Question about De Dietrich Dishwashers
De Dietrich Dishwasher vw200mi/1
Got this dishwasher from friend. hooked it up,pushed the on button & it's almost 2 hours & still running.Din't get a manual with it so I'm in the dark
bigg t
  • 640 Answers
SOURCE: Dishwasher drain hose.
Its ok to hook to the sink drain but an air gap should be inline with it to prevent sink water from backing into the dishwasher.
Posted on Feb 12, 2008
SOURCE: Problem with Bosch built-in Dishwasher Model SHU6806UC
I had the same problem and just today replaced the control board module. Purchased the control module online and installed in myself. Was not that difficult. undo the screws (torx screw driver needed) unhook the connections to the board and label all. Pull the board out and open, found burned connectors. Now works like a dream.
Posted on May 30, 2008
docjohn174
  • 943 Answers
SOURCE: how to hook up portable dishwasher
Hi. Thanks For The Question. The Adapter Goes On THe Faucet .It Screws On. Then The HoSE From The DishWasher Hooks On To The Adapter Turn On The Water. Plug DishWasher In To The Wall Socket Put Dishes In Lock The Door Push Cycle Good To GOo. Thanks The Appliance Doc
Posted on Oct 03, 2008
SOURCE: GE Nautilus dishwasher wont run
Thank you! Our dishwasher hasn't been working for so long. I've tried spinning the fan to get it unstuck a long time ago but I thought that wasn't the problem. The fan was stuck real tight and i couldn't turn it more than a quarter turn each time. This time it worked!
-Turned off power to dishwasher on circuit breaker
-Removed kick panel
-Used two screw drivers, one to turn the fan till I couldn't any more and the other one to hold the blades in place so that it wouldnt "unwind". Then I would turn the fan some more. It turned less and less each but after repeating about 5 times the fan got un-stuck.
-Turned the power back on to the dishwasher and turned the dishwasher back on and IT WORKS!
THANK YOU!!
Posted on Nov 09, 2008
SOURCE: Leak from a De Dietrich
Pull the built in unit out and tilt towards the rear right leg and the water will drain on to the floor. The Dishwasher then restarts but the anti flood sensor will reactivate after 2-3 more washes. Do not know final fix yet.
Posted on Feb 09, 2009
Where is the flood switch on die dietrich dishwasher dvh640ju1
these are normally in the bottom of the dish washer
micro switch controlled by a float
Feb 15, 2014 | De Dietrich DVH610JU1 24 in. Built-in...
My dishwasher does not deliver water. Switch on and it just switches off again
Here is a tip that will help you to find out why water will not come into thedishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Sep 19, 2010 | De Dietrich 18 in. VW7451 Built-in...
It does not rinse properly, leaving a film on
Pump worn out, using too much soap and depending on where you live there may be a more concentrated amount of minerals in the water. Florida residents are having that problem in spades due to our drought.
Oct 10, 2009 | De Dietrich 18 in. VZ9456 Built-In...
Leak from a De Dietrich Integrated Dishwasher has caused 3 red lights on the left of the Control Panel to flash and also a Blue Light on the right hand side of the Control Panel to flash. On resetting...
Oct 05, 2008 | De Dietrich Dishwashers
Dishwasher
WAS IT IN A CERTAIN CYLE WHEN FUSE BLEW
Jan 17, 2008 | De Dietrich 18 in. VW7451 Built-in...
Wont switch on
try replacing on/off button or replacing the door switch.
thees parts sould be examind by technishian befor replacment.
Dec 28, 2007 | De Dietrich 24 in. DVF120J Built-in...
Built in De Dietrich dishwasher
I suggest you get all your staff to search tirelessly for an answer, ChrissyJ!
Oct 02, 2007 | De Dietrich 24 in. DVF120J Built-in...
Dishwashers Logo
57 people viewed this question
Top De Dietrich Dishwashers Experts
richie46
Are you a De Dietrich Dishwasher Expert? Answer questions, earn points and help others
