Question about Husqvarna Viking 1
Power won't stop - Husqvarna/Viking 3600
I have a 30-year old Husqvarna 3600 / Viking 3600 sewing machine that is used infrequently. It was last used about a year or more ago.
When I plug it into the power outlet, the sewing machine starts to sew – without any pressure on the foot control.
I have:
- disconnected / reconnected the power from the sewing machine and also from the wall outlet.
- checked to see if the foot control was in a “stuck” position
- I dusted the contact points that I could see,
but I still have the same results - when I plug the power into the outlet, the machine takes off, sewing at very high speed and I can only stop it by disconnecting the power cord.
Any thoughts on actions I can try to resolve this?
Thank you
    New Friend:
    Problem Solver:
  • 5 Answers
Your foot controller is damaged and should be replaced.
Posted on Feb 07, 2013
  • 4 Answers
Many older sewing machine (and some newer ones too) have radio-interference-suppression capacitors fitted in the foot controls to eliminate motor noise being radiated back down the mains power line. Many of these, especially the ones fitted across the rheostat (speed controller) in the foot pedal go partially or fully short-circuited, this meaning the machine starts sewing when the foot controller is plugged in. The solution is simple: get a qualified serviceman to take the capacitor out of circuit to see if that fixes the problem. If it does, then a replacement suppression capacitor of a suitable high voltage, at least 1,000V working, should be sourced and fitted. Just removing the faulty cap is not recommended and there is likely to be radio interfence spread all around the neighbourhood if you run the machine without the suppressor. The Radio Inspectors will not be amused. Good Luck.
Posted on Feb 27, 2012
This happened w/ my 3600 many years ago. I took it into the repair shop and was told the foot control was 'bad'. THey replaced it w/ a foot controller off of another machine (not same color or size) but machine has worked for the last 20+ yrs.
Posted on Nov 12, 2010
  • Husqvarna Expert
  • 371 Answers
Suggest trying this - turn machine on with foot control unplugged. Does the machine perform in same manner? If it does not, then plug in the foot control (with power still on). What happens? If the foot control is triggering it, it could be a faulty foot control. If it does not, it could be either a bad transformer or motor. Suggest contact local authorized Husqvarna Viking dealer. You can find the closest dealer at the Husqvarna Viking website -
Posted on Sep 25, 2009
What does the dongle for an old Viking Rose sewing machine look like?
Contact these people. They are the best supplier and may be able to help you.
Husqvarna Viking Sewing Machine & Serger Parts - Sewing Parts Online
  1. Cached
  2. Similar
If you can't find the Husqvarna Viking Part(s) you are looking for, send us an email at or click here to contact us. Or, shop for Husqvarna Viking Presser ... 250C Eden Rose · 2840 · 305 · 3310 · 340D · 341 · 341D.
dongle for an old Viking Rose sewing machine Google Search
Apr 14, 2017 | Sewing Machines
Husqvarna viking sewing machine bobbin
Could the part number be 4011770? I've found the Viking 7 bobbins here: . Another site with them is . This bobbin is compatible with the Husqvarna Viking 7, 49, 51, 52, 21 & 21E . It probably will work for other machines. Sears also has them listed as 11770: .
I also found these bobbins: . The part number appears to be 1702.
I hope this helps.
(googling Husqvarna Viking metal bobbins found a number of hits.)
Mar 05, 2013 | Husqvarna Viking 1
My 5 year old Huskystar 216 sewing machine is
Sounds like the hook/needle timing. To check do the following:
With the power off!!
remove bobbin and bobbin case.
push needle all the way to the left.
Turn handwheel toward you watching the needle and bobbin housing hook. The point of the hook should line up right above the eye of the needle.
If not timing, clean bobbin area removing lint and thread.
Check bobbin tension, should get slight resistance when pulling thread.
Make sure using only Husqvarna Viking bobbins -- most are green but they have new colors now. All will have the Husqvarna logo on them (an H). Make sure the bobbin is unwinding in the right direction.
Remove fabric. Pull extra long bobbin thread (about 3 inches). Hold upper thread tail in left hand, turn handwheel toward you for 1 revolution. Is the bobbin thread caught by the top thread and pulled through the opening of the needle plate?
If you are still unable to get a good stitch, take to an authorized Husqvarna Viking dealer for service or have them send to Husqvarna Viking (SVP) Technical Service Dept for repair. A list of dealers close to you can be found at the Husqvarna Viking website -
Good luck.
Sep 26, 2009 | Husqvarna Sewing Machines
I have a Husqvarna Viking quilt 870 sewing
The overload message is usuall due to a bind in the mechanical function of the machine. When the motor has an extra "load" caused by something like a tight belt or dry bearing, it "overloads" the motor and the error message is displayed. It is doubtful your problem is computer related. Either way a trip to your service tech is required. If you continue to sew with it, you do run the risk of possible damage to some other parts of your machine. The computer portion of your Husqvarna is guaranteed for 5 years and the mechanical parts carry a 20 or 25 year guarantee depending on when you purchased your machine. A copy of your bill of sale from a Husqvarna Viking dealer or a stamped warranty card is the proof of purchase needed to obtain warranty replacement of parts. Labor is only guaranteed for 1 year.
Sep 26, 2009 | Husqvarna Viking 1
Part for a Viking 6440 Sewing Machine
Check ebay. They sell a lot of parts and/or machines for repair.
Mar 09, 2009 | Husqvarna Viking 1
Machine stopped running, its getting power but wont run.
I would take it back to your service tech or choose another. It may be something simple that needs replacement, like a new cord. (or . . .)
Also, before thinking of buying a new machine, I would get another opinion.
Feb 17, 2009 | Husqvarna Viking 1
Viking is skipping some stitches when it is on zigzag
These are great machines but after 25 years there are probably a lot of problems that need to be fixed. It could be as easy as buffing or replacing your needle plate. If you take it in for service (and can actually find someone who is good with this machine) you will probably pay $200 to $400 to get it back to 'factory' state.
Jan 29, 2009 | Husqvarna Viking 1
Needle doesn't move the problem isn't the foot pedal
I have a Husqvarna #1 that I also love. My needle stopped moving too. I was convinced it was the foot peddle but a repair person sais it was not. I discovered on my own that indeed it is the cord on the foot peddle. I suspect it has a loose wire because when I wiggle it where it connects to the machine it starts working again. Right now this is what I have to do because I can't find a replacement peddle. Can anybody help me find one?
Jul 06, 2008 | Husqvarna Viking 1
Sewing Machines Logo
995 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
