Sony VIAO will no longer power on
With the power adapter plugged into the laptop and the wall, the laptop will not power on. (won't power on with it unplugged either)
This is a Sony VAIO VGN-A600.
It is owned by a surgeon, and he needs the data from the harddrive. What do you recommend?
  • 1 more comment
  • clyons02 Jun 02, 2008
    thanks, will give these options a try!
  • Mike N Jan 24, 2009
    It does not turn on with or without the battery...it will never charge
  • dman1234 Apr 05, 2009
    my sony vaio wont power on anymore
    Sergeant:
    Champion:
  • 317 Answers
Try running it without the battery in, and only the wall charger plugged in. otherwise it sounds like it is a bad charger or possibly even battery. if this still does not fix it, then it could be that the power converter on the laptop has burned out.
Posted on Jun 02, 2008
Dell inspiron 1520 won't turn on.
Remove the battery from its compartment on the side of your Dell Inspiron laptop computer.
Remove the power adapter from its plug on the side of the Dell Inspiron (if your laptop is currently plugged into a wall outlet).
Press down and hold the "Power" button on the laptop for one to two minutes. This will dispel the excess electrical current that is built up inside the laptop.
Put the battery back inside the compartment of your Dell Inspiron.
Plug your power adapter back into the side of the Dell Inspiron. Press "Power." Your laptop computer will now turn on.
hope this helps
Oct 08, 2012 | Dell Inspiron 1420 1501 1520 1521 1525...
Acer one notebook no display and automatic shutdown
= if your laptop computer will not start =
laptops have power supplys that can lock up
the power adapters conectors break all the time
and the batterys are designed to be "con$umable$"
so
- - -- - -- - -power reset - - -- - -- - -- - -
remove the power adapter's wall plug &
leave the power adapter plugged into the computer
but pull the laptop battery out of the laptop.
press the power button just like you are trying to start it
but press it longer, this will drain & reset
the internal supply, now relese the button.
-- - -- - -power adapter only test - - -- - -- - -
reconnect the power adapter's wall plug
press the power button to start it with just the power adapter ,
If the power adapter starts the laptop on its own go down to
"If the computer can be started"
If the power adapter does not start the laptop on its own
leave the power adapter plugged into the computer but
remove the power adapter's wall plug & press the power button
just like you are trying to start it again,
then relese the button
- - -- - - battery only test - - -- - -- - -
unplug the power adapter & put the battery back in
press the power button to start it with just the battery
if the battery starts it on its own go down to
if the battery ALMOST starts it on its own
DO NOT BUY A NEW ONE! it may only be discharged
locate another laptop just like yours and charge it,
and yes this is crazy and yes i am sorry!.
- if your laptop computer cannot start at all -
this can be caused by a bad;
connector ($5-$60), power adapter($5-$60),
battery ($70), internal supply ($40-$90),
or main/mother board ($100-$300)
If the internal power supply is bad or if the
power conector fails at random (intermitant)
most of the cost is determined by how dificult
finding parts and dismantling the laptop is
and if it's external or internal
Jun 05, 2010 | Acer Aspire 5720-6661 Notebook PC
Screen is dead
  1. turn off the computer
  2. take off the ac adapter and remove the battery
  3. reseat RAM/memory
  4. without the ac adapter and battery, press and hold down the power botton for 7-10secs
  5. reconnect the battery and ac adapter
  6. try turning it on
hope this helps
Mar 02, 2010 | Sony Computers & Internet
Sony viao wont boot, battery light flashes amber once when power button is pressed, AC power indicator on laptop is green and responds to being un-plugged and the adapter LED is green,but it still wont...
Move the power jack around while plugged in, does the blinking on the battery stop when you hold it in certain positions? If so, your dc-jack needs to be soldered, but i probably was loose already before you started using it. It could be a broken motherboard issue as well. You can try to open the laptop and check the dc connection. There is a Laptop Repair Guide that shows you how to take apart a laptop, the sony may be made in a similar way. Sony Repair NYC
Jan 17, 2010 | Sony VAIO VGN-N325E Notebook
Short beep on boot then nothing pcg-9241 sony viao
the fist thing you want to check is the memory. try alternating sticks with battery out and ac adapter un plugged. make sure you are grounded and off carpet. try that first.
Dec 10, 2009 | Sony Computers & Internet
I have a sony viao vgn-c210e. but there is an x
u r laptop battery has dead u need to replace it
Jul 29, 2009 | Sony VAIO VGN-C210E/H PC Notebook
Vaio sat survey has stop working
Do the following:
-unplug adapter from the wall
-unplug from the computer side
-remove the battery
-With everything unplugged and battery removed, press the power button.  Keep holding it down for 15 seconds
Yes, nothing happened, that is ok. :)
-re-insert the battery first
-plug the adapter to laptop side first
-plug adapter to wall socket
Now, turn on the laptop and see if it powers on.
Jun 28, 2009 | Sony VAIO VGN-CS118E/P NoteBook
Dead Sony Laptop
If power supply is supplying correct voltage, then you do not need power supply PCB.
Try starting the laptop with AC adapter and no battery, if battery is shorting out you may get same problem.
Test the soldering joint on the AC socket and laptop motherboard, if there is a bad soldering on laprop ac adapter socket, you get same symptoms.
If it is none of the above, and the adapter is fine, then it is usually a faulty motherboard.
Nov 16, 2008 | Sony VAIO PCG-V505CP Notebook
Sony Viao, won't power up
Sir,
you remove your Laptop main battery and adaptor for aprox 10 min then fix again battery and adaptor then on power button m/c is on.
Mar 06, 2008 | Sony MBX-49 ASSY Motherboard
Computers & Internet Logo
240 people viewed this question
David Payne
David Payne
