Question about Toshiba Computers & Internet
My toshiba tecra 1 PT831A-67css has got horizontal lines on screen and keyboard is not working
  • 656 Answers
Hi remove ur display cable from the motherboard and and check wether display shows no connection check signal cable if you see this there is no problem with ur monitor if you dont and still you have horizontal line in your monitor then your monitor is fried if you see the display remove the cpu covers check wether you have addon display card or builtin with motherboard if addon replace the display card if its builtin try with an addon card to check if you are inserting a addon card you must disable the builtin deisplay from the bios if not it conflicts if the addon card is working and no problem with dispaly ur display section in motherboard is fried
Posted on Oct 15, 2010
  • rajesh raman
    rajesh raman Oct 15, 2010
    sorry for the inconvinence i gave the suggection for the pc desktop for laptop u have problem with laptop motherboard disply section it means some components in the diplay section have been fried you can aslo try to clear cmos
  • rajesh raman
    rajesh raman Oct 23, 2010
    in old computers sentonix connevtors which have 25 pins where used to connect the printer to computer the one end of the sentronix concter is connected to the printer the other to the LPT or printer port of the computer then install the software then you are ready to use the printer
The screen does not come on when i start the toshiba tecra
first you need to learn how to reach the area inside betw the screen and keyboard to see if the cables that connect the screen with the mother board are not lose or disconnected.
Aug 11, 2012 | Toshiba Computers & Internet
Toshiba Tecra A8-S8414 keyboard
I'm not sure if it is worth ..but you can get a new keyboard and change it ..To change the keyboard you have to remove teh hinges cover ..remove the screws and slide the keyboard one inch toward teh display ..and lift it up ..pay attention cause it has a ribbon attached on the motherboard and it is sensible
http://www.uspcparts.com/toshiba-tecra-a8s8414-keyboard-p-9904.html
Dec 22, 2011 | Toshiba Tecra A8-S8414 Notebook
How do i remove the key board
How to replace your Toshiba Tecra A2-S119 laptop keyboard ?
It's easy to break the flimsy keys on laptop. In order to better protect the Toshiba Tecra A2-S119 notebook keyboard, some friends, instead, use USB keyboard. But if you work outdoors, carrying a USB keyboard is not convenient. You still have to use the laptop keyboard. Once a laptop keyboard stops working, there is no option but to replace it. You can use these steps to replace the Toshiba Tecra A2-S119 keyboard.
1. Take out the battery and AC adapter, unplugged from the wall, enusre the laptop is fully powered off.
2. Remove those screws with a T-8 or Phillips screwdriver.
3. Turn the laptop back over and open it up. Check and see if the Toshiba Tecra A2-S119 keyboard is tucked under any plastic pieces. If so, find them if those plastic pieces are screwed into anything, and unfasten them as well. If not, it probably uses clamps that can easily be removed.
4. Remove the plastic pieces carefully.
5. Unscrew any screws at the top (if necessary) and remove the keyboard itself from top to bottom. You'll notice that the keyboard is connected with a thin, but wide, data cable to the system board at the bottom.
6. Disconnect the data cable attachment of the keyboard which will sever all the remaining attachments of the laptop keyboard with the laptop computer motherboard. To remove this cable, you have to just carefully pull it out from the socket to which it is attached. Then you can lift out the entire keyboard out of the laptop.
7. Take the new Toshiba Tecra A2-S119 keyboard out of the plastic and place it inside with the right orientation, attach the data cable.
8. Refasten the keyboard in place at the top.
9. If you had to remove any plastic pieces, carefully snap them back in and replace any screws you had to remove.
10. Turn the laptop over and replace all of the keyboard screws.
11. Put the laptop battery back in place and switch it on to check Toshiba Tecra A2-S119 keyboard functionality. If everything has gone according to plan, you should be ready to type away!
You have to remember that once you open up the Toshiba Tecra A2-S119 laptop computer for keyboard replacement, the warranty provided by the manufacturer stands void. We personally suggest that you do it on your own only if you are in a really desperate situation and there is no way you can get maintenance from the manufacturer. I hope this assists you. John
Jan 26, 2011 | Toshiba Tecra A2-S119 Notebook
Lockedout laptop toshiba pt831a-67cti
I don't know about your particular laptop. I had this problem with my Tecra M1. Every time it boots, it asks for a password in the upper left corner. I put in, without quotes,"12345" and presses enter. This is a valid code on mine. If this is what yours is doing, try it. It just may work. Your discription "locked out" can mean a lot of things. You may want to be more specific.
Feb 12, 2010 | Computers & Internet
I have toshiba tecra model, some keys on keypad are not functioning .. pls advise .. By Renuka
if u have fall something like water or juice then u have to dissasseble ur laptop keyboard and clean the carbon points of ur keyboard using Aciton with tishue but if this not work then u have to change ur keyboard
hopw this will fix ur keyboard
Jul 30, 2009 | Toshiba Tecra A9-S9021V Notebook
Toshiba Tecra 8200 Laptop. when i type on the Keyboard some Characters do not work. A,D,E,I,K,L,P,R,S,T,U,W,X,Y,Z, and Back space do not appear on the Screen, all the rest are ok.
You probably need a new keyboard, but before ordering one go into the control panel, device manager and uninstall the keyboard.
Restart the computer.
If you get the same results, it's time for a new keyboard.
You can get a replacement from ebay for cheap and install it yourself. Usually it's 3-5 screws. very easy diy project.
Jun 17, 2009 | Toshiba Tecra 8200 Notebook
Toshiba tecra m4 tablet pc screen problems
Video driver update try updating your video driver
Jun 16, 2009 | Toshiba Tecra M4 Notebook
Toshiba won't boot
 You can boot from XP cd.
When prompted..press [R] this will launch recovery console.
Choose your windows installation (typically by pressing [1] press return..
When prompted for password type chkdsk /r
Press return..Windows will fix errors..type Exit and press return..
Let me know if that helps.
Jan 05, 2009 | Toshiba Tecra A8-S8314 Notebook
Computers & Internet Logo
116 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
