Question about Vizio Gallevia GV42LF 42 in. LCD Television
The tv imput does not work now it is stuck in rgb and turns off after 2 seconds
  • 998 Answers
Try to reset the setting of your tv.
Posted on Oct 15, 2010
I'm trying to view my monitor on my LG 32" using the RGB port but can't get it working? I've connected the monitor cable to RGB port, selected the RGB menu in Imput and keep getting "NO...
I too am having the same problem. It works fine on my Samsung TV but no signal on my32lG60. If you find anything let me know. Larry mebehe.Larry@gmail.com
Dec 01, 2010 | LG 32LG30 32 in. LCD HDTV
I have a 50'' Pioneer plasma T.V. and can't seem to find a place to plug in an HDMI cable, can you help. Model no. is: PDP 507CMX. The T.V. has the following plug-ins: one that says RS232C; one that says...
An older television might have DVI instead of HDMI. the difference is that HDMI also carries sound while DVI does only video. You may need a converter box or another converter cable.
Feb 05, 2010 | Televison & Video
Have a Vizio VX37L that when it is turned the
HERE'S THE FIX: I just went through this with my Vizio VX37L. TV is stuck in RGB input. This is the fix.... TV is stuck in RGB input.
(option 1) Power on TV, and press the INPUT button repeatedly and rapidly until you can change to a different input, such as AV.
If that doesn't work, try:
(option 2) With the TV off, press and hold the INPUT button on the side of the TV for about 5 seconds. The TV should power on and the input list will appear. The TV will no longer be locked, and the INPUT button should function properly after that.
Option 2 worked for me!
Jan 24, 2010 | Vizio VX37L Television
TV will not get off the RGB Screen
I just talked to a tech and fixed mine. unplug tv and hold power button for 1 minute. this drains the compasitors, sometimes they get over charged. if that doesn't work. with tv off hold down input button until tv turns on . it should work. here is tech support # 714-668-0588
Aug 27, 2009 | Vizio VX42L 42 in. LCD TV
No RGB imput signal
You need to change the input signal, get into the menu on your monitor and change the signal from rgb to dvi, hdmi or vga dipending on what cable you using for connection.
There is NO rgb connector on that monitor
Good luck
Dec 05, 2008 | Balance CM2015 15" LCD Monitor
Lc-42d62u 42in.
This is a common issue with HDMI. Try unplugging the TV for 2 monutes and also reset the cable box as well by inplugging.
Feb 10, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Green Picture
The problem sounds like one I had. If so, the cause is as follows.
The Daewoo ouputs synchronisation information on the green channel of the RGB outputs (which are pins in the SCART socket) The Panasonic TV automatically preferentially selects the RGB input in the SCART rather than the composite video signal in the SCART. The video circuits in the Panasonic should ignore the sync on the green channel but instead interpret the sync as green signal information which means the adjustment of the green channel is upset leading to a very green picture.
Possible solutions:
1. From the TV, manually select composite video input, not RGB. This may not be possible - I think the TV automatically goes for the RGB if it is present.
2. Disconnect the wire to pin 16 in the SCART socket. This is the signal from the VCR/DVD to indicate that RGB is available. Disconnecting it means the TV defaults to the composite video. This is what I did.
3. Connect the TV to the VCR/DVD using component or S-VHS leads only.
Jan 13, 2008 | Daewoo DV-6T955B DVD Player/VCR
Hooking dvd player to tv
check if your dvd video output is switched to the svideo or RGB and make sure it is switched to the output youare connecting video cable .
Dec 31, 2007 | Philips 32PT6441/37 32" TV
Vizio Gallevia GV42LF 42 in. LCD Television Logo
96 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
