Question about Boston Acoustics BA735 Computer Speakers
My son recently gave me his used BA735 3-component system. I was looking forward to using it because of BA's reputation and because it would be my first digital acoustic output device, but I couldn't make it work because several of the (9?) male pins in the socket at the end of the cable from the speaker with volume and treble controls meant to connect to the female 'control out' socket (coded blue) on the back of the woofer/bass box component were severely bent or completely broken off. Trying to make repair, I right away cut off the male connector socket at the end of the cable, thinking that I could find a replacement with good pins that I could splice back at the end of that cable. Unfortunately, I've not been able to determine the technical names or locate the whereabouts of replacements. Can you help me there? And finally, is it reasonable to plan to multiply-splice the cable wires and connector back together given that my experience is limited to taping and mechanical compression type splicing and have no experience soldering? If not, what else would you recommend?
  • 712 Answers
I believe this site will lead your way:
http://www.bostonacoustics.com/Service-and-Support-C89.aspx
Thank You.
Posted on Oct 15, 2010
Truck runs on propane will not start
What do you want to gave from the message that you have left? There are several components that make up propane system. Also the trucks ignitions components will remain the same. To better help you I need to know as much as you can tell me. Year, make, model, engine size, any light on or flashing, on the gauge cluster, any drivability symptoms, any repairs performed recently, anything replace or tested, and are you familiar with the mechanics of the propane system? The same rules apply. The engine needs Fuel and Spark to run. You will need to determine which system has failed. From there you can narrow down your search and in time find out what has changed or stopped working. Also look at the trucks maintenance history. When was the last Tune-up performed, has anyone used the additives that are available to keep the sludge (From the propane tank) from clogging up the system. Please write back with more questions or information, good luck.
Dec 29, 2013 | Cars & Trucks
Unknown device
Samsung HDD division was only recently sold to Seagate.
"ST" is a Seagate number so your drive cannot be old - manufactured by ex-Samsung factory now part of Seagate.
Utility from Seagate (e.g. Seatools) should be able to display from S.M.A.R.T the number online hours.
Dec 27, 2013 | Samsung HD502HJ Samsung 500 GIGAByTE SATA...
I had a power cut a few weeks ago, I can not find my user manual for my sharp ba 1200 system, I know that I need to press three cetain buttons to re set the micro computer in order to set the clock to get...
What's a Sharp BA 1200? Web search for "(exact product) manual".
You might find it at the manufacturer's support site, by using a common search engine or these guys...
retrevo.com
audio.manualsonline.com
hifiengine.com
usermanualguide.com
vinylengine.com
Search Engine of your choice: "(product) manual"
Aug 15, 2011 | Sharp Multi-System Mini Component System...
I am not computer literate and my son gave me thie WiDigital Photo Frame. However, I did not get the manual - could you help
use the help menu for instructions. open the software and look for the help tab or help question mark
Feb 12, 2011 | Computers & Internet
I cant find any place to hook up a dvd player to it, Is it possible? Also What is the jack used for that is hanging above screen on left hand side. I have no manual as my son gave me tv for my bedroom when...
Look for a jack labeled HDMI, Component Video, or S-video on both the TV and the DVD player. You will need a cable that matches the jacks that you have available. HDMI is the easiest. Buy your HDMI cable on line - the retail stores mark them up drastically. Try firefold . com
Jan 13, 2011 | Televison & Video
Sharp cd-bp1200w cd carriage will not open power is ok display ok . cds locked inside!
On my sharp CD-BA 1200 most cd's do not run. It is the problem that has recently occured. Kindly suggest solution.
Mar 14, 2010 | Sharp Multi-System Mini Component System...
Dvd wont read discs dvd or cd
is the drive still recognised by the system of the tv? If so it may simply be a dist situation (that's what happened tro me recently) unless it was jolted heavilly just before it froze. I asume other disks won't read either. You could try a dvd cleaning disk but I found them to be pretty **** and an aerosol cleaner works a lot better. Get one from an electrical component supplier or even some department stores stock them. Be sure to use the right product, i.e. for blowing dust out of electrical systems, as you don't want to go spraying just anything in there. A friend of mine once used a car 'easy start' to try and do a similar job and he ended up buying a new cd player (it was an in car player). Like I said it worked for me.... I was ignoring my intuition for ages looking to get components replaced etc. Finally I gave in and ended up kicking myself for not having listened earlier!!!
Jul 06, 2009 | Televison & Video
Unable to remove programme
Try to unstall using the add/remove program.
Here's the step
1. Click start
2. Click control panel
3. Click add/remove program
4. Choose the program you want to remove then click remove.
Hope that will solve your problem
Thanks
Dec 01, 2008 | Philips J44414
Interest only payments
I gave up using the Texas BA II. I used an on-line mortgage calculator for interest only. I was able to get a full printout.
I would like to learn more about the BA II and how to do this type of math on it.
Thank you
Mar 02, 2008 | Texas Instruments BA-II Plus Calculator
NIKON PRONEA S
No, the camera uses APS, ( advanced photo system ) type film.
Dec 30, 2007 | Nikon Pronea S 35mm SLR Camera
Boston Acoustics BA735 Computer Speakers Logo
100 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
