Question about Watches
Hello, I am from Greece and own a Tissot T-touch titanium. I just received it back from Tissot's service, I sent it for a battery change and a compass calibration, as it did not work well. As it was delivered to me after 3 months!!, what a disappointment... I pressed once the T button, it gave a different sound than usual, and the dials are turning erratically, going from one function to another without touching the crystal! In fact, the touch crystal does not work, watch keeps changing functions between thermo, alt, chrono, date, units and all over again regardless of what I press, buttons or crystal. I am sure the touch crystal has been messed up, or something with the battery went wrong (short-circuit?) Is there any hard reset function, or service manual? Can I avoid the useless technicians of Tissot's service in GREECE? Any help would be appreciated? Thanks in advance, Panos
  • 52 Answers
Its a good watch and good company, I would send an email to Tissot head office customer service. Praise the brand but insist you are not happy with the local service, having already had a failed repair. Hopefully they will accept it back for repair or replacement.
Posted on Apr 08, 2017
SOURCE: tissot t-touch t0015204406100
Go to the offical Tissot site www.tissot.ch and download the pdf file "user manual" and there you'll have everything u need to know about operating this great watch...
Posted on Jan 21, 2008
SOURCE: "Tissot Touch" Touch screen failure
it all stems from the watch not actually being waterproof it's more water resistant than waterproof. The little indentations on the back that look like they are for a tool to unscrew it are actually holes i guess for the altimeter and meteo so it can sense pressure. Behind the back just behind the holes is a nylon gauze material and underneath this is a sensor slightly recessed and covered with some kind of waterproof substance. As far as i can see the problems lie here any water sweat or other foreign object than gets into this gauze will eventually will clog this gauze material which at first will affect the altimeter then the meteo. When the gauze has been clogged up severely i gets very dirty indeed which means when it gets wet it takes an age to dry out so if you wear it in the shower like i used to it will never dry out this causes the watch to malfunction quite severely. You can actually fix this problem yourself just get a very small flat screwdriver and lever the back off don't worry it's only a push fit and comes of easily you will see straight away a dirty damp smelly clogged up round piece of nylon gauze clean this up with a bit of WARM not boiling soapy water being careful not to disturb the pressure sensor and it's waterproof goo inside then dry it all and put it together
Hope this helps
Dom
England
Posted on Feb 26, 2008
escapement
  • 2334 Answers
SOURCE: Screen not working T Touch Titanium (Totally Useless)
I suggest you have to find the decent watchmaker and do not use dealers services anymore.In my opinion you have been overcharged in both cases.
Consider replacing touch screen if it is damaged and then sell it on ebay (anyway you do not like it). For watch in working order you have to get quite a decent money. If you gonna sell it as it is, you will get pennies only.
Later just buy another make and forget about this unlucky example. :))
Posted on Dec 17, 2008
escapement
  • 2334 Answers
SOURCE: Date function notworking properly
Do as follows:
1) At any time of the day pull the crown out and advance watch hands forward for EXACTLY 12 hours ( for example: if it's 6.35 on your watch, then after advancing hands it will be 6.35 again, just minute hand will be forwarded clockwise 12 full circles, while hour hand will be forwarded 1 full circle). Push the crown back in.
2) Pull the crown out to the date setting position and change to the desired date. Pull the crown back in.
Now your watch will be changing dates at midnight continuosly.
Rate me, please.
Posted on Apr 04, 2009
SOURCE: lost the beep on my timex watch alarm
Try taking the back off and orientating it the other way (i.e. turn top for bottom). You don't have to screw it down to see if this will work. As soon as the back clicks in you will be able to hear beeps as you press the buttons
Posted on Jun 11, 2010
Hello i have replaced the battery on my tissot t touch expert & display not working? Any suggestions. Battery was completely dead before change?
If the battery was dead too long the fumes from the battery might have damage the electronics and that's not good it will have to go back to tissot for a new movement What I'm going to tell u is very inportant. Never let a watch set dead I don't care if it's a windup or an automatic or even a battery watch. U must always keep the running because all the lubriactions will set up and not performed properly. Just like a car setting dead too kind In ur case the battery has cause the problem
Apr 22, 2017 | Tissot Watches
Tip
After six years my battery is low, so I took my Tissot Touch back to the shop...
When you need frequent re.Syncronizing of your Touch or after 2-3 year
maybe you need to replace the battery.
you need:
a CR1632 3V Battery (about 2€)
a very tiny screw driver
a very sharp knife
With the knife remove the bottom of yout Tissot, (you do not need to unscrew) it's just a cover to pull up like in this imagedcef0c0d.jpg
Now you can clean with a soft brush & remove the dust.
Use the screw drive to replace the battery,
put back the cover & enjoy
on Aug 29, 2009 | Tissot T-Touch T33759851
Tissot t-touch battery problem
If you take a jeweler's lupe near where the arrow is you will see the word "reset" in the plastic.
There is a deep hole in the plastic with contacts below. That is the reset, and that is why you must use very sharp pointed tweezers to make contact with the back of the battery.
I think if you do not have sharp tweezers, you can probably put a sewing pin down the hole, and then connect with a small screwdriver to the back of the battery
Jan 30, 2013 | Tissot T-Touch T33159851 Wrist Watch
Why would a tissot t-touch need an overhaul to replace a dead battery
These babies are notorious for going down the tubes with a battery change. I bet if you get it back it won't work with a new battery. Twice I have replaced batteries and the watch didn't work when I finished. One of them was my own watch, I think $450 is about half the price of a new watch and that is sad. Cool watch just not very long life
Oct 01, 2012 | Tissot T-Touch T33759851
Wrong airpressure reading in my Tissot Touch
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all TISSOT watch manuals.Rate me, please
Mar 22, 2010 | Tissot T-Touch T33159851 Wrist Watch
Stuck on 02.10 hrs
You have to change battery. 3 years was a quite long service time for one battery. After replacement your watch will work as brand new. Rate me, plz.
Feb 03, 2010 | Tissot T Touch Navigator 3000 T96.1.488.42...
Digital readout on the titanium touch reads bAE.
battery almost empty? sounds about right... I just got this now
Feb 23, 2009 | Tissot T-Touch T33759851
Tissot T-Touch T33.7.788.51 Bracelet replacement
Sounds like it's broken @ a factory sealed link (non servicable). Local jeweller should be able to order & fit you a new one
Feb 19, 2008 | Tissot T-Touch T33759851
Watches Logo
142 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
