Question about Zanussi Refrigerators
I have an older fridge freezer which has 3 lights in fridge ,1 for if ive left the door open, 1 for i think tempreture and 1 with an s on also a on/off switch.I just purchased this 2nd hand and its great but it keeps beeping and flashing the tempreture light,also the freezer is not keeping things really frozen even though i have put it up to 7.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 210 Answers
What make and model is this unit. It sounds like it could be an error code. Possibly a thermal fuse or something in the defrost cycle. Try unpluging the unit for 15 mins and plug it in again. It will at least reset it and it may run until it hits the defrost cycle again. You are most likely going to require service.
Sgt 48
Posted on Jun 02, 2008
My Miele Fridge Freezer Keeps Beeping Although there is no issue, how do i remove the alarm?
I bet the light is also staying on inside even if the door is closed. There is a switch inside that turn the light on and off when the door is open. If the (Door Switch) is working then the light inside should shut off when the door is closed to save energy. It also tell the computer the door has been shut in case you forget then it will notify you. The switch may not be working. Look for a door with on ebay or sears. Need your model number and brand of the unit.
Sep 20, 2016 | Miele KFN8762SDED Bottom Freezer...
Freezer is all frozen
One solution:
This can happen if door has been left open. To solve:
Red light on for High Freezer Temperature Warning
or freezer not cooling, but fridge is and a lot of noise from compressor.
Also, fridge drain hole blocked, water in bottom of fridge.
This is a common fault in Hotpoint Fridge Freezers and can also happen if the door has been left open or has been a power cut.
1. Turn off fridge freezer, or at least turn down the freezer temp to minimum, though not ideal.
2. Open freezer door and remove all drawers.
3. Remove the back panel on the inside of the freezer. This is held in place with 4 screws, which might be 6mm hex head or star allen head. Pull the panel out.
4. Behind where the panel was, there is a cooling element for cooling, pipes, and below this a temperature sensor. If the fridge freezer is not switched off, then fold together a few layers of tinfoil and wrap around the sensor.
5. Use a hairdryer to slowly melt the ice. Melt it around areas where it appears to be hanging on, such as the corners of the cooling element or bolts, as well as any thin sections below the main block of ice around the cooling element, which will be supporting the main block. Use a plastic ice scraper to remove ice but not near pipes or sensor.
Warning: Be careful using electrics around water & melting ice & drips.
6. Below the cooling element, there is a drip channel & drain hole. If this hole is full of ice, pour a small amound of warm water down, leave for 10 seconds and pour a bit more until clear.
In the fridge, clear the drain hole in the same way.
Warning: Do not pour a lot of water down, as this water drains onto a tray above the hot compressor at the rear of the fridge freezer to be evaporated by the heat of the compressor and the tray will only hold a small amount.
7. When all ice is removed, dry all moisture. Put the shelves back. Close door. Turn on fridge freezer. Turn up the freezer temperature to your normal setting. Turn on fast freeze if available. After 1 hour, check with a thermometer. It should be cold enough after 1 or 2 hours.
Oct 28, 2013 | Samsung RF265AA Bottom Freezer French Door...
Freezer side is fine but fridge side wont get below 39 degrees
Nominal tempreture for your refrigerator is 36-38. on the Freezer the tmpreture should be between 0-2. One of the first things to check is on the freezer side is there any frost or snow build up on the rear wall of the freezer. If there were this is termed as a defrost issue. If you do have this issue with frost build up message me back and I will instruct you how to repair this issue. Another thing to check is if the evaporator fan inside the freezer is blowing the cold air into the refrigerator. The Freezer section is the only area that produces the cold tempreture a fan blows the cold air off the evaporator coils through a damper door that opens and closes depending on the tempreture the refrigerator side is set to. Also check the damper door for any ice build up as well this would cause the door not to open and close and remain in a stuck postion. This would cause inadequate tempreture in the refrigerator side as well. If you have any questions or need any schematics or step by step instructions message me back the model number of your unit and I will provide these and answer any further questions you may have. I await your reply
Thank you
Rick
Jul 12, 2012 | Frigidaire Refrigerators
My hotpoint ff187 fridge/freezer is making a beeping sound and has flashing lights. We have tried everything from turning off this button and that, then trying the power off and backwards again. There is...
clean the door rubbers and sides this sometimes fixes the problem as the seals are not closing properly and the fridge freezer thinks you have left the door open.
Feb 09, 2018 | Hotpoint Freezers
Is it right what they say " The higher your number on the tempreture gauge the warmer it will be inside the Fridge/Freezer
#1 is warmest #2 is cooler#3 is colder etc.....fridge should be between +2C to +5C and a freezer -18C or lower(-20)
Sep 17, 2010 | Refrigerators
The fridge does not seem to be cold.
if just the refrige isnt cold,check the damper door located between the freezer and refrige compartments and see if its open to let in cold air from freezer,if not sometimes they freeze shut and cant operate with temperature setting changes/if nothings cold,then replace the ptc overload relay located on the compressor body,it just unplugs off the compressor
Mar 23, 2010 | Maytag ZigZagW / B Side by Side...
SMELLY FRIDGE
I would move the fridge and check what is under it.
Dec 07, 2008 | Kelvinator 12 cu. ft. / 340 liter Chest...
Haier HRF10 Fridge weird motor sounds
hi. thanks for the question. leaving the door open ,would let a lot of moisture to enter the freezer, and cause it to frost up. to clear frost. cut power to fridge, open the doors .,let thaw over nite clean up the water mess. dry the inside of fridge & freezer turn power on good to go. to stop the door from being left open .lift the legs under the front so the fridge has more weight, and it will close by self . no more doors left open. thanks the appliance doc
Sep 28, 2008 | Refrigerators
Have a hotpoint rsf60 fridge/freezer,noticed over temp red light on, defrosted as ice buid up on top shelf of freezer.light still on red temp set at 3/4 ?
The red warning light will not go out?
1. Has the fridge freezer just been
installed? If so, this is normal and the
light will go out when the correct
temperature has been reached.
2. Has the fridge freezer been loaded
with a large quantity of food? If so,
the light will go out when the correct
3. Have the doors been closed
properly?
Jul 01, 2008 | Hotpoint Refrigerators
Refrigerators Logo
135 people viewed this question
Top Zanussi Refrigerators Experts
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a Zanussi Refrigerator Expert? Answer questions, earn points and help others
