Question about OKI C3530N Color MFP Printer
My oki c3530 says Power off/on Home Position Error how can i fix this
How can I fix oki c3530 231: fatal error 03?
RFID Reader I/F Error An interface error was detected
with the RFID reader device.
01: communication error between
the RFID reader and the engine
PCB.
02: the transceiver circuit error of
the RFID reader.
03: communication error between
the RFID reader and the Tag
chip.
04: the RFID Tag detection error
Jun 21, 2014 | OKI C5800Ldn Led Printer
073 fatal error in OKI c3530
Oki ERROR 073 is a H/W Overrun detect. this occurs when the video circuit has set the overrun bit. Restart the printer and check the first print out. Try printing a different job and then reprint the same job that the error occurred. If you get the same error again, try using a different driver, ie swap from PS or PCL whichever you were using to see if that clears the error.
Dec 28, 2009 | OKI C3530N Color MFP Printer
OKI 3530 MFP Service call: 150
Your error 150 is the toner sensor board not making contact with a drum and therefore not blowing its fuse. Remove the Main board and you will find the toner sensor board behind it. It has a lot of metal contact springs and you will most probably find one is out of position and just requires removing and refitting. If still not working the part number for the board is: 43614901 OR-Board-PRS
Good luck.
Jul 09, 2017 | OKI B4350 Laser Printer
OKI C3530 Fatal Error 031
Hi.. i only remove the memory ROM in the board and refixed it, then i turn on the printer and now its working :)
thanks Admin
Feb 19, 2009 | OKI C3530N Color MFP Printer
OKI C3530N Multifunction Printer
Check the left side of the drum cartridge.
There's a little door that may be stuck closed.
Carefully push it open with a small screwdriver.
Oct 31, 2008 | OKI C3530N Color MFP Printer
Toner sensor error on an Oki C3520 Laser
Check the little switch/door on the right hand side of the drums.
This has worked successfully for me.
Symptom:
After replacement of a C3530 Image Drum, the message, "Toner Sensor Error" is displayed.
0.10a?openelement&fieldelemformat=gif
Cause:
The plastic shutter in the ID is fully or partially covering the toner sensor window.
Resolution:
Move the cover upward to allow for the sensor to become fully exposed prior to reinstalling the drum.
0.106?openelement&fieldelemformat=gif
Oct 18, 2008 | OKI Electric Industry C3520 Laser Printer
Error Code 155: Fatal Error
Looks like a fuser error-
re-seat fuser
check for paper scraps, etc in fuser and printer.
Service call
155: Error
Defective fuse
cutting of fuser
Is the fuser installed correctly?
Does the error recur?
Reinstall the fuser after its
connection connector is cleaned
if error still exists-
Turn on the power supply again
Replace M32 board after check
the cable connection.
Jul 29, 2008 | OKI KIT-C3530N MFP LASER CLR P/S/C/F USB...
OKI C3530 MFP
Looks like a fuser problem.
Re-saet the fuser.
Check for pieces of paper, etc. in the path.
Service call 155: Error
Defective fuse
cutting of fuser
Yes
If error still exists_
OKI C3530N Color MFP Printer Logo
306 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
