Question about MSI Computers & Internet
My mainboad fail to boot. I've checked the ram, power supply and even the procesor:(. i don't have video signal ...
Are you using onboard video or a card? If onboard look in your bios and make sure it is turned ON sometimes the default is off. If you are using a aftermarket video card you may need to use the onbaord to get to your desktop so you can load the drivers for the card then switch your video cable after you shutdown the computer and then try restarting.
Posted on Oct 16, 2010
Asrock G31M-S No Display/Booting
First of all, check if there are any inflated capacitors, if there is even one- ditch MBO, other capacitors will soon follow. If no inflated capacitors proceed with these diagnostic steps: 1/ disconnect all peripherials (DVD, HDD, card reader...), leave only MBO, PSU and RAM (and CPU of course); if nothing happens 2/remove CMOS battery (CR2032) for 20-30 sec with power cord disconected from computer, that will reset BIOS; 3/ take out RAM sticks, then, if you have more than one stick, try with each stick separately (it might be faulty RAM); 4/power on MBO without any RAM-if speaker is present it should give BEEP signals; 5/ try with different PSU, many power supplies are faulty even when they do give power to MBO.
If nothing of above does not help than you have faulty MBO, because CPUs are so rare to fail that in my 10 years of experience in PC service I had 3-4 fried CPU-s, and even that was because costumer tried to clean PC, removed CPU cooler and than incorrectly placed it back or didn't put thermal paste afterwards. asrock-g31m-s-no-display-booting-yuc33qzjuwfqgyyin4u45syc-4-0.jpg
Dec 18, 2014 | Asrock Computers & Internet
My motherboard(ga-6cxc rev 2.0 motherboard) don't show any sign of booting but if i let some part lose it beeps(long) what should I do? even the keyboard don't light up(num lock...) and monitor...
Unplug all of your RAM, expansion cards and IDE/SATA devices. Leave only the processor and the CPU/heatsink plugged in, now try turning it on. If it boots, you should get a ram error, which is normal. If it doesn't boot, either the board, processor, or power supply is bad. Next, reinstall the RAM and start it up again. If it boots again, keep adding parts until you find the one that is causing the problem.
Hope this helps.
Sep 25, 2011 | Gigabyte Slot 1 GA-6CXC-1 Motherboard
This is the strangest thing I've ever seen. I have a Gateway FPD1975W TFT Monitor and its always worked great. The other day it went into a sleep mode via windows, and now it wont boot up the input...
Your monitor problem is causes by the power supply. What is happening is the power supply voltages are not stable, just enough to power the unit up. When you connect it to a video signal the power demands slightly increase and the power supply can't handle it. This is a very common problem with LCD after a few years of use. The issue with the power supply is the capacitors have started to fail. These parts are used to filter the output voltage and when they start to fail the outputs start rippling hence the problem you are having. Here is a link to a repair article that shows how to repair the Gateway FPD1975W monitor.
http://www.ccl-la.com/blog/index.php/gateway-fpd1975w-monitor-repair/
I hope this helps you get back going.
BuddyMc
Sep 20, 2011 | Gateway FPD1975W 19" LCD Monitor
Heatsink fan spins without pushing power on button, no display asus p4xp-x, reseat video adapter, ram, remove connector power and signal to optical disk only mouse keyboard ram and video adaptr
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this will help don
Mar 11, 2011 | ASUS P4XP-X Motherboard
My power supply failed. Now after replacing it
More than likely the power supply you bought isn't capable of handling the wattage demands of your system. If you do not get ANY indication from your video board (i.e. boot information), chances are the power supply is either too low on wattage output or it's defective.
Aug 21, 2009 | AOpen Computers & Internet
Not booting
What type of PC are we talking about? Have you tried a replacement "known to be good power supply", the board will spin up with ram & video card not seated correctly. are you getting any bios "beep" codes?
Jun 18, 2008 | Computers & Internet
UPGRADING PROCESOR
Make sure your BIOS can handle an upgraded CPU. I would go into bios, check the "default" or "fail safe" boot option and then power down. Lift keyboard or access your CPU and change out. Remember to touch something metallic before you operate so you discharge any static electricity (killed a CPU and a video card by not doing this ONCE) Boot up and notice any BIOS messages, may want to start in safe mode just to get a basic working config going, then power down, access BIOS and start getting it back to your best config, maybe stepping one item at a time, rebooting and continuing until you get a stable platform.
Jan 22, 2008 | Sony VGN-S150 MBX109 (M9_32 (A1072469A) PC...
No signal on first boot
This would usually indicate that there is a problem that is causing your computer to not boot correctly all of the time. What you have described could be many different problems and without more information I cannot say which one it is.
1. Hard drive. I have ran into Hard Drives that for some reason do not start up correctly right away when you put power to them. This can cause the initial startup to hang possibly indefinitely.
2. Video Card. Something probably firmware is causing your video card to not start up properly when power is first applied.
3. PSU. The power supply could cause similar problems if it cannot supply enough power because the highest power draw is when you first turn on the computer. When you push the reset button the power is already being supplied to most of the components and the ones that did not have enough power to start properly before can do so now.
4. CPU. If the CPU has some minor problems it can cause similar problems. In any case to fix it you can try clocking down the CPU but you are better off replacing it.
5. RAM. I have had similar problems with RAM. Clocking down the RAM fixed the issue.
6. Settings in BIOS. I would check to make sure the setting for init display on boot is set for PCI-e.
Nov 06, 2007 | XFX GeForce 6200 Graphic Card
Power on/boot-up problem
Have I got a story for you? Dell inadvertently used some defective capacitors in their Optiplex motherboards and some power supplies. From what I?ve experienced and read this affects the Optiplex 270 and early 280 lines. In my case my systems had video display problems and eventually ended up not booting. The giveaway is looking at the large 150 uf capacitors; they are the larger ones usually with an ?X? inscribed on the top. If the tops of the capacitors are flat you?re out of luck but if any of them are bulging (even slightly) at the top, leaking electrolyte or split Dell will replace the motherboard for free. This program is in effect till 2008. I wouldn?t recommend pulling the power supply apart but the flashing yellow power light for me has been a failed power supply. I would check out the motherboard for bad capacitors then call Dell. It?s likely they will replace the power supply if it?s in warranty, perhaps even if its out in light of the capacitor issue. If you?ve got some rounded caps on the motherboard I would also ask them to replace that as well. Let us know if you have any other questions and please don?t forget to rate this posting.
Mar 30, 2007 | Dell OptiPlex GX270 PC Desktop
Computers & Internet Logo
101 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
