Question about Mitsubishi WD-65731 65" HDTV
Have mitsubishi wd 65731. where can i buy lens assembly for it...?
  • 998 Answers
Try to ask the service center they might help you and give you the right part for your tv not just a replacement.
Posted on Oct 15, 2010
Mitsubishi wd-65731 screen flickering
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. .
Nov 13, 2016 | Mitsubishi WD-65731 65" HDTV
Where can i get a repair manual for my wd-65731 mitsubishi free
you can get a free manual here all it takes is a download
http://www.retrevo.com/support/Mitsubishi-WD-65731-TVs-manual/id/564ag725/t/2/
Jan 29, 2012 | Televison & Video
Mitsubishi WD 65731 - where is the thermal sensor connection that sometimes needs to be resoldered?
does not need to be resoldered. needs to be changed! Any tech that is familiar with Mitsu would tell you that. It's behind the lamp area. Should be done by a Tv technician or you may never get it back together. But not expensive to repair. About $150 parts & labor.
Feb 26, 2011 | Mitsubishi WD-65731 65" HDTV
Mitsubishi wd 65731, replaced bulb, after about 10 minutes screen starts turning yellow
If the screen is turning yellow from the centre out, then the blue LCD unit is burning up. Check that there is good airflow to cool the optics. It will not recover if that is what has happened unfortunately.
Nov 23, 2010 | Mitsubishi WD-65731 65" HDTV
Mitsubishi tv
How long was the lamp last change?It was more 1 1/2 or 2 years must change the lamp.Life of the lamp it over.
Jul 31, 2010 | Mitsubishi WD-65731 65" HDTV
Changing the lamp on a Mitsubishi DLP WD-65731, when trying to put back the cartridge, it semms that it does not go all the way in since the two screws do dot reach the nut.
Look inside the tunnel with alight see if the contact plug is straight. Sometimes this plug can get bent to the side a little.
Sep 01, 2009 | Mitsubishi WD-65731 65" HDTV
Need to replace a cracked screen
WD-57731 & WD-65731 Front Disassembly
57” & 65” Models Screen Frame
Removal
1) Pull off the Speaker Grill.
2) Remove all the screws (b) from the
upper rear cover (except one at an
upper corner to support the frame).
3) Remove 10 screws (a) from the
front of the screen frame.
4) Remove the remaining ***** (b)
(supporting the frame). Carefully
pull the Screen Frame from the TV
and disconnect the ES and LE
connectors.
57” & 65” Models Screens Removal from Frame
1) From the rear of the Screen Frame remove 20 screws (a) from the top and bottom rails
2) Remove 6 screws (b) from each side rail.
3) Carefully lift the Screen assembly from the Frame.
MODEL: WD-52631 / WD-57731 / WD-65731
Screen Replacement
CAUTION: Wear gloves when handling the Lenticular Screen and Fresnel Lens.
This prevents cuts and finger prints. Do not place Fresnel Lens in the sun.
This may cause fire and heat related injuries.
Lenticular Screen and Fresnel Lens Replacement
1) Apply LENS-TAPE along the rear top edge of the Lenticular Screen.
2) Place the Fresnel Lens on top of the Lenticular Screen, and apply pressure along the top edge.
3) Place the screens in the screen frame and reinstall the cushions, top, bottom and side rails.
NOTE: The Lenticular Screen label must face the front and the Fresnel Lens label face the rear.
4) Reverse the Screen Removal Procedure and insert the screens in the Bezel.
Lenticular Screen and Fresnel Lens Removal
1) Remove the top, bottom and side HOLDER-SCREEN rails and their cushions from the Screen Frame.
2) Lift the screens as a single unit from the frame.
2. Separate the Lenticular Screen and Fresnel Lens.
Note: When separating the Lenticular Screen from the Fresnel Lens, use caution
while prying the Screen and Lens apart. Use a slot type ***** driver, and
remove the pressure sensitive double sided tape.
Mar 11, 2008 | Mitsubishi WD-65731 65" HDTV
Mitsubishi WD-65731 65" HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
