Question about Toshiba Satellite P205D-S7479 Notebook
Toshiba P205D While reading the paper online the laptop screen went black
  • masquaw Sep 04, 2008
    I have a Toshiba Satellite L30/L35 Series that has been working perfectly until I started it up this AM. I use it every day with no hint of a problem I checked the power cords and that didn't help. Maybe someone could offer suggestions to help me solve this problem. Thank You,
    Sharon
  • Alexander Selby
    Alexander Selby May 11, 2010
    was there any info, displayed on the screen, did you download something, or was it just a random happening
  • 4 Answers
CHECK THE PORT THAT U COULD HOOK UP AN EXTERNAL SCREEN IF IT WORKS THEN ITS NOT THE VIDEO CARD IF YOU CAN SEE THE WINDOWS WORKING AND SHINE A LIGHT OR TILT THE SCREEN A CERTAIN WAY AN CAN SEE THE WINDOWS THEN IT MAY NOT BE THE SCREEN MOST LIKELY ITS THE BACKLIGHT IVERTER BOARD HERE IS SOMTHING GOT OFF THE WEB
Do you have a problem with the backlight on your laptop? If yes, you are not alone, that’s one of the most common laptop problems. In most cases the screen inverter is the culprit. Here are some LCD screen backlight failure symptoms that could be related to a bad inverter board:
- Laptop boots as usual but after some time the screen blacks out. You still can see an image on the screen but it’s very dim. You might even use a flashlight to see it better. Sometimes the backlight comes back for a while but then goes off again. In some cases you can turn the backlight on if you tap rapidly on the lid close switch.
- The screen always stay black and the backlight never comes on but you still can make out an image on the LCD. It’s dark, but the image is still there.
-In some cases you might hear a buzzing noise coming from the area where the inverter board is located, it’s on the bottom part of the display assembly.
NOTE: if you cannot see an image on the screen, most likely you have a different problem and there is nothing wrong with the screen inverter. HERE IS A WEBSITE THAT SHOWS HOW TO REMOVE IT AND REPLACE OH AND EBAY HAS THEM FOR AROUND 30 TO 60 DOLLARS
Posted on Feb 05, 2009
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 262 Answers
Either screen or viedo card has gone out try plugging it into a alt screen and see if it shows or not if it does I would say your screen took a floop or if it does show on a atl screen I would suggest you have prombally lost your veido card let me know la la linda
Posted on Jun 03, 2008
I need to know if the mother board from the p205d-s7436 is compadable for the s7438 model
Satellite P205d-s7436 motherboard,
http://www.sparepartswarehouse.com/Toshiba,Laptop,Part,K000056150.aspx
Satellite P205d-s7438 motherboard,
Same part number used for both laptop models.
Satellite P205d-s7436 specifications,
http://www.cnet.com/laptops/toshiba-satellite-p205d-s7436/4505-3121_7-33428376.html
Satellite P205d-s7438 specifications,
http://www.cnet.com/laptops/toshiba-satellite-p205d-s7438/4505-3121_7-32658635.html
Just by comparison of the specs the data suggests only a Processor change, Ram Memory amount, and Harddrive size.
Uses a Socket S1 processor socket on both model's motherboards,
http://en.wikipedia.org/wiki/List_of_AMD_mobile_microprocessors#.22Tyler.22_.2865_nm.29
Both models use an AMD 690V graphics chipset, (ATI Mobility Radeon X1200)
http://en.wikipedia.org/wiki/AMD_690_chipset_series
The answer is Yes.
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/laptop-disassembly-1.htm
Regards,
joecoolvette
Sep 15, 2012 | Toshiba Satellite P205D-S7438 Notebook
Toshiba satellite p205d-s7436 will not start.
Please remove the cable and remove the battery and connect the power cable and check it. if it working remove the power cable and connect the battery and check it.
Mar 15, 2012 | Toshiba Satellite P205D-S7436 Laptop DC...
Toshiba P205D-S8802 will not start up. Pressed power button, and hear the droves starting up and then stops. The screen remains black.
Hopefully you have more than 1 stick of RAM. I would remove 1 and try it again, if that doesn't work, try the other one. When it's powering up and then powering off quickly, that could also be a heat issue. Make sure all of the fans are powering on. Also you can try removing the battery, and trying with just AC power connected. Some laptops won't let you do this, but some will, and if the battery is causing the issue, it should work.
User guide can be found here, which will walk you through getting to the memory bay. http://www.retrevo.com/support/Toshiba-P205D-S8802-Laptops-manual/id/12395ag000/t/2/
If this helps, please provide a positive rating.
Jun 30, 2011 | Toshiba Satellite P205D-S8802 Notebook
Need to replace cpu battery for my P205D-S7438y
Straight from Amazon:
http://www.amazon.com/Replacement-Battery-Toshiba-Satellite-P205D-S7438/dp/B003O77162
If it's still under warranty though you can call up Toshiba and get it replaced at no charge.
Jan 02, 2011 | Toshiba Satellite P205D-S7438 Notebook
Toshiba P205D-S7438 Screen goes black after a few seconds
First you need to find out which "Bit" is faulty. Please try this monitor on another PC, if it works, then your problem is in the PC, if NOT then you need a new monitor. If it appears to be the PC, you will have to ascertain, if it is your Video or software that's causing the problem. First try below. At boot up press F8, when the Menu comes up, choose Safe Mode, but this time instead of going to the desktop, choose System Restore, follow instructions, and when the Calender type window comes up, simply choose a time BEFORE, the time it went faulty. This should completely restore you to working again. As long as there are NO other problems. support.microsoft.com/kb/306084 -
If that doesn't work you will then have to troubleshoot the motherboard by swapping out each item until you find the culprit.
Apr 13, 2010 | Acer AL1916W 19" LCD Monitor
Black colors turns to red in toshiba laptop P205D no bad connection
It is not due to bad connection it is due to bad software driver version of graphics driver. I recommend you to install correct version of graphics driver like Intel's driver.
Dec 12, 2008 | Toshiba Satellite P205D-S7479 Notebook
BIOS PASSWORD ON TOSHIBA P205D
contact me @ timothydjohnson@comcast.net
Jun 01, 2008 | Toshiba Satellite P205D-S7479 Notebook
Make sure the power supply is plugged into the mobo
Toshiba Satellite P205D-S7479 Notebook Logo
168 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
