Question about Dell Audio Players & Recorders
Why are my computer speakers making a static noise?
  • 6,826 Answers
I'm sorry, but I got bumped off of our chat by another chat request.
Let me know how it goes, getting another computer speaker set for your computer.
Posted on Oct 15, 2010
  • Anonymous Oct 15, 2010
    Oh, green is the standard output for line out, I read down below.
  • Duane Wong
    Duane Wong Oct 15, 2010
    Unfortunately, I think I got bumped off of the system when we were chatting, losing the connection with you.
3 Suggested Answers
sys_admin
  • 829 Answers
SOURCE: static noise coming out of speakers
What sort of computer do you have? Is it a laptop or desktop? Many laptops have this problem and it is quite widespread in laptops. The crackling or humming noise could be a result of interference from the mains power signal.
If it's a laptop, try running it on battery alone (take out the mains power cord). My laptop has this kind of noise in speakers when running on mains electrical supply, but it goes away like magic when I run it on battery.
A more long-term solution is to buy a 'Ground Loop Isolator' and insert it between your computer and the speakers/earphones. They are quite cheap and you could get it for under £10. It removes all static noise and you'll hear crystal clear sound.
Posted on Jan 01, 2009
sleepy_user
  • 140 Answers
SOURCE: Insignia PC speakers - give a weird static feedback noise
I'm going to vote for the haunted option.
Sound like you have some noise on your power lines. This can be caused from many different things. Normaly it is a motor going bad or a compressor starting up. From the AC unit or refrigerator.
See if you can correspond the noise to anything else happening in the house. Fridge starting up, AC or heat cycling on...etc.
It may be that you just have speakers and a cordless phone going bad at the same time.
It might just be Casper the friendly ghost playing tricks... ha!
Posted on Jan 23, 2009
Nakamichi mini speaker has crackling noise as soon it is switched on
check
the speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line or use a can of compressed air specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
hope this helps
Jul 29, 2012 | Audio Players & Recorders
My speaker making noise if I make it louder
no MOISTURE in the air line specifically around the sound card and the CPU central processing unit
hope this helps
May 14, 2012 | Logitech X-120 Computer Speakers
When I turned on the power for my 'Logitech X-240' speakers, there was a loud static noise coming from the speakers. I unplugged the speakers from the subwoofer, and as I began to plug them back...
clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your SOUND CARD dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Aug 31, 2011 | Logitech X-240 Computer Speakers
I get static interference noise
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
hope this helps
Aug 07, 2011 | Altec Lansing Multimedia Computer Speakers
My right speaker is making a fuzzy noise while my left one works perfectly. How do i fix the right one?
try swapping the speakers around if the problem still persists either the speaker is faulty or
Apr 09, 2011 | Bose Companion 2 Computer Speakers
I have been experiencing static noise/crackling from my front left and right speakers just recently. (I have a 5.1 dell system - the front center - attached to the monitor and rear speakers do not emit...
This seems like at cables have gone bad or either the connections in the speakers went bad. Its best to replace them unless you know how to disassemble and re-soder the connections.
Mar 01, 2011 | Dell WL6000 Computer Speakers
MY speakers are making weird noise, i have logitech x240 and on youtube i can only listen audio, not voice. Everything is connected but its still making weird noise.
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or click start control panel administrive tools computer management device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
don
Feb 26, 2011 | Logitech X-240 Computer Speakers
Static only in one speaker
When you say static that they both work but one is noisy or are you saying that the only one is making a noise and nocoherent sounds coming from either
Aug 03, 2009 | Genius SP-F350 Computer Speakers
Static noise coming out of speakers
Jan 01, 2009 | Dell A215 Computer Speakers
Static noise
Check for the Third earth wire of your computer else check for the motherboard taking earth for the cabinet.
Good luck
Oct 09, 2007 | Dell WL6000 Computer Speakers
78 people viewed this question
Top Dell Audio Players & Recorders Experts
Greg Cann
Greg Cann
Jax Planet
Jax Planet
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
