Question about IBM Infoprint 1120 Laser Printer
Printer stuck on Perfoming Self Test
How do you get past test mode
  • 734 Answers
Step1
If you're setting up the printer or changing the toner or ink cartridge for the first time, double-check the instructions to make sure that you installed the cartridge correctly and, for new printers, that you have removed all the pieces of cardboard or plastic packing material.
Step
Check to see whether paper is feeding from the paper tray. If it's not leaving the tray at all, try feeding a page manually (if that's an option) or using a different paper tray. Sometimes a problem with the tray can be traced to a broken spring or a piece of plastic.
Step
If paper is feeding from the tray but jamming in the printer, examine where the jam is occurring and then inspect the printer carefully to see if you can find what is causing the problem. A piece of paper, for instance, might be blocking the paper path.
Step
If paper is feeding through the printer but coming out blank, check to see whether the printer is out of toner or ink. A defective toner or ink cartridge could be the problem.
Posted on Dec 04, 2008
Error code 1200 is showing?? help!!
The error 1200 indicates that the cartridge carrier is stuck inside the printer. Please follow the steps given below:
1. Unplug all cables from the back of the printer.
2. Open the front cover and look above the steel rod. You should see a black belt with rubber teeth on it. (On some models, the cartridge access is very small, but the belt should still be visible.)
3. Take the top part of the belt and move it gently to the right. The cartridges should come towards the center.
4. If the cartridges will not move, tilt the printer on its back and try moving the belt again.
5. If it still will not move, try putting your finger inside the area where the cartridges are stuck (with the printer still on its back), and push them firmly against the cartridge carrier holder while you move the belt with your other hand.
6. Once the cartridges are in the middle, snap them firmly into the cartridge carrier. Note: Make sure that these cartridges are the correct models for your printer. Once the cartridges are seated properly, they should not become loose inside the carrier.
7. Plug all the connections back in and power the printer up.
8. Open the front cover again to see if the cartridges slide to the center.
You should then try to self-test the printer. The self-test allows us to rule out software and the cable by testing the hardware by itself. Please note that this is not a "fix," but rather a diagnostic test to determine if your hardware is at fault.
Please begin by disconnecting the power supply from the wall (not the back of the printer) for at least "30 seconds." Then plug the printer back in and follow these steps:
Next, try this printer self-test by following the steps given below:
1. Press the "Copy" button once.
2. Press the "Options" button 11 times until the screen reads "Maintenance."
3. Press the "Left Arrow(-)" button until the screen reads "Maintenance: Self Test."
4. Press "Select."
The self-test should at least print out a set of either black or color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with the color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues, we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
Oct 01, 2009 | Lexmark X4270 All-In-One InkJet Printer
Getting error message 1203
4. Press "Select."
Aug 20, 2009 | Lexmark X7170 All-In-One InkJet Printer
When I copy the page comes out black
It seems there is a possibility of a problem with the printer itself, or perhaps the cartridges. You should first self-test the printer. Since we are unsure where the problem exists, we must do eliminative troubleshooting to rule out parts of the printing system. The self-test allows us to rule out software and the cable by testing the hardware by itself. Please note that this is not a "fix," but rather a diagnostic test to determine if your hardware is at fault.
Please disconnect and then reconnect the power supply on the printer and make sure it makes a setup noise when the cable is reattached.
1. Press the "Mode" button until "Copy" light comes on.
2. Press the "Options" button nine times. The "Maintenance" option should appear on the LCD display.
3. Press the right arrow key three times. The "Print Test Page" option should appear.
4. Press "Select."
The self-test should print out some text at the top of the page and a black and gray bar below the text. Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service.
May 11, 2009 | Lexmark X7170 All-In-One InkJet Printer
Error 1200 indicates paper jamming. No paper is jammed however the cartridge carrier appears to be jammed on the left hand side. I have tried everything I can find but cannot release it. Even uninstalling...
4. Press "Select."
Apr 20, 2009 | Lexmark X4270 All-In-One InkJet Printer
Printer flashes self test
GO ON LINE AND TYPE THE FOLLOWINF INFORMATION IN THE ADDRESS BAR:
HP PSC 2175 ALL-IN-ONE INKJET PRINTER FLASHS SELF TEST MODE OVER AND OVER
ENTER
SEE IF ANYONE ELSE HAS EVERY SEEN THIS PROBLEM BEFORE
Mar 07, 2009 | HP PSC 2175 All-In-One InkJet Printer
Officejet 6210 All in one stuck in self test mode
Try unplugging the printer for a minute and then plugging it back in.
Feb 26, 2009 | HP OfficeJet 6210 All-In-One InkJet...
HP DESKJET380 NOT RESPONDING WHEN CLICK ON PRINT
After sitting in power save mode for a long period of time the printer might not function properly. This happens when the printer is plugged into a surge protector. Unplug from the surge protector and plug directly into the wall power socket.
Step 1:
Please try to print Self test Print from the Printer (without PC ie. remove the USB cable from the PC)
Step 2:
If the Self test Print is Ok, try to connect your printer to PC
and Print Test Page
Go to Start >> Printers and Faxes >> Select your Printer F380
then Right click Properties and Click on "Print Test Page"
If this prints Ok then all the connections you have made are correct
In case, it does not print then please check your USB cable try to change it
Step 3:
You can uninstall your Driver
and install the new driver, to download the driver for F380 All in One Printer Please click the below link
Choose appropriate Operating System
HP F380 All in One Printer Driver
I hope this will resolve your problem
all the best
Jan 05, 2009 | HP DeskJet F380 All-In-One Printer
Printing Problem in Windows XP
Does it seem to print the Windows test page faster than the self test print? If so it is probably printing the self test in a higher resolution than the Win test print (Win test prints are usually printed in low res)
Try printing a simple graphic or document from a piece of software. First in DRAFT mode and then in the HIGHEST Quality setting. See if you notice the "jerky" sensation in the DRAFT mode.
It could be normal for you printer.
Oct 14, 2008 | Epson TM T88 Thermal Printer
IBM Infoprint 1120 Laser Printer Logo
177 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
