It is showing the error DRUM LIFE OVER REPLACE THE DRUM.
    Guru:
  • 832 Answers
Hi there!
what is the model of your machine? if the error saying the one you have mentioned, you just have to buy a new drum and install it properly.
regards, fossildude
Posted on Oct 15, 2010
3 Suggested Answers
  • 22 Answers
SOURCE: Panasonic KX-FL512 fax drum life error
You need to follow the instructions that came with the drum as you need to reset the internal counter.
Posted on Dec 07, 2009
KingDWS
  • 1606 Answers
SOURCE: error drum life over
Ok what the error means is that you have used the fax to print so many pages. The image drum is what actually creates the image that gets printed. These are rated for so many pages.I think it is about 10,000 pages on this unit. The fax (and printers and copiers) simply count the number of pages and then when they reach the limit you see this error. Sometimes the print quality looks pretty goof but usually you can see some spots or rough print or fuzzy bits and so on. What you need to do is replace the image drum.
Here is the important bit. You can buy a replacement image drum for about $75 from several sources aside from Panasonic (Amazon, Office Depot, Staples etc) however a new replacement is only worth $120. So if you can change it yourself (it is pretty easy to do, almost identical to the toner cartridge replacement) then it may be worth doing. If you have to call someone in by the time they add labour on top you could have saved some money and just buy a new unit.
Posted on Sep 05, 2011
How to fix brother printer drum error troubleshooting and routine maintenance
I still receive the error message "Replace Drum", "Drum End Soon", "Drum Near End", or "Drum Stop" after I replace the drum unit with a new one. The following error messages will continue to appear if the drum counter was not reset when you replace the drum unit with a new one.
  • Replace Drum
  • Drum End Soon
  • Drum Near End
  • Drum Stop
To clear these error messages, you need to reset the drum counter as instructed below.
If you want to clear an error message related to the toner replacement, click here to see how to clear an error message after you replaced the toner cartridge.
"What is the difference between the toner cartridge and the drum unit?"
Please reset the drum counter only when you replace the drum unit. If you reset the drum counter during the life of the drum unit currently being used, the remaining drum life will not be displayed accurately.
  1. Make sure that the machine is turned on.
  2. Open the front cover.
  3. Press Clear or Clear/Back on the control panel.?
    NOTE: The layout of a control panel differs depending on the model, but the Clear or Clear/Back button is located on the right side of the LCD screen as shown in illustration.
  4. Do one of the following.
    • If your Brother machine has a numeric keypad:
      Press 1 to reset the drum counter.
    • If your Brother machine doesn't have a numeric keypad:
      Press the Up Arrow Key to reset the drum counter.
  5. When the LCD shows Accepted, close the front cover.
Sep 11, 2017 | Brother Office Equipment & Supplies
The Samsung Printer M-2876ND is showing an error replace imaging unit. It has already printed 9000 units, so i guess the life of the unit is over. Now, i want to know if the same will work in case i j
Dear Ankit
you can replace the complete drum cart. or replace the CRUM (drum chip) of the drum cart. no need to replace the drum it can goes up to another 9000 a4 pgs.
Thanks.
Jan 12, 2015 | Samsung Office Equipment & Supplies
I HAVE C5500 OKI PRINTER AND THE ERROR SAYS REPLACE IMAGE DRUM 561:M DRUM LIFE I PUT IN NEW MAGELN AND STILL HAS THAT MESSAGE
oki printer c5950 fix new cartridge & drum coming error replace image drum 561:m drum life
Jan 15, 2013 | OKI C5500n Printer
How do i reset ricoh sp 1200s drum unit
why toner life end message keep on showing on sp 1200s prints.
Aug 04, 2012 | Ricoh Office Equipment & Supplies
My brother DCP 7055 shows eror replace toner
Some Brother laser printers have separate consumables - the toner cartridge and the drum unit. From time to time you may need to replace only the drum unit and not the toner cartridge.
The error LED lights up, or an error message shows on a flat screen panel, when the drum unit is near the end of its working life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one.
Jul 26, 2012 | Brother 1 Black Genuine Laser Toner For...
I just installed a new drum and toner cartrideg last week and the error message says drum is near end. Should the toner cartride be replaced?
After replacing the drum and toner you may need to reset the drum life of the machine. This is how to reset the drum life:
Open the front cover where the drum and toner are located. Press the clear/back key. Lcd should show Replace Drum? Then press 1 for yes. Lcd should show accepted. Close the front cover the press stop/exit. Lcd now should show the date and time.
Hope this helps. Rate if it works. Thanks
May 02, 2011 | Brother MFC-8460N Laser Printer
Drum Error - see routine maintenance chapter in user guide. Do not have user guide
I tried everything and then decided to slightly change the above instructions to:
press Clear/Back
Replace New Drum - select "Yes"
after the screen will show "accepted"
close the front cover and you are good to go
and WA LA it worked!!
Apr 19, 2011 | Brother MFC-7340 All-In-One Laser Printer
I have this model printer (brother mfc-7840W) and i'm getting an error on the screen-it says Drum Error. See troubelshooting and maintenance chapter in the user manual
If you have the manual follow the steps for trouble shooting.
It will tell you to remove the drum, remove toner, clean corona wire and reinstall. If that does not solve the issue it will recomend replacing the drum. You can check your drum life by going to menu- press machine info, choose option 3 drum life and press ok. This will show you the remaining percentage of your drum if the number shows less than 25% replace the unit.
If it shows more than 50% you can reset the drum counter allowing the machine to read it as a new unit.( Bare in mind this will change the usage meter back to 100%, you will have to keep an eye out for print defects or light pages as this will signal the end of the drum life) to reset page counter remove the drum from the machine, with the front door open press Clear/back until the lcd displays reset drum yes? no? press 1 for yes and reinstall drum. The machine will cycle until ready; if this still has not cleared the message you will need to contact brother for a manual reset or service.
Jan 05, 2011 | Brother MFC 7840W Printer
Toner life end warning light. replaced with new toner/drum still error
To reset the sensor after installing a new toner cartridge follow these steps.
1. With unit powered on open the front cover.
2. Press the "Options" key. Display will show "Replace Drum?"
3. Press "Start" key.
4. Press "+" key 10 times until the display reads 10.
5. Press "SET" key.
6. Display will show "Accepted" for approximately 2 seconds. Then display will change to "Cover Open".
7. Close cover and see if Toner Life End error message has gone.
Jul 28, 2009 | Brother DCP-7020 Black and White Copier
54 people viewed this question
jasbo
jasbo
