Question about Shoprider Superlite 4 TE-787NA-UL4 Xtralite
Shoprider cordoba wont start when switched on it beeps constantly
gewiz
  • 1271 Answers
SOURCE: I need a user manual for SHOPRIDER CORDOBA
http://www.centralmobility.co.uk/includes/pdfs/scooters/Scooter%20Service%20Manual%20Live%20Document.pdf
The above is for a servicew manual, covers everything you should want plus how to service it.
Regards
GeWiz
Posted on Oct 13, 2009
  • 103 Answers
SOURCE: HAVE PUT SCOOTER TOGETHER AND CHARGED BUT IT
Make sure the scooter is not in freewheel.
Posted on Jul 23, 2009
SOURCE: my shoprider dasher just beeps
we just bought a shoprider monaco,after i cleaned it it did same thing just kept beeping,i found moving the free wheeling lever under back bumper a few times cleared it.Lever makes contact with a micro switch,on motor.
Hope this helps
Posted on Sep 10, 2009
  • 313 Answers
SOURCE: shoprider nippy powerchair when i switch it on
Here are some ideas :- Is the charger disconnected from the chair, are the brake levers in the drive possition. do the batteries need charging. Failling that it could be a controler fauld so you will need to consult an engineer.
Posted on Aug 01, 2010
mwoodring1
  • 496 Answers
SOURCE: my shoprider cordoba slows down to a
I'm thinking it could be the motor it's self, I would check the simple things till i got to motor. I;m not sure how much you know about electric motors and how electricity works so here is a crash course.
Electricity wants to get from positive to negative via a load ( light, motor, anything that runs of electricity ) or a short ( a grounded positive before the load ). There are a few basic ways to control electricity, switches on/off, rheostats, relays. On/off is pretty simple it's on or it's off, a rheostat allows you to control how much from 0-100% like the control on your scooter or a dimmer switch in you house. Relays are switch that is turned on and off by another switch. Electricity makes heat, the more volts and or amps you have the large the wire you have to use I.E a small 9 volt battery has low amperage and dose not need a large wire. While a 12 volt car battery has a much higher amperage and needs a larger wire.
The heat that is made by the electricity makes resistances. think about walking in the water, if it's still you can move with very little trouble but if the water is running the harder it would be the faster the water moves. The more resistance the more heat and back and forth it goes. over time it can cause wires and contact points to wear out.
The motor has spins inside a case the " housing" the contact points are called brushes. The fixed to the housing and a winding of copper wire spins inside the brushes. they can wear out of time do to the consistent moving.
I would start by checking the hand control to make sure it is work as it should. A multimeter is what you use for this on the ohm setting.
The other part to look into is the battery you can take it your local auto parts store or battery warehouse to have it tested.
I hope I have shared some useful information with you. If you have any other questions or need help in testing you scooter please feel free to contact me via fixya.
M.Woodring
Posted on Jun 18, 2011
Should the battery lights go iut in quick succession ie within half mile on my shoprider cordoba?
hi, no , are they fully charged and if so how long do they take before being fully charged ?
Have you tired another charger ?
Regards
Rob
Sep 18, 2016 | Shoprider Health & Beauty
Have a shoprider cordoba, judders and then pulled away very sharply.Changed brake and stripped and regreased drive. Went ok but now just beeps when throttle is pressed. Any ideas
Have you tried checking the motor brushes, remember if you get stuck and decide to go to a repair place. You will be lucky if they take the job on, but if you are happy to repair yourself. I suggest to take a picture of each step you take. My own scooter had same problem and the only thing i needed to do was the brushes. Hope this helped.
Aug 14, 2016 | Shoprider Health & Beauty
How to stop a continuing beep on my Cordoba scooter when I turn the key on? The scooter don't move at all.
Hi Mag,
I have this steps that might help you with beeping sound on your Scooter. Hope it helps.
UNIT LIGHTS UP/HORN WORKS BUT UNIT WILL NOT MOVE
Possible Cause:
  • This often occurs when the scooter is in free wheel mode and is not in drive mode. Re-Engage the free wheel lever which is located down near the rear wheels (normally a yellow or red lever).
  • If you hear a beeping noise, the beeping you hear is a fault beep indicating the scooter main control box has detected a problem. Contact your dealer who can diagnose the beep code.
  • Check batteries with load tester - If either battery drops more than 1 volt under a load, the battery(s) are bad. Replace "both" batteries.
I also find these additional steps on how to know beep alarm indicators:
This main control box has a self-diagnostics feature & cannot be tested with a volt meter. When a
problem is present the main control box will diagnose the fault, prohibit the scooter from being driven
and sound an alert beep. Each alert beep indicates a different issue which helps to determining the
problem by narrowing the fault into one of a few main areas of the scooter. Reference this information
below for the alert beep indications.
Very Rapid beep- Batteries are low. Charge & test batteries.
Medium Fast beep- Motor/brake wiring fault. Free wheel lever disengaged.
Solid beep- The charger is plugged into the scooter (some models may vary).
Very Slow beep- The throttle pot was not at center when you turned the unit on. Throttle pot off
center or wiring (yellow & orange wires) fault.
Apr 24, 2014 | Shoprider Health & Beauty
Constant beeping when turned
The freewheel lever isn't re-engaged properly. Try moving the lever to "free" then back to "drive" again. The lever moves a small micro-switch.
Apr 02, 2014 | Electric Mobility Health & Beauty
Beeper code
Needs manufacturers key fob swiping over control
Jul 26, 2013 | Shoprider Health & Beauty
Constant beeping, won't run
The beeping on shopriders usually means that the Main Control Box is faulty. It may also be caused by the Throttle Pot being out of neutral. This is a common promlem on this model of scooter as they use a Plastic throttle control lever instead of a metal one. Unfortunately, the plastic one's sometimes slip round slightly causing the above problem. Throttle pots can be very difficult to set to neutral without a multimeter so may be best left to you local dealer.
Jul 01, 2010 | Echo 3 TE SL7 3 New Electric Scooter by...
Regards
GeWiz
Oct 10, 2009 | Shoprider Health & Beauty
My shoprider dasher just beeps
Hope this helps
Sep 09, 2009 | Shoprider Dasher 9 3 Wheel Scooter...
Shoprider Superlite 4 TE-787NA-UL4 Xtralite Logo
117 people viewed this question
Top Shoprider Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you a Shoprider Health and Beauty Expert? Answer questions, earn points and help others
