Question about Kenmore Drop-In Bobbin 16231 Mechanical Sewing Machine
My bottom thread keeps getting jammed when I start sewing. What's goin on?
It sounds like the bobbin may be positioned wrong (it should turn counterclockwise when you place it in the holder) or the bobbin is not pulled completely through the notch in the holder.
Also, make sure your top thread is threaded properly too. Sometimes I've had problems when I thought it was the bobbin but it turned out to be my main thread.
Hope that helps.
Posted on Oct 25, 2010
The cotton on my bernina 801 keeps jamming
Loops on bottom indicate a top thread tension problem.
Make sure needle is the correct size and not bent or broken
Make sure it is threaded properly with the lever UP.
Do a test stitch.
If it still loops below... tighten the top tension and do another test stitch... keep doing this until the stitch is balanced.
BTW... always grasp and hold both threads when starting a seam.
Jul 30, 2012 | Sewing Machines
Threading the machine
You said it jams when you start to sew. Please clarify. how and where does it jam?
Make sure you threaded the machine with the foot in the UP position. Make sure your bobbin is in the case correctly and is spinning in the correct position when you pull on the thread.
When starting to sew, grasp the top and bottom threads and gently tug, then hold it down to the surface of the machine as you begin the seam.
Jul 14, 2012 | Necchi 3537 Mechanical Sewing Machine
I have a brother ls-1217 i was cleaning it and one of the springs that is on the inside on the left came un hooked from the bottom and I am not sure where is supposed to be hooked up to. Can someone...
Brother says DO NOT OIL!!
Sadly I'm afraid you'll have to take this in to a service location.
Issues with thread jamming and threading are normally issues with the wrong needle for the application. Your manual should have needle suggestions for different fabrics. Also before you begin sewing grasp both threads and gently tug straight back as you start your first stitches.
Good luck.
Feb 05, 2011 | Brother LS-1217 Mechanical Sewing Machine
Keeps getting jammed
Give these solutions a try.
* Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your
bobbin case. Re-thread your machine, reinsert and re-thread your bobbin.
* Change your bobbin as there could be a nick along the edge of your bobbin spool that’s catching your thread as you sew.
* When you start to sew a seam, Hold the upper and bobbin thread tails back and out of the way as you sew your first couple of stitches. This will keep them from getting jammed in your machine.
I hope this helps.
Dec 29, 2009 | Sewing Machines
Sewing machine jams
does it jam up on the top or bottom?? if it shows on top it is the bottom thread if it jams on the bottom it is the top thread
Oct 12, 2009 | Husqvarna Viking 1
My sewing machine keeps getting jammed when sewing. the top stitch keeps getting tangled in with the bobbin thread and jamming up the machine.
Here are a couple of things to try.
There could be a nick along the edge of your bobbin spool that’s catching your thread as you
sew.
* When you start to sew a seam, grasp the upper and bobbin thread tails. Hold them back
caught in your machine.
I hope this helps.
Sep 11, 2009 | Singer 5160 Mechanical Sewing Machine
Euro pro model 385W sewing machine
Hi FixYa,
I'm fifi1076, and I'm having quiet a good bit of trouble with my sewing machine.
I'm new at this site so I don't know if I'm doing this correctly or not so please
forgive me if I do something I'm not suppose to do!!!!
I copied this question from off of this site for I wanted to make certain that
whoever answers my question will understand that all of the question
doesn't pertain to my problem.
"when we have it threaded the top thread keeps getting jammed up in the bottom bobbin. if i redo the bobbin as shown in manual then the bottom thread will not loop so it will stitch"
This is the only part that pertains to my problem...... when I have it threaded the top thread keeps getting jammed up in the bottom bobbin......and I can't get it to sew at all....it won't do nothing.....the motor will just sit there and grind.
If whoever can help me with this and can give me a solution I will be forever gratefull
Thanks,
Kay Nowicki
Aug 27, 2008 | Sewing Machines
Kenmore Drop-In Bobbin 16231 Mechanical Sewing Machine Logo
76 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
