Question about Magellan Maestro 4040 GPS Receiver
Charge Problem I have a Magellan Maestro 3100 and whenever i turn it on it say's critical battery with my car charger plugged in. It turns off in about 10 seconds of use. The light on my charger still works, but for some reason it's not charging my GPS. Do you think there's a problem with my charger or the battery on my GPS? Please someone help me, thanks!
  • Anonymous Jun 05, 2008
    I bro
  • cmcloca Dec 30, 2008
    i am trying to charge my gps and it doesnt even turn on. can i charge it on my computer
    Sergeant:
  • 250 Answers
Hello guitarman249,
It sounds like a bad battery. Theoretically, it could be the charger but if the red light on the charger still comes on when the unit is plugged in then the battery is the more likely culprit. The only way to really know for sure is to try charging the unit with a different cable, such as the USB cord used to connect the GPS to a computer. The GPS should charge when connected to USB. If it doesn't, then it's the battery.
Like most GPS receivers, the battery on this one is not replaceable by the user. If you do determine that the battery is causing the problem you will need to contact Magellan tech support to arrange a battery replacement.
Best Regards,
Ken
"Go Ahead. Use Us."
Posted on Jun 02, 2008
Magellan Maestro 4040 won't turn on with and wiothout chargers, car and 110 v. Will turn on very briefly and turn off again saying the battery is critically low. This is even after being on 110 v charge...
hi jaykremer
The following advice pertains to the following magellan gps systems.
Magellan 800, 860, 2000, 2200t, 2500, 3000, 3050, 3100, 3140, 4000, 4040, 4050, 5310 and 6000t
i fix these and many other magellan gps daily so when considering my advice , please understand i do not google my solutions.
assuming your car charger is working (the little green light is on) and your magellan still wont start up after holding the power button while its plugged in for up to ten seconds and still does not start..read below
this is actually a very common problem with these magellan power ports...they are poor quality from the factory and always and i mean always fail..the new ports that you find on ebay are 100% better then the factory port.
if your able to replace that power port yourself, you can get one HERE, if not, ask the fellow that sells them for help.
due to some dubious "experts" on fixya, im not permitted to help you directly, but please follow the link above to get further help.
let me know if you need more help or info
Bill
Standing Member of G.O.T.
Please Support Our Troops
Dec 31, 2010 | Magellan Maestro 4250 GPS
My Magellan Maestro 31100 won't power on
You could have a defective power connection in your Magellan Maestro 3100 which will not allow you to charge the internal battery or power on your unit.
You may try to contact Magellangps.com or Autonav2000.com to see if they can provide you with repair service.
Might be cheaper to purhcase another Magellan Maestro than spend the money on repairs.
Good Luck
Apr 03, 2010 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan maestro 3100 will not hold a charge
this is very common problem with this and many model magellans.
try the car charger.
make sure green light is on the car charger and let it plugged in for awhile, then hold the power button (up to ten seconds) until it starts..if that fails
the following magellan 2000, 2200t, 2500, 3000, 3100, 3140, 4000, 4040, 4050 and the 6000 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...
you can get it repaired, here
or buy the port here
if you need further help, just let me know.
Dec 02, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
My Magellan Maestro 3100 GPS unit won't charge anymore. I've seen 2 possible explanations for this problem. #1: The DC power port is broken #2: The battery won't hold a charge any longer How do I determine...
if it starts, you can verifiy if its charging by going to the system settings then power options. the green indicator should be moving left to right. this indicates its charging.
if you disconnect the battery, your magellan should still work while plugged in if the power port is ok.
Oct 15, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
My magellen 3100 battery will not charge
its probably not charging...very common problem with this and many others.
make sure green light is on the car charger and let it plugged in for awhile, then hold the power button (upto ten seconds) until it starts..if that fails
the following magellan 2000,2200t,2500,3000,3100,3140,4000,4040,4050 and the 6000 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...
Oct 09, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Why does my magellan maestro 3100 turn off immediately after I turn it on?
Hi catscan990 Its probably not charging, but plug it into a known good charger and let it charge for a few hours then see if it starts.
press and hold the power button for upto 10 seconds or untill it starts.
If it starts normally and is still plugged to the charger, go to the main menu/options/power and see if the changing indicator is moving from side to side. If it is not moving,
The following Magellan 800,860,2000,2200t,2500,(crossover) 3000,3050,3100,3140,4000,4040,4050,5310 and the 6000t are known to have faulty dc connectors...if your Magellan
You may also have another issue with the screen but you need to find out why its not charging 1st.
You can get it repaired
here
Or buy the port here
Let me know if you need further help!
Bill
Sep 19, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Unable to charge the 3100. If charged via car
the Magellan Maestro can not be charged using the USB connection.
make sure green light is on if using the car charger and let it plugged in for awhile, then hold the power button (up to ten seconds) until it starts..if that fails
The following Magellan 800,860,2000,2200t,2500,3000,3050,3100,3140,4000,4040,4050 and the 6000t are known to have faulty dc connectors...if your Magellan gps is not charging or will not power up, its most likely the dc power port.
you can get it repaired here
Sep 09, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Battery critically low. Turns off soon after it is turned on plug when plugged. Won't come on if not plugged on.
Aug 31, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan maestro 3100 turns itself off
Try using the RESET button . Make sure the battery is holding its charge
Jan 20, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Start-up instructions
I'm confused? Did you plug in the charger or the computer adapter. It needs to charge using the power cord. The USB cord will likely not charge this unit.
Aug 19, 2008 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan Maestro 4040 GPS Receiver Logo
141 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
