Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
Printing labels: these come out grey and only sometimes black. I have tried all maintenance tasks and re-saving with black colour on the label page, there is no pattern to this. Ordinary documents print just fine.
  • Kodak Master
  • 11,800 Answers
In that case the problem is with the paper of the label itself: it absorbs the ink in a random rate. The only thing you can do is to use from now on a better quality label paper, and using only that one. You will probably gonna have to try different brands before choosing the right one.
Posted on Oct 15, 2010
Have a label with colours of gray and black. Toshiba B-SX5T printer does not print the gray colour very well at all. Shoppy print of areas on the label that are gray. Printer issues?
You must either modify your graphics or try another driver ou driver options.
Take care that this printer only print black dots and the grey is obtained by not printing all the dots.
With some algorithms the grey color is not correctly interpreted.
Sep 09, 2013 | Toshiba B-SX5T Printer
Hi. We are trying to use an avery label 22807 and also 22806 for a label factory logo we created. We need measurements/diameters so that we can print on these labels. They keep printing wrong. ...
If you are using Microsoft work to print the label, then follow the link below to Avery's website. The link is to their find a template, type in the label number in the Product # or Keyword search box and it will take you to a down load for that label. Click on the download, you will be asked for some information before the download begins. Follow the instructions on the next page (save the file and remember were you saved it). When you open the saved file it will be in Word and you can go from there.
http://www.avery.com/avery/en_us/Templates-%26-Software/Templates
I hope this helps you out.
Jul 22, 2011 | Computers & Internet
My Xerox 8400 is printing the wrong colors. Where it's red, it's printing a brown shade and where it should be grey, it's printing green. My logo is grey and red and it's printing all grey, but not the...
Try printing a light stripes test page (Troubleshooting, print quality problems, troubleshooting print quality page).
If you do not appear to have many missing jets but the colours are all just wrong it may be that the ink has gone stale. Run a couple of head cleans and you should see the colours start to improve. If it is getting better, all you can do is keep running head cleans until you have replenished all the ink in the printhead well.
This problem is common in situations where a lot of black and white printing is done, with very little colour.
Alternatively, it could be that your wiper/cleaning blade is not cleaning the head properly and is smearing the different coloured inks across the head, or possibly that your printhead is leaking colours but I think the first solution should solve your problem.
Hope this helps.
Dec 09, 2010 | Xerox Phaser 8400 Laser Printer
TRYING TO HOOK UP MU POWER BUTTON NEED TO KNOW
Hi there
The front panel connectors are mainly,
  • harddisk activity connector
  • power switch connector
  • reset switch connector
  • power LED connector
  • speakers connector
  • USB connector
Harddisk activity connector
This normally comes red in colour and is labeled as HDD-LED
Power switch connector
This comes green in colour and is labeled as POWER-SW
Reset switch connector
This usually comes grey in colour and is labeled as RST-SW
Power LED connector
This is usually green in colour and is labled as PWR-LED
Speakers connector
This speaker will give different beep sounds during boot to tell the user if there is any errors. It occupies 4 pins, however only 2 is important for the function. Be sure to connect the red coloured cable to the positive polarity and the black to the negative.
front_panel_connectors.jpg Front panel connectors pins on the motherboard
front_panel.jpg Front panel connectors from the casing
Good luck and thanks for using FixYa!!
May 13, 2009 | eMachines T6420 PC Desktop
Problem with printing labels - not aligned, some missing
This is due to print server problem, you should change the options on the driver.
Nov 04, 2008 | Datamax M-Class M-4206 Thermal Label...
Grey background over entire page.
If toner is getting onto the transfer belt, it can only get there by either being put there intentionally, or leaking.
Failure of Transfer Belt is normally degraded print quality - usually poor density, or a failure of the support behind the belt (usually puncturing the belt), and scoring a drum.
Sep 15, 2008 | HP Color LaserJet 2600n Printer
Samsung CPL-300 Color Laser Printer Problem W/ Labels
I work in the comercial printing game, what your describing sounds like the surface finish used on these labels is only suited to black toner. Black requires the least amount of heat to set, where as colours require more radient heat the lighter the colour gets from black. Try printing a black/monotone lable and see if you still get this blistering problem.
May 07, 2008 | Samsung CLP 300 Laser Printer
Grey & Black Printing on everything
it appears that the printhead has a problem. try cleaning the printhead, via software. usually in printer prefs. also try running a few test pages. to see if you have any colours at all. if it,s only printing in grey scale. i.e grey-black. check the colour cartridges ink has,nt run out or blocked the nozzles.
Hope this helps Mike@Compurepair.
Feb 20, 2008 | HP DeskJet 9800 InkJet Printer
Paper feed
The feed rollers are slipping on the surface of the label, causing the page to load incorrectly. There is no permanent solution at this time. Try one of the following workarounds to correct this issue. Workarounds Workaround 1 Adjust the top margin using Page Setup.
  1. Click File , then Page Setup in the program being used, (accessing Page Setup may vary from program to program. Refer to the Help file for that program).
  2. Adjust the top margin until printing is correct on the label.
Workaround 2 Manually print one sheet at a time. Place one sheet of labels in the input tray at a time, printing only that page. Repeat for all pages of labels needed.
Nov 20, 2007 | HP PSC 1210 All-In-One InkJet Printer
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
26 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
