Question about Canon imageRUNNER 7200 Copier
I have a canon ir 7105 . now the copy coming light . i chenge the toner but the the fault is there
4 Suggested Answers
  • 11 Answers
SOURCE: canon iR 7105
The Tray A Area Sensor Unit may be faulty. Replace the Sensor
Posted on Oct 28, 2008
SOURCE: We have a Canon IR-7105
it is a transfer corona problem ,clean it first.even its not ok change the corona wires.
if its not ok finally change the transfer corona .
Posted on Jan 21, 2009
Cogz
  • 1326 Answers
SOURCE: i have this machine Canon IR 7105 B&W
Odds are is that the finishers exit bins got stuck while looking for it's HP. Most of the time it is a garbage can.... Move the object blocking the path of the exit trays first. Then turn the power switch for the finisher off first then turn the main power switch on the right side of the copier. Once it is all off > turn the finisher back ON first then the copier and then remove the paper jams.... Good Luck
Posted on Apr 25, 2010
Hi, I want to know about Canon Image press 1110/1125/1135 these copiers use which type of toner. Can we put IR 5000 or IR 7105 toner in them How is the drum
no you can not, the toner in a image press is a dual component toner. in the 5000 and 7105 are a mono component toner please dont and if you did please tell the tech because it will drive him crazy trying to figure it out unless he is a veteran in the copier business.
Oct 17, 2015 | Canon Office Equipment & Supplies
Ir 7105 black copy is appear
I've had the Laser go bad on two occasions causing black or partial black copies
Feb 07, 2015 | Canon Ir7105 Ir 7105 Copiers1saddle Stitch...
What are the steps to solve light copies with canon ir 1024 copier
Did you clean the optik lens,mirrors...?It may also be a transfer roller,try to clean or replace it.
Sep 03, 2014 | Canon IR-1022 Copier
Error code e121
Reader controler cooling fan fault replace the fan or dc board
Jul 17, 2013 | Canon Ir7105 Ir 7105 Copiers1saddle Stitch...
Out of toner cheng
Clean the toner of dp unit baising
Jan 22, 2013 | Canon iR 2016i Black and White Copier
Canon IR 7095, error code E000005-010
Hello to all
I have a client server ir Pass has forgotten his password and I reset.
how reinitialiser server S2 canon ir Pass?
Thank you for the help.
Dec 27, 2012 | Canon Imagepass S2 Fiery For Ir...
Ir 6570 copy light
When you were replacing the drum did you tuch the drum surface?Best would be that you take some toner on piece of cloth, and polish the drum, while turning it in good direction, that the cleaning blade can clean it.After you must let it copy about 50 copies.
You can try to replace the whole drum unit cexv14, or clean the laser unit.
Also could it be that the toner unit, or toner cleaning blade are not properly distibutes the toner accross the developing/toner cylinder
May 07, 2012 | Canon Office Equipment & Supplies
Code e566 ir 7105
It is a fault in the Horizontal Registration. It is most likely caused by a bad fuse pcb, front door switch or safety switches
Mar 07, 2012 | Canon Office Equipment & Supplies
Copy darkness problem canon image runner 2830
Did you try to clean beneath the copy glass?
On digital machines, when the copy glass or optics are dirty, copy becomes verry light.
How many copies do you have? pres 123 button.
It also could be that you need to change the toner station, by the book it goes 300000 copies.
But I bet on dirty copy glass and dirty scanner assy.Clean the glass with glass cleaner and polish it with dry cloth.
Jul 25, 2010 | Canon imageRUNNER 2870 Copier
Canon iR 7105
Oct 27, 2008 | Canon imageRUNNER 7200 Copier
Canon imageRUNNER 7200 Copier Logo
252 people viewed this question
old marine
old marine
