickstart it - you'll need some torx screwdriver bits - remove the battery cover (it may be a bit sticky since it is wedged against a rubber seal that it may have stuck to, but it does just lift off, there's nothing to snap), remove the black plastic retainer underneath that which hides a couple of screws holding the head assembly (you may need to prise the battery up to get at them) - undo them and you should be able to pull the head assembly off and push the motor up from underneath to free the plate holding the three cogs driving the head - beneath that is a big cog attached directly to the spindle, spin that by hand while starting the razor and it should hopefully spring back into life since you'll have freed the seized spindle.
Sep 10, 2007 | Philips Philishave Cool Skin HQ6760/HQ...
Philips Philishave HQ8150 Electric Shaver Logo
340 people viewed this question
Top Philips Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Philips Health and Beauty Expert? Answer questions, earn points and help others
