Question about Friedrich M18CF Split System Air Conditioner
My dads Friedrich floating air wall unit won't stop making a loud noise even though it is powered off. I tried to power it off but it will not stop making this noise, it has never done this and it always turns off with no after noise, it has now been running for hours while off, although it isn't working the way it would be if I turn it on. It just sounds like a motor or something is still trying to run. Any help, thanks!
  • 1,608 Answers
It is possible it is the noise of refrigerant balancing when the compressor shuts off. Does the noise ever stop? Have you turned breaker off??
Posted on Jul 14, 2017
kstfas
  • 75 Answers
SOURCE: Friedrich air conditioning - inside unit ice build up
Hi, Reduced air flow, low on freon or being continuously run during cooler weather such as at night. Some people turn their thermostat on 60 thinking that it will help get it cooler faster. They freeze up at night and don't get a chance to thaw during the day. It needs set no lower than 75 or so. The evaporator may be dirty. Don't know a lot about your particular unit but if the outside unit has the compressor and refrigerant lines running to it, The large refrigerant line should sweat all the way to the compressor if its fully charged. Please rate me if I have helped. Good luck kstfas
Posted on Aug 28, 2007
SOURCE: Friedrich Mini-Split blowing fuse
Low voltage shorts can be a real pain to find!!! i would try a process of ellimination: first i would try to elliminate the thermostat. then id look for a wire that is vibrating on something in the cabinet.
Posted on Oct 16, 2007
Sea Breeze
  • 4655 Answers
SOURCE: compressor makes loud noise when it shuts off
If you know that the compressor is making the noise, I really believe you need to prepair to replace the the air conditioner. If under warranty it would be wise to contact the dealer for options.
Posted on Oct 21, 2007
  • 330 Answers
SOURCE: friedrich challenger air condition remains
automatic thermometer doesn’t function
Posted on Jul 06, 2008
  • 189 Answers
SOURCE: squealing and sometimes doesn't blow cool
A squealing noise is most likely the bearings going bad in the blower motor. This will slow the motor down. If the blower is not operating at the proper speed this will affect the temperature pressure relationship of the refrigerant. This will cause the unit to put out the wrong temperature. Running the unit to long under these conditions can possibly cause further problems ( including a very high electric bill). I recommend that use do not use this unit untill it is repaired or replaced.
Good luck.....
Posted on May 03, 2009
Hi. My dehumidifier stopped working. It powers on, but does not do anything.
Check if the full light is lit. If so check that the float switch is free.
On page 5 step 3 they discribe how the float switch needs to be free?
http://www.sylvane.com/media/documents/products/friedrich-d70bp-dehumidifier-owners-manual.pdf
Jan 16, 2016 | Friedrich Dehumidifiers D70bp
Friedrich quiet master KS12L10 leaking water down outside wall and windowsill.
it may need coil cleaned. there is a drain hole under evaporator coil that might be stopped up.
Aug 12, 2014 | Friedrich QuietMaster RS10J10 Air...
Friedrich wall unit whistles when turned off
it is the automatic valve when it is closed
Dec 14, 2013 | Heating & Cooling
Thermostat friedrich twintemp
try unplugging it from wall and try to reset, power outage might have caused a capacitor to fail
Aug 27, 2013 | Friedrich EL25L35 Thru-Wall/Window Air...
I have a frederick x star Its a wall mounted unit and is excessively noisy at the beginning of a cycle or start up it does not appear to be loose in its mounting though why is it making the noise
This often happens when units get a little age on them. But, they quiet down after 30 seconds or so. Be sure the unit is tightly secure in the window, as the vibration my be caused in part by the unit moving slightly in the window.
Hope this helps you and thanks for choosing FixYa.
Jul 28, 2011 | Friedrich XStar XQ06J10 Air Conditioner
My air conditioner is making a loud noise when I turn it on...even when it is on fan mode. HELP Please!
ir could be the plastic front vibrating, try putting your hand on it and see if you can stop it
May 18, 2011 | Friedrich CP06C10 Wall/Window Air...
Just installed a new Friedrich CP06C10 window air conditioner that I purchased from J&R. Turned it on and it makes a loud rattling sound. I installed a Friedrich CP08C10 window air conditioner in...
its the fan hitting the shroud, look inside for the fan hitting anything and check for the copper lines vibrating against each other, also, it could be the plastic front vibrating, put your hand on the front to see if you can stop it,
Apr 17, 2011 | Friedrich CP06C10 Wall/Window Air...
Squealing and sometimes doesn't blow cool
Good luck.....
May 03, 2009 | Friedrich M18CF Split System Air...
Compressor makes loud noise when it shuts off
Oct 19, 2007 | Friedrich QuietMaster SS12L10 Air...
Friedrich M18CF Split System Air Conditioner Logo
47 people viewed this question
Top Friedrich Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Michael Vincent Cruz
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
