Question about Toshiba MW24F51 24 in. TV/VCR/DVD Combo
Conversion to hd
How do I get the unit to tape to the vcr once the hd conversion box is installed?
  • 1 more comment
  • historyguy Jun 02, 2008
    I have powered rabbit ears; how do I get it to tape using the converter box channels (it now keeps taping from the fuzzy channels with no antenna)?
  • historyguy Jun 03, 2008
    Nope, when I try to tape,  it insists on going through the antenna instead of the converter box.
    If I try to set a timed taping, for example, it will tape channel 10, but it will be fuzzy and not the clear picture presented on the converter. However, if I start taping using the remote, it tapes whatever channel is on the converter, in other words, channel 10 (really 10.1) is really clear.
    I hope I have explained this better.
    1. The Toshiba is a tv/vcr/dvd combo, does that matter?
    2. There is no "f" connector, there is an "RF" connector.
    3. I used to tape using timed settings before with no problems.
  • 4,234 Answers
First of all, you will only need a box if you are currently using an exterior antenna. If you have sable or satellite, no box is needed. If you need the box, it will allow normal operation of the set. That means that however you tape now will continue to work.
Dan
Posted on Jun 02, 2008
  • ABRsvcs Jun 02, 2008
    WIth the converter box, the HD digital broadcast signal is converted to an analog signal that the TV can understand. If your reception is better with the digital signal, the VCR will still be receiving the analog signal through the "F" connector on the back of the set. If you are currently having problems with taping, these problems are independent of the conversion. In essence, the converter box will present similar signals to your TV as exist today.
    Dan
Can not get to hook up ot tv
Your new TV is digital. Your VCR is for the obsolete analog NTSC broadcast standard. The two devices are totally incompatible. There are converter boxes available. The quality of the playback will be very poor compared to the picture you now see on your high definition digital TV. The NTSC picture is made up of 525 lines. The best home VCR reduced the resolution to about 350 lines. Your new TV is very high resolution by comparison with a much larger screen in all likelihood. The large screen will exaggerate the poor quality. The process of sending the signal through a converter box will reduce the resolution even more, although digital enhancement with a computer or a dedicated device can marginally improve the results. In the end, you will probably be very unhappy with the resulting picture. If you have video tapes you need to convert them to a digital format using DVD or BlueRay disks, for example. Once converted, you will need a a BlueRay or DVD player for playback to your TV. There are devices for making the conversion or you can send you tapes to a company that will covert the tapes for you. If you do a google search, for video to DVD conversion services, there are many choices. I would suggest that you just have your tapes converted to archival quality DVDs. The sooner you do it, the better because tape degrades in a relatively short time. The tape has a sync track along one edge and as the tape stretches (they always do) by just sitting on the shelf or being played, the player will no longer be able to play the tape and your memories will be lost forever.
Mar 11, 2014 | Televison & Video
LG DVD VCR combo recorder RC689 doesn't record in VCR
I see a RC689D model. It DOES record via VHS and it should do so as you have done before. Go through all of the steps in making sure the tape(s) you're trying to use isn't missing the "Safety" tab, look at the tape to make sure there are no defects, and make sure you are receiving a signal to the VCR. With most signals being "Digital" and not analog, I would assume you are trying to pull your signal from either a digital box, a Satellite feed, or a cable feed.
Try "Daisy chaining" your VCR from your output box using the following method(s):
Signal coming to box> (1) Coaxial or Cable hookup from box to VCR> (2) Red White Yellow connectors from source to VCR> VCR output using same method(s) as input from source to TV> make sure your TV is set to the correct channel; usually notated as either channel 3 or 4.
If you cannot get the VCR to record correctly, and you have checked and verified all of the input\output cables are properly seated, and you are getting a signal from the VCR to the TV, then it is possible the unit may just be faulty, in regards to recording onto a VHS tape.
Hope this helps.
May 01, 2017 | Televison & Video
I have just bought a 40 inch HD LCD TV, I want to purchase a combo VCR/DVD HD to be able to record channel 11(the new free to air channels HD). Big W gave the model No. RC 689 D to me but they were not...
The VCR/DVD combo that you purchased will be able to record what you wish to a VHS tape at low quality or to a DVD at a higher quality.
  1. Coax cable (round and screw on) from the antenna to VCR/DVD
  2. Coax/AV/HDMI cable (only need 1) from the VCR/DVD player to TV
  3. TV on and turned to the input matching the cable you used in step 2
  4. Turn on VCR/DVD and use the remote control included with this unit. Not the TV's
  5. Turn it to the channel 11 on the VCR/DVD
  6. Put in a VHS tape or DVD-R to record onto
  7. You will be able to hit record whenever the show comes on or used timed recording in the menu to schedule it ahead of time
Sep 14, 2011 | LG RC389H DVD/VHS Recorder
Taping VHS through HD Set Box
as i am aware of you can only tape sd programs on to vcr and not hd.
May 26, 2010 | Emerson EWV403 VHS VCR
I have a Sylvanis VCR/DVDcombo and a Standard TV.
The converter box receives hte digital signals and converts them into either channel 3 or 4, or into direct video (red,white,yel). The output of the converter box must go into the VCR input for recording to work. Before the conversion, the tuner of hte VCR would receive the RF signal the same as the TV. The tuner inside the VCR is an analog tuner not digital, so it needs the conversion too. Most converters will provide both the A/V signal (R/Wh/Y) and RF (coax connector).
Hope this helps,
Dan
Sep 30, 2009 | Sylvania 6720FDG 20" TV/VCR/DVD
Comcast Digital Conversion box (cable TV)
You will have to split the signal before it goes into the digital box. The digital box is not allowing the analog signal to go to your vcr so you will only be able to record what you are watching on the cable box (on channel 4). If you split it, you will get all your analog channels back on your VCR (the way it was before the box was added).
Jun 29, 2009 | Allegro DVD/VCR ABV511
Can we tape digital feed on a VCR and play it on an HD-ready tv?
You should be able to accomplish this. Run the antenna to your converter box. Run the video and audio outputs of the digital converter box to the inputs on your vcr. Your vcr should then be able to record the program (select line-in as the channel when setting up the recording). Hook your vcr audio and video output to your tv.
It's best to use a converter box that has an event timer - this allows the converter box to turn on at a specified time and channel. Otherwise you will need to manually set the channel you wish to record on the converterbox, and leave it turned on.
Mar 10, 2009 | Mitsubishi HS-U560 VHS VCR
VCR will not record
yes your hook is all correct...but still will not work......unless this is a d-vhs recorder...(and the other way to record hd is dvr)....(note dont throw the standard vcr away) it might and can be use later down road
Jan 15, 2009 | Proscan PSVR73 VHS VCR
Memorex MVD4544 VCR will not record
Take the unit back to the store and exchange it for an other unit of the same. The likelyhood of two units not working is very slim, and good luck with your new unit.
Jan 26, 2008 | Televison & Video
PAL to NTSC conversion
This is not a converting unit, it will play the format of the tape inside. To convert the signal you need one of the following:
1) A converting VHS player; they are fairly expensive.
2) A separate video converter (hardware); they run for about $200-$500; just put this between your VCR and the TV.
3) Capture the PAL on your computer using a software like Movie Maker via a Firewire cable. Than convert it to NTSC on your machine using software like Nero... do a search on Google for converting software. Or just watch it on our computer in PAL format, most computers do that... For this step I use a separate camcoder that has a passthrough feature. The VCR connects to it and the camcorder connects to the computer via Firewire.
4) send the PAL tape to a specialized shop for conversion. They normally charge $30-$40 for a regular 2h VHS tape.
Jan 20, 2008 | Philips DVDR3435V/37 DVD Recorder/VCR
Televison & Video Logo
65 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
