Question about Nokia 5230 Cell Phone
My nokia 5230 will not turn on. It was working then just stopped, the battery was good strength when it died. I have removed the battery a few times, still no go. When you push the on button at the top of the phone, the screen lights up a little bit but stops when you stop pushing the on button. Any ideas? Mark.
SOURCE: tracfone dies after adding time
Same problem. Working off of Reijose's suggestion (thanks) I had the charging plug in the wall and the phone. That at least stopped the buzzing. Then I started working combos of buttons, turning the phone off and on etc and finally it came back to life. Can't say it was any one combo, but I did press 666 and clear or stop enough times that I might have finally exorcised the demons of of this thing.
Serriously that was the combo of buttons I used, through just by chance more than anything, ha.
Posted on Sep 18, 2008
suxia
  • 142 Answers
SOURCE: I dropped my Nokia 6301 in a bowl of water. It
when you take it from bowl did you disassamble it and free it from watter and battery? battery must be take off untill phone dry. If battery was in it it may cause some condensation and need to be cleaned.
Also some light flash in sides are when battery discharged, try to recharge it, if don't began charging better take it to any customer care.
Posted on Jul 30, 2009
SOURCE: My on/ off button fell off 6500 slide how do i turn my phone on
This problem is very simple. I see this question continually popping up when the answer is so simple. You pull the battery out of the phone. On the back of the phone their is a sequence of numbers That represent the phone's BDK. (CODE) write down on a piece of paper the last "number" , e.g CODE:055565('8)OK now You connect the phone to its own charger.. the screen will start to turn on (go white). now just before the screen turns on 100% you disconnect the phone from its charger. repeat this method to the amount of times the last number was. In this case we would repeat this method 8 times, because 8 was the last number on the phones code. I hope I have been helpful ;)
Posted on Nov 29, 2009
toy_ladi
  • 484 Answers
SOURCE: I remove the Nokia 5230 battery and sim but cell
hello,
the phone might be experiencing some software problem.
try to charge the battery in another phone then insert it back with the sim, then try to turn it on again.
try flashing the phone with a compatible software,then try to turn it on again.
if it does the same, then you should try to take the phone to a nokia service center for further repair.
take care
Posted on May 27, 2010
rockmeister
  • 2047 Answers
SOURCE: My Nokia N97 email widget
The Nokia N97 is a great device used one when the phone just got released. The problem with this device is that when you get to many applications on it it starts to freeze up abd act just like how it is now. Best solution out is to free up the phone remove some of the applications on it and reset the email widget. Also download an antivirus application preferably from ovi store. Restore factory settings on the phone and watch how it behaves over the next couple of days and get back to me.
Hope this solution has been helpful?
Posted on Dec 12, 2010
How to check signal strength in Nokia 5230
there should be a indicator bar on the upper section.
Nov 17, 2013 | Nokia 5230 Cell Phone
Check signal strength
settings phone settings manual select network
I have a nokia 5230 and a plantronics 360 bluetooth headset and i can't connect the headset to phone. what can i do?
You want to make sure there is no other bluetooth interference. Try turning off the phone and disconnecting the battery for few seconds and reconnecting. This helps to reset the phone. Then follow the pairing instructions found in the Plantronics Explorer 360 User's Guide (pages 3-5).
Good luck from Headsets Direct!
Mar 09, 2011 | Nokia 5230 Cell Phone
When i try turning my 5230 on it just comes up with the intial white screen that says nokia on. It wont load up my screen. Please help, thank you
Try the following suggested solutions as they may solve your problem:1. Remove any newly added hardware on your device, e.g a MicroSD device(memory card), and replace it with a component compatible to your product.2.Upgrade your phone's firmware.You can do this through the Nokia PC Suite provided with your phone.During the firmware upgrade process, ensure that your phone remains connected throughout the operation and that you have a working internet connection.
Procedure:1. Download the Nokia PC Suite from the Nokia Website at http://europe.nokia.com/support/download-software/pc-suites/compatibility-and-download and ensure that you select the appropriate phone model2.Install the Nokia PC Suite(latest version is Nokia PC Suite 7.1 as at the time of writing this) on your computer.3.Connect the Nokia phone to your computer via USB.4.Follow the procedures at http://nokia5230.com/nokia-5230-firmware-update-v12-0-089/ and http://nokia5230.com/nokia-5230-firmware-update-v20-0-005/ to upgrade the phone's firmware.
I hope the above data will help.For more on tweaking your Nokia 5230 phone, follow the link beloe:http://nokia5230.com/nokia-5230-hacking-tutorial/
Have a good time ahead.
Dec 18, 2010 | Nokia 5230 Cell Phone
My nokia 5230 keeps on turning off for no apparent reason
my nokia 5230 automatically turns off and on , pls help
Nov 13, 2010 | Nokia 5230 Cell Phone
I have a poor signal how can i make it better nokia 5230 so i can call on my phone
First of all,put the SIM card into another phone which you can be sure that there are no faults with it and check whether you're getting a good enough signal strength than your nokia 5230 phone.
If you're not,then its not a fault with your nokia 5230.
If your area has a poor signal strength from your current service provider,move into another service provider who has more signal strength within your area if you can.
Sep 11, 2010 | Nokia 5230 Cell Phone
I remove the Nokia 5230 battery and sim but cell phone stop working how we on the cell again.
hello,
take care
May 27, 2010 | Nokia 5230 Cell Phone
Nokia 5230 problem - the phone turns on okay, but then does not respond to screen or key touches. I've taken the battery out and replaced it again, but it keeps happening. Any suggestions? Thank you.
Nokia has stopped the production of his phone recently because battery issues and stated manufacturing nokia 5233. Please walk into Nokia showroom and get it checked they will help as phone comes with one year warranty.
May 25, 2010 | Nokia 5230 Cell Phone
Nokia 5230 Cell Phone Logo
500 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
